20 Most Recent Sierra Entertainment Pharaoh And Cleopatra for Windows Questions & Answers
Probably a bit late, but here are the best fixes I found:
First off, you want to:
*** Change compatibility to Windows XP (SP3)
*** Disable Visual Themes
*** Run as admin
Next you want to:
Download the pharaoh exe files (these are for modifying the resolution - this is what worked for me - I used the lowest res available, so I cannot comment on higher ones)
http://www.wsgf.org/dr/cleopatra-queen-nile/en
Or you can try this fix:
https://web.archive.org/web/20080721084339/http://www16.brinkster.com/salvage/thief/imagecfg.zip
"Download ImageCFG
Extract the .zip and place imagecfg.exe in your game's folder.
Create a batch file. First, open up notepad and paste the following.
@echo off
if not exist Pharaoh.exe goto end
if exist Pharaoh.exe.bak goto end
copy Pharaoh.exe Pharaoh.exe.bak
imagecfg -u Pharaoh.exe
imagecfg -a 0x1 Pharaoh.exe
pause
:end
Save as a .bat file and place it in your Pharaoh installation folder.
Run the batch file.
This will change the CPU affinity of Pharaoh so it will run on one CPU core."
This fix taken from here:
http://pcgamingwiki.com/wiki/Pharaoh
Sierra... | Answered on Mar 12, 2016
I’m having the same problem but my copy is a digital download.
Video Game... | Answered on Jan 07, 2021
    -Open Minecraft game from games and app menu
    -Tap centre button on xbox controller twice
    -Select snap an app-Do this by pressing up on the D pad of your controller
    -Select Twitch-scroll through apps until you find Twitch, once you find it, press A button
    -Choose broadcast-when you find it hit a
    -Name broadcast, go down to text field and hit a button.
    -Begin broadcasting-scroll down to bottom of twitch screen and hit a on "start broadcasting". Tap centre button on Xbox controller one more time.
Video Game... | Answered on Jan 05, 2021
Get CD Cleaning disc from Walmart. They have little brushes that clean the optics.
Or it is a counterfeit copied disc!
Video Game... | Answered on Dec 26, 2020
Seems impossible unless you jailbreak it
Video Game... | Answered on Dec 19, 2020
Error Code: 150-3039 means there is a problem with with your external storage device. It is most common when you are using an external hard drive that does not have a separate dedicated power supply. It either isn't getting enough power or the hard drive has other problems. Try powering off your Wii U, disconnecting your external HDD, and running the system without the drive. It should work. Then power off and reconnect your external drive. If you receive the error message again then you should look into getting new external storage. This link lists Nintendo approved devices: http://en-americas-support.nintendo.com/app/answers/detail/a_id/1359/~/what-external-storage-devices-can-be-used-with-wii-u%3F
Video Game... | Answered on Dec 09, 2020
I got you on that code
GL19-Y15U-72FO-U5SW<br>
Video Game... | Answered on Dec 08, 2020
Confirm the message with OK.
The automatic spout adjustment will be deactivated during drink preparation whilst the machine remains switched on.
You can still make drinks.
Video Game... | Answered on Dec 07, 2020
I would say the best bet it to call the Escalade Sports Customer Service number and see if they can help you get replacement parts. I am going to put a call in myself to get a new junction box (I have no power to the fans, but the scoreboard works) and some new strikers and a puck. I got my table from a friend who had been using it and then when I set it up it would not turn on...guess that explains why it was being stored in his garage when I picked it up!
The Escalade Sports Customer Service number is:
1-800-426-1421
Video Game... | Answered on Dec 04, 2020
Super Saiyan
Video Game... | Answered on Nov 28, 2020
This is an error that is reported when u have an extension/attachment plugged into your wiimote.. this can be either a motion plus, a nunchuck, anything other than just the wiimote itself is a possible candidate for this issue...remove it and the error should go bye-bye.. bye-bye :)
Video Game... | Answered on Nov 27, 2020
Ok.first go to emulater.com:visiualboy advance
second go to doperoms.com for games.
Note:you can't get all the games here,but if you want cool hacked games go to wahack.com
If you don't understand the language then click on the flag on the right.
Video Game... | Answered on Nov 15, 2020
I need one too. I found the owners manual on-line and it says the AC/DC Adapter we need is 12volts and 2500ma (2.5amp). I wrote to the company to see if one is available. If not, I may just try to find one that matches the voltage and amperage, cut off that odd male end and wire it directly. the only issue will be finding the positive and negative.
Video Game... | Answered on Oct 30, 2020
I added the Sector 7 XG900 Joystick driver files from my install disk to a WinRAR archive file & uploaded it to TinyUpload.com for you. Just double click the "setup.exe" & it will guide you through the install process. If you have any questions or need any help, just ask. Remember, you need to have WinRAR installed to open the archive. Link to WinRAR: http://www.rarlab.com/download.htm
UPDATED LINK:
Drivers:
http://www.filedropper.com/sector7xg900joystick
Video Game... | Answered on Sep 09, 2020
Hi, you can check https://www.rs2hot.com, which is a Top Games Gold, Powerleveling, Account and Items Supplier also offering cheap and safe rs gold.
Video Game... | Answered on Aug 20, 2020
I need a 19 digit code to play Speed Racer The Great Plan game
Video Game... | Answered on Jul 27, 2020
How to Resolve the Roku Error Code 009?
1. Turn off your Roku device. ...
2. Wait for the lights to go off on the Roku system.
3. Switch off your wireless router until the lights are off.
4. Now drop the wireless router's data cable.
5. Wait a minute for the power cable to reconnect.
6. Turn your wireless router on first.
7.Wait for the router to reset again in 60 seconds.
Check and ensure your wireless router is working properly.
1. If you have successfully developed internet connectivity, turn on your Roku system.
2. Start connecting the Roku system to a wireless network now.
3. Perform the process of activation, as before.
4. Check to see if the problem persists after the activation process.
5. If the problem with Roku Error Code 009 is resolved, then continue to use your router as needed.
Resolve the Roku Error Code 009 at our website and our technician are available 24/7.
Video Game... | Answered on Jul 21, 2020
Press the A Button and then you can adjust the flashing box with the B (up)or C (down). Press the A again and you can move to a new box.
Press D to start it up again.
Video Game... | Answered on Jul 15, 2020
Sierra Entertainment Pharaoh And Cleopatra for Windows Logo
2 questions posted
Top Sierra Entertainment Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Tom Chichester
Are you a Sierra Entertainment Video Game Console and Game Expert? Answer questions, earn points and help others
View Most Popular
  • Sierra Entertainment Video Game Consoles & Games
Most Popular Question
pharaoh cleopatra freezes constantly
  • Video Game Consoles & Games
