20 Most Recent Western Digital Elements 1TB USB 2.0 Hard Drive Questions & Answers
I have a WD Elements
Hello, the easiest way to achieve this is reinstalling the program on the hard drive. Select advanced installation, and when it asks for a path, give your hard drive's path. if you can't reinstall it, it'll be a little bit more complicated. if it's on Windows, you'll have to go into the "Program Files" folder, find your program's folder, and copy it into a "Program Files" folder (you have to create this one). Then find the main exe file in the program's folder you copied (usually <program name>.exe, right click on it and select Send to desktop (or create a shortcut) in order to access it more easily. That's it. if you need more details, feel free to ask. Antoine Viallon
12/16/2017 7:16:13 PM • Western Digital... • Answered on Dec 16, 2017
My pc does not recognise
Hi kileyjones1
Go to the Control Panel and select " folders options \ view "
Check " show hidden files , folders and drives "
Uncheck " hide empty drives in the computer folder "
Your drive will now appear in the Computer Folder .
Best regards ,
fanaudi .
4/29/2011 6:05:53 PM • Western Digital... • Answered on Apr 29, 2011
tip
How to get a WD Elements Drive recognized by Windows 10
Problem: WD Elements drive inaccessible when plugged into USB 3.0 Port on Windows 10 computer Symptoms: Drive appears and vanished repeatedly, blinking Drive light, error message of "invalid directory", files inaccessible Solution: Go to Control Panel. Click Change Power Plans. Go to USB settings. Click the plus sign. Beside USB selective suspend setting, click the plus sign. Change the "on battery: and the "plugged in" to disabled. Click apply. Click OK. The drive should appear as per normal and files be accessible. Note: The WD Elements drive WAS already accessible to a Toshiba laptop running Windows 7. It failed to be recognized by Windows 10. This solution has been tested upon an Aesus and an HP under Windows 10 Home and Pro.
How to run chkdsk on network drive
Cannot CHKDSK a network drive. Explanation: You cannot use the Chkdsk command with a local drive letter that has been redirected over the network. User Action: If you must run Chkdsk on the drive that is on the network, you will have to use the computer that is local to that drive. You might try this Log into the computer sharing the drive. Open your "Start" menu and select "All Programs." Click "Accessories" then "System Tools." Select the network drive and Right click select properties tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart have no input while the chkdsk utility is in progress any input may further damage your computers operating system and Hard Drive. If no luck chkdsk utility for network drives Found a great utility called "TreeSize Professional". It runs on Win9x and NT and has command line options for running in batch files. You can download a full functioning 30 day eval @ http://www.jam-software.com/tree.html Background b> A network drive is a disk or tape drive connected to a server in the network that is shared by multiple users, according to PCMag.com. A network drive can also be called a remote drive. b> Benefits b> A network drive is typically on a server. Servers normally are always on, so the information on the drive is always available. Information stored on the drive is accessible on any computer on the network. Significance b> The implications of network drive technology on computer mobility are significant. Network drive software that allows a person to connect to a network drive via the Internet is available. You may access files from home or work from any computer with an Internet connection, even if you're thousands of miles away. Run Network Repair From CMD b> The command-line interface for Microsoft Windows is accessible through the "Command Prompt" utility in the "Accessories" folder. The command prompt is particularly useful for network diagnostics and repair. For example, you can issue the "ping" command from the command prompt to test for and verify network connectivity. You can issue commands to repair the Windows networking from the command prompt instead of using the built-in diagnostic wizards that sometime provide less information than the command line. Click the "Start" button in the lower-left corner of the screen. Type "cmd" without quotes. Press "Ctrl," "Shift" and "Enter" simultaneously on the keyboard. Click "Yes." Type "ipconfig /release" and press "Enter." Type "ipconfig /renew" and press "Enter." Fix Network Device Driver Errors b> A network device driver is a small program that enables a network device to communicate with the computer's operating system, as well as with other computers connected to a network. Errors may occur if the network device driver becomes corrupted because of viruses and other causes. You can fix errors by following the steps laid out below. Check the information that came with your network device for compatibility issues; you need to know whether it is compatible with your computer, as well as the version of Windows you are using. Check if the network device is properly attached to the computer. Click on the "Start" button then choose "All programs." Right-click on "My Computer" and select "Properties" from the list of options. Select "Device Manager" from the "Properties window." In the "Device Manager" window, click the plus sign (+) beside the "Network adapters." This will list all the network devices installed. The network device that has an error should also have a yellow exclamation point right beside the network device icon. Double-click on the network device icon that causes the error. On the "General" tab, click on the "Troubleshoot" button and answer the "Troubleshoot Wizard's" questions. Follow the resolution steps provided by the "Troubleshoot wizard." If Step 3 does not work, check if your hardware or network device came with a software disc. Use the disc to install the network device on your computer. Follow the specific instructions provided by the manufacturer. You can also go to the manufacturer's website to check for updates available for the device driver. If no updates are available, try manually updating the driver. Getting an updated network device driver will prevent any conflicts from arising in the future. Go back to the "Device manager" window. Double click on the device that you need to update. This should bring up a small window that has the device's properties. Click on the "Driver" tab and choose "Update Driver." Reboot your computer, if necessary. If the network device still shows an error, Go back to the device manager, right-click on the device that shows an error and select "Uninstall." Restart your computer and open the "Device Manager" again as soon as the machine is back up. Right-click on the device and then choose "Scan for hardware changes." If the device continues to malfunction, the hardware or device may already be corrupted. Consider getting professional assistance from from a computer technician. Hope this helps. b>
6/22/2017 8:47:40 AM • Western Digital... • Answered on Jun 22, 2017
I do need to reinstall driver for WD Ext HDD 1021 USB Device - wdbaau0010hbk-01. Where I can find it?
