20 Most Recent
Thomson RCA DCM245R Modem Questions & Answers
My modem randomly resets and no internet.
either the modem is going out or its a problem with your internet provider. before calling to complain to the internet provider. run down to your local walmart or electronics store and pickup a modern if you have the same issue its your internet provider.
i delt with a modem that was causing a similar issue. the problem ended up being the modem was running hot. i modified the case and added an external fan and the problem went away.
hope this helps. good luck
RCA DCM245R Modem Vista
Hi Ken:That's not my expertise but you could try installing some drivers:
rca-thomson-dcm245-driver.htmlHope this helps; also keep in mind that your feedback is important and I'll appreciate
your time and consideration if you leave some testimonial comment about
this answer.Thank you for using Fixya, and have a nice day.
Comcast is my service provider and I have had an
It can be an issue with the modem or with the line. When the line drops the link then the modem shows only two lights. And, when you power cycle the modem (unplug and replug it) it establish the session again with the comcast.
So, i'll suggest you to get the line checked first and if comcast finds that line is working fine then get the modem replaced.
Rashish
All of the lights are blinking in unison
Check to see if there's a reset button on it somewhere, and reset it, if you can. It sounds like a heat problem, since it's been getting worse and worse. Not much you can do in this case except have it repaired, or buy a new one. Get an estimate first, though, often it's better to buy a new one than pay as much or more to fix the broken one.
Need username and pwd
To access the configuration: The default user is 'Administrator' and the password is blank.
Make sure you have your DSL username and password to log into you DSL service. If you don't have it your service provider can give it to you.
If that doesn't work find the reset button on the back. Do not use the front reset. Hold the reset buttion in until the power led flashes red. This should reset the unit back to factory. You will need probably need you DSL username and password to re-configure the router.
How to turn on ethernet?
Your modem should be on when it is plugged in - "always on". If your ethernet light is not on, there is either an issue with your modem, or with your cable internet provider. Please contact their technical support people for appropriate troubleshooting.
Have I resolved your issue? If so, please rate this. ty.
Comcast internet
Yes you can get the internet with that modem but only through a cable connection.
Here is the specs on that particular model for your information >>>>>>>>>>
http://www.newwavecom.com/phone/pdfs/DS_DHG535_200802.pdf
Regards.
How can i connect an additional pc to my rca dcm245 cable modem?
Hi there.
What you have to do is plug in the Ethernet hub, run the Ethernet cable (RJ45) from the modem to the "internet in" or "internet" socket on the hub, it will the one which is separated from the others.
Then connect an ethernet cable in port 1 to your first computer and a cable from port 2 to your second computer and so on.
If you experience connection problems just pull power from the modem for 30 seconds, plug it back in wait a minute and reconnect.
If you would need further assistance please post back.
Good luck and thanks for using FixYa!!
