20 Most Recent Sony Cyber-Shot DSC-HX9V Digital Camera Questions & Answers
You've not mentioned which program you are using, or on which platform.
Sony Cyber-Shot... • Answered on Jun 20, 2017
Are you sure you are using the correct memory stick? Most cameras use SD cards, but Sony uses Memory stick Duo pro. Make sure you have the right memory, because not all Memory sticks are compatible and not all can be user for both, stills and video. If you have the right card, make sure you only put it in like described in the manual. If you try to put it in, the wrong way around, toy could damage the camera. (most likely you will bend the contact points inside the memory card holder) and if you already did, it could be almost impossible to get that right, without sending in the camera to a Sony service centre. For memory card use, see page 276 and 277 of the (english) manual. The manual can be found online.
Sony Cyber-Shot... • Answered on Jan 21, 2014
Replace this control. First buy a service manual costing USD30.00 to upload.
Sony Cyber-Shot... • Answered on Oct 17, 2013
turn the camera sideways. then it might be the way it was taken.
Sony Cyber-Shot... • Answered on Sep 10, 2012
Yes! mine works the same way, when fully charged it cuts power to the battery.
Sony Cyber-Shot... • Answered on Jul 20, 2012
Use the "Format" command. It's in the Memory Card Tool menu, which is under the Setup menu.
Sony Cyber-Shot... • Answered on Jul 13, 2012
I have had that problem unfortunately the method to fix this issue is not guaranteed but has been effective. First get a wash cloth or anything similar and fold it in half and then fold into a square. Second cover the side of your camera with the cloth that holds the battery. Third depending on how thick the cloth is tap the battery end of the camera on a hard surface a couple times then reboot your camera
Sony Cyber-Shot... • Answered on May 16, 2012
Sony Cyber-Shot DSC-HX9V Digital Camera Logo
49 questions posted
Top Sony Cameras Experts
Vish Iyer
Vish Iyer
gbob59
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Sony Camera Expert? Answer questions, earn points and help others
View Most Popular
Sony Cameras
  • Sony Cameras
Most Popular Question
tell battery dsc hx9v fully charged
  • Cameras