The USB HDD driver is built in on XP. If the drive is not recognized try the following;
  1. If you usually plug it into the front USB, Try the rear USB
  2. Try a flash drive in the same USB and see if it works
  3. Plug the HDD into the USB then look in Device Manager for it, Right Click and click Update Driver then select Windows Update for the location.
6/19/2016 3:53:12 AM • Western Digital... • Answered on Jun 19, 2016
I need a usb to to sata/ide cable to fit a
Check online computer stores like Tiger Direct, Newegg etc. They should have what you're looking for.
6/5/2014 10:03:31 PM • Western Digital... • Answered on Jun 05, 2014
Wdbaar1600abk-00
Go to Western Digital's web site and download the software.
2/27/2014 12:54:10 PM • Western Digital... • Answered on Feb 27, 2014
The drive is recognised in the computer on the
Before the operating system can recognize the drive and assign it a drive letter, you must partition and format the drive. This article explains.Before the operating system can recognize the drive and assign it a drive letter, you must partition and format the drive. New hard drives are rarely pre-partitioned by the manufacturer. There are three options to formatting and partitioning the drive:1. (Recommended) Seagate's DiscWizard utility is compatible with all Windows operating systems. The DiscWizard utility is a fast and easy way to format a drive.2. FDISK is compatible with Windows 9x, Me. Please refer to Microsoft's knowledge base article Q255867 for instructions on FDISK.3. Disk Management is compatible in Windows NT, 2000, XP, and 7.
10/16/2013 9:58:11 AM • Western Digital... • Answered on Oct 16, 2013
My Hard drive dosen't work again the system could not recognize it.
Good Day.
Don't know if your external hard drive has power led on it, that comes on when connected to the PC. If it has these led, does it come on when connected to the PC? If no, then I believe there's is problem in the connection within the external Hard disk. So maybe you buy a new cord or you just have to change the connection panel or buy a hard disk casing that has the panel for connection in it.
Or, if the led give light, do you feel any movement (or rolling) within the external hard disk when connected? If yes then it's still working, just try the first recommendation.
I hope this helps. Thanks for using FixYa!
9/11/2012 9:15:45 AM • Western Digital... • Answered on Sep 11, 2012
Western digital elements external harddrive
http://download.cnet.com/external-hdd/3000-18493_4-91318.htmlhttp://download.cnet.com/wd-external-hdd-button/3000-2110_4-96908.htmlor if these are not right
click start control panel administration tools computer management device manager scroll through all of your devices
if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver
if you computer came with a motherboard disk the drivers could be on it
or you might have to download one
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
it might take some time being a freeware driver solution
note: it will find all of your outdated drivers
this is a free driver solutions
they will automatically search for and find the correct driver
hope it helps you
3/5/2012 12:51:18 AM • Western Digital... • Answered on Mar 05, 2012
How to refomat from ntfs to fat 32 windows 7
in windows, right click the drive in question and choose "format..." from the menu. in the subsequent window, select FAT32 as File System and default as allocation size. please note that a FAT32 file system does NOT support files that are bigger than 4GB.
12/28/2011 3:57:21 PM • Western Digital... • Answered on Dec 28, 2011
I ;have formatted the WD external drive and
You should not even try to install an operating system on an external drive. Windows looks at the "C" drive and installs programs to "C" drive. You are trying to put it on the "G" drive. You will have too many problems and wish you never had tried. Buy a larger main drive and partition it with two equal partitions. Then "Dual Boot". You will find how to do this on the internet. Just Google "Dual Booting".
9/9/2018 5:37:54 PM • Western Digital... • Answered on Sep 09, 2018
Western Digital Elements 1TB USB 2.0 Hard Drive Logo
Popular Tags
4 questions posted
Top Western Digital Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Paul Bade
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Elements Western Digital
  • Elements Western Digital
Most Popular Question
pc not recognise
  • Computers & Internet
