20 Most Recent
Haier HL19R 19" LCD TV Questions & Answers
Need three digit code to access DISH network
We would be happy to help. We currently do not have anycodes specifically for your Haier TV. We would recommend performing apower scan. If there is a code that is compatible with your TV the power scanwill find it.
Power scan instructions:
Step 1:
Press and hold the TV mode button until all mode button back lights illuminate,then release.
Step 2:
Press and release the Power button.
Step 3:
Press the Up button once per second while pointing the remote at the desiredequipment. If the code for the equipment comes up, the equipment will poweroff.
Step 4:
Press the pound (#) button. If the code entered is valid for the remote, themode light flashes three times.
After doing the power scan please remember to put the remote back into SAT mode.Thanks so much for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Code for haier
These are the setup codes for Haier: 0081 0216 0217 0157
10/26/2012 5:20:11 PM •
Haier HL...
Answered
on Oct 26, 2012
Am I suppose to put water into the Haier Standing Portable Air Conditioner?
Most air conditioners need water removed, not added. They act as dehumidifiers as they change the air temperature. What model air conditioner do you have? The Haier HPRD12XH5 has a blinking red LED with a triangle symbol to indicate the unit is flooded. Air conditioners can also fail if there is a coolant leak or the room is too cool. If the removed water freezes in the air conditioner, it can damage the fan and cause the motor to overheat.
The air cooling systems that need water added are "swamp coolers". That's the term I learned for the old-fashioned fan + ice/water cooling systems that work well in low-humidity environments. They'll make the area feel hotter in high humidity conditions.
I hope this helps. Please add a comment with the model of your unit for further information.
