20 Most Recent Behringer Pro Mixer Djx750 Professional 5 Channel Dj Mixer With Advanced Digital Effects And Bpm Counter Questions & Answers
Line level output of the mixer would go into the line level inputs of the EQ, and the EQ line level outpputs to the line level inputs of the amplifier. If you are faced with a mix of unbalanced inputs or outputs, to balanced inputs or outputs it gets a little complicated because you need to matrix the balanced signal to unbalanced load and vice versa. There is no single answer to doing this either.
RCA jacks are unbalanced, 2 conductor 1/4 inch connections are unbalanced most of the time. XLR and 3 conductor 1/4 inch jacks and plugs can be either balanced or unbalanced.If either are wired so left and right are a single ring or tip on the 3 conductor 1/4 inch jack, it is unbalanced and they would share a common ground lead. XLR wired with one pin common with shield and right and left have a single conductor on the plug or jack, that is unbalanced.
Behringer Pro... | Answered on Apr 27, 2012
The internals run on +/-15 Volts and +5 volts. While schematics show the audio and digital circuits they fail to show the power supply. I suspect the supply uses regulators such as the 7815 family so one would want around 18 to 20 volts DC of each polarity.A transformer would likely be about a 28 to 30 VAC centertapped. HOWEVER transformers rarely fail. There should be fuses to protect the transformer. Some Behringer equipment uses a switching supply. Common failures in those is the switching transistor. When testing these units, it is useful to place a 25 watt incandescent lamp in series with the power cord to save fuses and act as a resetable fuse that will send a limited current into the unit for testing.
Behringer Pro... | Answered on Jun 14, 2011
Make sure channel(s) are assigned to stereo output
Behringer Pro... | Answered on Mar 30, 2011
In order to help you we would need the make and model of the mixer.
Behringer Music | Answered on Apr 30, 2020
Behringer recommends using a shielded CAT 5e cable with Ethercon connectors wired to the T568B standard to connect the two. Also you need to make sure that the board is completely powered on before turning on the S32 for proper connection. Make sure you are connecting between the Aes50A ports. When connected you should be able to see a green light next to Aes50A in the main screen. Then you will need to properly route the channels.
Behringer Music | Answered on Nov 13, 2019
See if another audio source connected to the mixer produces the same results. Try with the same cable and then with another cable. The purpose of this procedure is to determine if it is the cable and/or the laptop. (Sound card problem???) or mixer.
Is it ALL audio or just specific audio from for instance, a music application? Does it cut out using iTunes?
The mixer may have a bad or oxidized input. Try a different input channel? Are you using headphones to listen? It may be the headphone amp? OR, if audio is produced via amped speakers, it may be the mixer output. Does the mixer have metering? Do the meters also cut out? Does the laptop do the same thing if plugging in headphones to the laptop directly (no mixer)?
Behringer Music | Answered on Oct 23, 2019
You have given in detail which is helpful
Behringer Music | Answered on Oct 16, 2019
I looked up what that unit is so I'm not uber familiar and this is before coffee, however, check your effects levels, possibly delays or echos are building up on an individual channel and adding to your total output making it clip. Even if you don't have the effects on output, they can work in the background and clip internally. Is the output sound affected? Magnetic interference is another possibility if you are running it close to pickups, recorders and other high power supplies. Trim levels set too high? I don't know your actual stage setup but these are a couple things I have experienced through the years. Ahh, here's coffee and a drink to you finding your problem.
Behringer Music | Answered on Sep 15, 2019
Hello Geoff, try using an external processor and check that it works well, if so, the problem is that you have the Jack connectors of Effect sending and those of Return of Effects, dirty
Apply a couple of drops of oil, type WD40, to a Plug connector and insert and remove them repeatedly in each connector Jack for sending and returning effects
I hope you can solve the problem, comment the results
Greetings Franco Dosil
Hola Geoff, prueba usando un procesador externo y comprueba que funcione bien, si es asi, el problema es que tienes los conectores Jack de envio de Efecto y los de Retorno de Efectos, sucios
Aplicale en un conector Plug un par de gotas de aceite, tipo WD40 y entralos y sacalos repetidamente en cada conector Jack de envio y retorno de efectos
Espero puedas solucionar el problema, comenta los resultados
Saludos Franco Dosil
https://media.music-group.com/media/PLM/data/docs/P0A8M/PMP1680S_PMP980S_PMP960M_M_EN.pdf
https://c3.zzounds.com/media/PMP1680S_P0A8M_OI_EN_ES_FR-df44b2314272dfc61a7cabe5bb88ecce.pdf
Behringer Music | Answered on May 24, 2019
Connect the two Behringer B215XL to the Right/Main Speaker Outputs. Monitor(s) would connect to the Left/Mon Speaker Outputs
manual is here: https://assets.peavey.com/literature/manuals/xr684fand696f_manual.pdf
Behringer Music | Answered on May 21, 2019
Behringer Pro Mixer Djx750 Professional 5 Channel Dj Mixer With Advanced Digital Effects And Bpm Counter Logo
4 questions posted
Top Behringer Music Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you a Behringer Music Expert? Answer questions, earn points and help others
View Most Popular
Behringer Music
  • Behringer Music
Most Popular Question
wire gemini graphic eq 3000 behringer
  • Music
