20 Most Recent
Acer Aspire 5710 Series Laptop Motherboard (System Board) Questions & Answers
Find serial number
cheak that u right clik at my computer than find it from properties r management ok
Aspire 5710
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key
Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
(note after you have loaded the operating system you should go back and change the first boot device to your failsafe or optimized defaults)
after windows has loaded
your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd
during the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys load
failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
otherwise it will keep booting from the cd /dvd drive
hope this helps
Webcam crystal eye not working aspire 5710
click start control panel view devices and printers you should see your webcam from there
if you are have trouble with your webcam
click start right click on my computer select properties then device manager scroll down image devices you could see a yellow question exclamation mark? ! or a red X
right click to reinstall drivers or update driver
W7
click start control panel administrive tools ,computer management ,device manager scroll down image devices you could see a yellow question/exclamation mark ? ! or a red X a new driver will need to be installed
hope this helps
''e'' button :acer empowering technology
That button can be set using the utility on your programs list
It maybe that you accidentally turned it off or set it to do some other task.
Start there first before re-installing the program that sets it.
That is on one of the cds that should have come with it and can be installed by itself.
