20 Most Recent Frigidaire FRS12PYS1 12000 BTU Split System Air Conditioner Questions & Answers
2answers
What does H1 code indicate?
Hello E, I appreciate your post! I see that your Frigidaire air conditioner is displaying an error code of "H1". I have reviewed the air conditioner and the "H1" error code could be an "HI". The "HI" error code means that the room temperature is above the display range. I would recommend performing a reset on your air conditioner. In order to reset the air conditioner you need to unplug the power cord you can press the reset button and then the test button that should restart your air conditioner. If that does correct your issue I would recommend seeking assistance from a professional technician for proper diagnosis and repair. I hope this information is helpful for you. -Matt
4/28/2019 4:20:11 AM • Frigidaire... • Answered on Apr 28, 2019
Window ac/heater freezes up when using the heater?
This is likely due to a lack of airflow. Make sure that the air filter is clean and that there are no obstructions blocking the air intake or exhaust vents. If this does not resolve the issue, you may need to have a technician come out and inspect the unit for any other potential issues.
2/14/2023 12:17:18 AM • Frigidaire... • Answered on Feb 14, 2023
Frigidaire model fftr1835vs styrofoam inside filter housing unit. Should it be there?
Not 100%certain to what styrofoam you are referring to but there is definitely styrofoam components inside the machine. The entire drain pan is made of styrofoam, I would not touch it.
7/4/2022 9:22:49 PM • Frigidaire... • Answered on Jul 04, 2022
New Frigidaire Portable ac unit turning off and flashing 8.8
Have you drained the water?
7/2/2022 7:30:52 PM • Frigidaire... • Answered on Jul 02, 2022
2answers
The "filter reset" button keeps turning on on my
The blower wheel probably is dirty. The unit is sensing that not enough air is flowing across the AC coil.
6/27/2022 12:31:44 AM • Frigidaire... • Answered on Jun 27, 2022
2answers
The compressor on my Fas257r2a 25000 btu stops running before the room is cool. but takes awhile before compressor starts up again What could be the problem?
Mine is doing the same but it's very moldy and dirty. It worked well when we used it for the first month when we moved into our Gma's house. She left the unit. It's old yes but it worked fine before. Why is this happening? I'm going to clean it, but I have NO IDEA HOW TO GET IT OUT OF ITS CASE! HELP
6/20/2022 12:59:27 PM • Frigidaire... • Answered on Jun 20, 2022
My Frigidaire 12,000 BTU window air conditioner is tripping as soon as I plug it in!
did you clean it with water? They don't mix. Use a hairdryer to dry thoroughly.
6/18/2022 6:59:05 PM • Frigidaire... • Answered on Jun 18, 2022
I have a Frigidaire FGH2272UF and want to change from centigrade to fahrenheit? Help
Here are some videos, but it looks by doing a search on that model, that you can't change it. Having said that, the manual shows both, but perhaps that is for display. https://www.manualslib.com/manual/1581184/Frigidaire-Fg4h2272uf.html?page=13#manual Videos https://www.google.com/search?q=Frigidaire+FGH2272UF+change+from+centigrade+to+fahrenheit This search forces your model to be featured https://www.google.com/search?q=Frigidaire+%22FGH2272UF%22+change+from+centigrade+to+fahrenheit It doesn't appear to be in the manual. Centigrade is much easier. Fridge at 3'C and Freezer at minus 18'C. Freezing is 0' and boiling is 100'. You can hang an American thermometer inside. https://www.manualslib.com/manual/1581184/Frigidaire-Fg4h2272uf.html .. ..
4/13/2022 6:15:05 PM • Frigidaire... • Answered on Apr 13, 2022
2answers
Can't change temperature on AC
thats normal its showing ambient when you lower it the number will change to the setting and then will go back to show what the ambient temp as the room gets cooler the temp number will go down and shut off at set temp
6/30/2021 4:29:10 PM • Frigidaire... • Answered on Jun 30, 2021
2answers
Why does my wall unit Frigidaire air conditioning fuse keep blowing when I it's on the power cord
probalbe causes may include loose connection, voltage drop (undersized circuit conductors), wrong type of fuse, bad compressor, motor or capacitor,
12/23/2020 5:59:09 AM • Frigidaire... • Answered on Dec 23, 2020
2answers
I have a kt-9018e universal a/c remote can you tell me the code for a frigidaire
Thank you for your post, John!
Based off the information you have provided you need the code for a universal air conditioner remote. You may need to speak with manufacturer of the remote for that direct code. Best of luck! -Matt
6/11/2020 6:32:20 PM • Frigidaire... • Answered on Jun 11, 2020
After 11 years, my Frigidaire window unit has stopped blowing cold air. On the first startup 3 days ago, it blew cold air after 5 min. Then 2 days ago it blew cold air after 10 min. Today no cold air.
Make sure that the cooling coils are clean. Also that the cooling fans are working. It may have lost it's treon and it is time to buy a new one.
5/20/2020 2:44:21 AM • Frigidaire... • Answered on May 20, 2020
2answers
When unit is turned off, unit is still running. MODEL LRA11PZW1
yes, but when it is running, does it also turn off??
7/26/2019 4:14:18 AM • Frigidaire... • Answered on Jul 26, 2019
My Frigidaire AC unit was working and all of a sudden it Stopped. And it won't cut back on. What could have caused that?
Could have clipped the low voltage wire outside with a weed wacker, could have blown out the run capacitor or lost a major component! If the unit is buzzing when you turn it on but nothing's running (compressor or fan)then you have a failed run capacitor! The list of things it could be are endless without more info
7/13/2019 3:50:25 PM • Frigidaire... • Answered on Jul 13, 2019
Frigidaire FRS12PYS1 12000 BTU Split System Air Conditioner Logo
2 questions posted
Top Frigidaire Heating & Cooling Experts
Robert
David Shaub
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Heating & Cooling
Most Popular Question
h1 showing up find code anywhere
  • Heating & Cooling
