20 Most Recent Canon Pixma MG5220 InkJet Printer Questions & Answers
Error 6000
same pcs of paper in printer please boring the printer and solve the problem
11/17/2021 8:06:10 PM • Canon Pixma... • Answered on Nov 17, 2021
7answers
Printer will not print from rear tray but does not appear to be jammed.
WILL THE PAPER FEED AND NOT PRINT? HAVE YOU GONE TO PRINTER SERVICES AND TRIED TO PRINT TEST PAGE? ARE YOU SETUP TO SHOW BACK TRAY IS SELECTED AS PAPER SOURCE?
6/1/2020 10:04:22 AM • Canon Pixma... • Answered on Jun 01, 2020
Canon mg5220 printer won't print black
Try this: take a small, sharp knife and make sure the air slit on the top of the cartridge goes all the way through the plastic. You know that little tab you have pull off the top of the cartridge before inserting in the print head? There is a tiny slit under the tab to let air in, which is necessary to let the ink flow out. The slit is made very small so ink won't leak inadvertently out the top. Sometimes the slit doesn't go all the way through the plastic. When that happens, the ink can't flow. I blew through that slit on a defective cartridge and no ink came out. I used a pen knife to open the slit (it doesn't take much) and then blew again. This time ink spewed out the bottom. My print test showed the black ink coming through. It was a bit spotty so I cleaned the print head and now the black ink comes out just like its supposed to.
1/25/2019 6:46:42 PM • Canon Pixma... • Answered on Jan 25, 2019
3answers
Is there any way to get ink to dry on the wrong
Hi RobynPRINTING ON REVERSE SIDE OF PHOTO PAPER The only realistic choice here is for you to chalk this episode down to experience, buy some new photo paper of the correct type to produce your preferred outcome and then do another print run of the postcards. I always advise, when printing on exotic papers and even when producing ink intensive printing on ordinary paper, to print a single test copy first and then study the result, rather than completing the entire print run in one go. Because of the lack of absorbency on the reverse side of the paper you used, I would also recommend temporarily putting the printer settings back to regular paper and printing a test page, so the micro-nozzles on the print head are cleared of any excess ink. If the test page is not perfect, then also run your printer's Print Head Cleaning maintenance tool. Then reset the printer back to photo printing for another run at your postcards.Good luck.I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can. If you need further help, please do not hesitate to post another Question or add a Comment to this Question.Thanks for using FixYa.
12/1/2018 6:07:52 PM • Canon Pixma... • Answered on Dec 01, 2018
I keep getting an error message b200 what can I do to fix my proublem
it's a cartridge fault, you have to replace the cartridges, then carry out a nozzel clean.
5/2/2016 2:47:11 AM • Canon Pixma... • Answered on May 02, 2016
Error code B200 with message reading: Unplug power cord and contact service centre
VH monitor error mainboard or printhead error only replace can fix problem
4/13/2016 9:34:32 PM • Canon Pixma... • Answered on Apr 13, 2016
Not printing out on paper. it comes out clear. Ink cartridges are all full, have done a clean. don't know what else to do
If after all you do, reinstall drivers, clean, etc. unit still does not print, then your problem may lie with the print head which on Canon printers is NOT part of the cartridge. If cartridges have been filled that may be causing the issue and there could be a work around for it posted on Google. Printer outfits do not want you to get your own ink.
11/18/2015 1:56:29 PM • Canon Pixma... • Answered on Nov 18, 2015
Canon pixma mg5220 wrong printhead error u052
Were you aware of the Canon printer class action suit? Canon USA Inc Consumer Class Action and http://www.federmanlaw.com/Websites/federmanlaw/images/QUESTIONNAIRE.pdf "...at least 16 different Canon printer models have been identified that display an error message of "U052: Wrong Printhead Error," after limited use. This error indicates that the printer does not recognize the printhead, or that the printhead itself is faulty, but disables all functions of the printer, including scanning and facsimile capabilities, rendering the printer unsuitable for its intended purpose and use."
6/24/2015 1:12:19 AM • Canon Pixma... • Answered on Jun 24, 2015
2answers
Why won't it print with black ink?
Hi Michael, Can you check the printer properties whether it shows up the new ink level ? I would like to have more info to help you further Thanks Seb
6/2/2015 7:05:23 PM • Canon Pixma... • Answered on Jun 02, 2015
Error says type of print head is incorrect - all I did was deep clean the head
Review the material on this page, it may be your solution: http://genesisoneandone.com/2014/10/how-to-clean-a-canon-printer-printhead/
5/20/2015 12:36:17 PM • Canon Pixma... • Answered on May 20, 2015
Printer is ccted to wifi. so is laptop. when I go to print it just says getting printer information. how do I connect
Unplug and shut off all devices, restart and see if connection is made. Was the driver disc installed in laptop for this printer? Might have to create a new wifi network if communications are not being made.
5/7/2015 3:59:14 PM • Canon Pixma... • Answered on May 07, 2015
My printer will not respond to my computer. How do I fix it?
Go to the canon website and download the proper driver. You must also download the wireless connection software. If you google "Canon Pixma MG220", the first item will be the link you need. You also download the manual. Good Luck
4/24/2015 11:02:56 AM • Canon Pixma... • Answered on Apr 24, 2015
4answers
I can't turn on my canon mg5220 printer. I checked the power source and it's fine. What do I do?
Have you tried holding the power button down for about 5 secs?Has it been operating ok before?
4/13/2015 9:15:04 PM • Canon Pixma... • Answered on Apr 13, 2015
Get ink cartridges to move
This video shows how to change the cartridges in a Canon MG5220. Canon MG5250 Changing the cartridges
3/3/2015 8:34:34 PM • Canon Pixma... • Answered on Mar 03, 2015
My computer shows my printer is offline
cycle the printer power, if it is WIFI, be sure the WIFI is active and on. remove and reload the printer if nothing else works.
2/24/2015 3:16:29 PM • Canon Pixma... • Answered on Feb 24, 2015
3answers
How do i install ink cartridges
open the front cover, wait till cartridge stop and then push down the cartridge.
2/12/2015 3:20:33 PM • Canon Pixma... • Answered on Feb 12, 2015
I was using my Canon MG5220 printer and it turned off by itself nothing that I tried worked it doesn't turn on cable is Ok a/c converter is Ok
Bad news - either the main-board is toast or the gear train has got out of sync. A good service tech might be able to fix it, but it is unlikely to be salvageable. It is also possible that the print-head has cooked, but they are usually more expensive the just replacing the machine.
1/11/2015 8:26:06 PM • Canon Pixma... • Answered on Jan 11, 2015
Could an aftermarket ink cause a malfunction in a MG5220
No. Aftermarket ink should cause no actual problems with your printer. The printer may not sense that the ink cartridge is full, but that's a minor thing to put up with considering the ink savings. Also, aftermarket ink DOES NOT void factory warrenties.
1/8/2015 8:07:01 PM • Canon Pixma... • Answered on Jan 08, 2015
Canon Pixma MG5220 InkJet Printer Logo
376 questions posted
Clive
Clive
old marine
old marine
View Most Popular
PIXMA Canon
  • PIXMA Canon
Most Popular Question
canon mg5220 printer won 39 t print
  • Office Equipment & Supplies
