20 Most Recent Frigidaire FAM157S1A Air Conditioner Questions & Answers
sounds like it is either low on Freon or the compressor is going out. The blowing ice cold is an indicator that it may be freezing up because the low Freon. when it stops blowing cold, turn it to fan only mode and see if it gets colder again. If that is the case then the unit is low on freon and freezing up. I know that sounds confusing but that is how AC works. The low freon pressure means the gas is expanding too fast and the air flow cannot take up the cold from the evaporator fast enough. Turning the compressor off and keeping the fan on will alow the room air to take up the cold.
Frigidaire... • Answered on May 07, 2016
Sounds like the contacts in a switch or relay are stuck together giving power all the time. Get someone with electrical training to check the power side of things.
Frigidaire... • Answered on Jul 04, 2015
here is the link: Frigidaire Manual Search Results Please mark my answer helpful.
Frigidaire... • Answered on Jan 06, 2015
Good Afternoon Friend, I understand that the thermostat is not cycling the compressor on and off on your Frigidaire air conditioner, model# FAM157S1A. Please check the temperature sensing element to see if it is touching a cold coil. This will be located behind the air filter. Straighten away from the coil if it is touching. The other possibility is the compressor shut-off by changing modes. Wait approximately 3 minutes and listen for compressor to restart when set in the COOL mode. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful. -Best Regards- WP
Frigidaire... • Answered on Jul 03, 2014
DRILLED INTO COOLANT LINE WILL NEED TO FIX AND RECHARGE
Frigidaire... • Answered on Apr 22, 2014
Hello, if the unit has a drain it may be blocked and not allowing the water to drain. If no drain is present then the unit uses the condenser fan blade to scoop up the condensate and splash the condenser. This is done for two reasons, to keep the condenser cool and to evaporate the condensate
Frigidaire... • Answered on Jul 06, 2012
Turn the unit OFF using the ON/OFF Switch and unplug it for 15 minutes. After the time has elapsed, plug the unit back in and turn the unit ON. With any luck, the electronics reset and reverted back to the original factory settings. You should know immediately, once the unit is turned ON. If they did, you can now set the controls as you like. If they didn't, the control panel will need to be replaced. Parts are available from Frigidaire or their authorized distributor.
Hope this helps and thanks for choosing FixYa.
Frigidaire... • Answered on Aug 07, 2011
get some tape and splice it back to gether. wire nuts would be best .. just make certain your connections are tight and well taped.
Frigidaire... • Answered on Jul 14, 2011
probalbe causes may include loose connection, voltage drop (undersized circuit conductors), wrong type of fuse, bad compressor, motor or capacitor,
Frigidaire... • Answered on Dec 23, 2020
Frigidaire FAM157S1A Air Conditioner Logo
20 questions posted
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Steve Oakes
Steve Oakes
Jean Sintulaire
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Heating & Cooling
Most Popular Question
as soon as plug into wall compressor
  • Heating & Cooling
