20 Most Recent
Mintek MDP-1880 8.5 in. Portable DVD Player Questions & Answers
My Mintek portable DVD player's
After a while even rechargeable batteries loose the ability to hold a charge. This process accelerates when the battery is allowed to lie completely discharged for long periods of time. NiCad batteries especially have this issue. If you left the battery sitting for long periods without occasionally charging it, it losses the ability to hold a charge. It appears you are going to have to either do without the battery or replace the pack. I would take out the old one, it will eventually start to corrode and leak and if its still in your machine it will cause damage.
If you get a new battery pack make sure you charge it fully and then depleat it completely before recharging it.
hope this helps.
Need to find plug for dvd player
here you go http://www.amazon.com/Dvd-1710-Dvd-5820-Dvd-5830-Dvd-5861-Mdp-1810kit/dp/B001R2ERFY let me know if that solves it for you!
No hdmi cable spot on my mintek 26" tv do i need a converter or will this not work?
If it has the RCA (Red,White,Yellow) ports you will have to use those. In that case if you are using something like a DVD player that only has HDMI output you will need a special cable that goes from RCA to HDMI. Here is a quick link for you to reference.
https://www.walmart.com/ip/5-Feet-1-5M-1080P-HDTV-HDMI-Male-to-3-RCA-Audio-Video-AV-Cable-Cord-Adapter/965878335?wmlspartner=wlpa&selectedSellerId=11827&adid=22222222228252900294&wl0=&wl1=g&wl2=m&wl3=296348219694&wl4=pla-526929718011&wl5=9010172&wl6=&wl7=&wl8=&wl9=pla&wl10=117084777&wl11=online&wl12=965878335&wl13=&veh=sem
