20 Most Recent Dell Vostro 1400 Laptop Computer (Intel Core 2 Duo T5670 1.8GHz, DDR2 SDRAM 1000MB, 80GB) (BQCWJ1S_1) PC Notebook Questions & Answers
I doubt there is battery problem, have you tried switching on laptop without battery and connecting through the laptop charger? most probable your battery is not taking the charge. so suggest you to disconnect the battery and try using laptop with charger then you'll find the problem.
Dell Vostro 1400... | Answered on Aug 06, 2012
Generally, connecting phones via bluetooth to a laptop just allows for file transfer between the two devices. It is not to input sound from the phone through the speakers of the laptop. You would need a bluetooth audio device for that such as bluetooth speakers or headphones
Dell Vostro... | Answered on Jan 12, 2017
This error is basically saying that Windows, for one reason or another, cannot communicate properly with one of your programs. This communication problem is usually caused by out-of-date, missing or corrupt device drivers. ... Select Start > All Programs > Windows Update.
Dell Vostro... | Answered on Oct 17, 2016
Check you have the Dell drivers, NOT windows drivers first.
Dell Vostro... | Answered on Oct 16, 2016
i used to get that also, I wrote down windows numbers from windows sticker on the side of machine, (needed magnifying glass) and went online to windows verify, after they scan it, it came out good
Dell Vostro... | Answered on Jul 25, 2016
Open a command prompt ( Windows key + R to open Run box, then cmd), and type
ipconfig /all
and look for the wifi adapter. The entry labelled "Physical Address" is the MAC address. It will look something like 84-3A-4B-C8-E9-B7
(Your router might want it entered in the format 84:3A:4B:C8:E9:B7)
Dell Vostro... | Answered on Jul 21, 2016
The cooling fins on the processor chip are plugged with dust. The fan may not be turning fast enough. If that's the case you'll need to replace the cooling fan
Dell Vostro... | Answered on Jan 15, 2016
You'll have to get the audio driver off of Dell's website.
WiFi will in the laptop will connect to a wireless router or a hot spot. The laptop itself has no hot spot built in.
The coin cell battery inside the laptop needs to be replaced
Check the cooling fan and the air inlet screen for blockage. You may need to clean the cooling fan and the fins on the heat pipe.
Some fans can be oiled, some not. You can get a replacement fan from Dell's website.
check the power supply (smps)
check the CMOS battery
check the motherboard
Dell Vostro... | Answered on Nov 06, 2015
What model is it? Could you post the service tag number?
Believed me you have to reinstall your operating system. I encountered that problem too. I uninstall and re-installed .NET, update windows service packs nothing happened until I reformat the hard drive and install the operating system again.
remember format the hard drive first then install the operating system (backup your data first)
Dell Vostro... | Answered on Apr 11, 2015
Hi Anonymous,
Try pressing the Ctrl+Alt+Delete keys together and now press lock the computer. However, if this doesn't help do let me know.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Dell Vostro... | Answered on Mar 17, 2015
Dell Vostro 1400 Laptop Computer (Intel Core 2 Duo T5670 1.8GHz, DDR2 SDRAM 1000MB, 80GB) (BQCWJ1S_1) PC Notebook Logo
2 questions posted
Ekse
Thomas F. Schneider
Shawn DuRee
View Most Popular
Vostro Dell
  • Vostro Dell
Most Popular Question
vostro 1400 won 39 t turn
  • Computers & Internet
