20 Most Recent Oracle 10g Database Standard (ODBSEONUPP0) Questions & Answers
sdf databases. You can then select the data you wish to convert, and either copy and paste into a new Excel spreadsheet (. xls), or use the program's "Export Selected Data" function to save the data directly as an . xls.
Oracle 10g... | Answered on Mar 07, 2020
Have you tried reinstalling your Quickbooks? From time to time Quickbooks does have errors related to their updates. The 1st step I would suggest is back up your company data file, and then uninstall, shut down, and then reinstall. Then you can import your data file back into Quickbooks. This should resolve your issue.
Oracle 10g... | Answered on Sep 06, 2019
LDF - layered data file, is the transaction log file for your database. It allows you to roll back changes you made to the data to a particular point and is used in rebuilding the data should it become corrupted.
MDF - Meta data file, is your actual data
SDF - Is a sequential data file, a flat file that can be used for compatibility with MS-SQL server, MySQL, etc.
Oracle 10g... | Answered on Sep 28, 2016
It is a special purpose programing language. Computer language you will never use, unless you are into servers or programing type software
Oracle 10g... | Answered on May 17, 2016
Regarding what is .SDF -- A file format that is compliant with the combination of SQL Server 2005 Compact Edition, SQL Server 2005 and Visual Studio 2005 to build, test, deploy, and manage applications for users. Databases of this type can be accessed directly as a datasource, e.g., from Visual Studio 2005, or from SQL Server Management Studio. As such, they can be passed around with programs or projects, although they are mainly used for embedded applications. The file includes all necessary code points to access the data, and so does not require an instance of SQL Server to be installed.
You can create a .SDF file with a software called PocketSYNC. (Although i have never tried it myself, a lot of people claim that this software works like charm. But it is not free)
Oracle 10g... | Answered on Dec 02, 2014
okay people... this is a long one, but I just did it for two units that were having this problem and it worked both times.
The problem is the unit sat on the shelf and doesn't have enough power to operate its charging cycle.
Take an extension cord and plug in the outlet charger while you also plug it into your cigarette lighter... now attempt to charge it (you will hear the familiar alarm). Now, turn on the LED light... after a short time, turn off the light and the unit will begin to charge regularly. You can then use one of the chargers to finish the job.
By doing this you are providing plenty of power to the battery while the light drains it at a slower rate... kinda forcing the battery to condition/cycle; it's just allowing the battery to take the charge. Hope this helps.
Oracle 10g... | Answered on Jun 12, 2013
You may want COUNTIF if you're specifying criteria. For instance, if my prices are found in b3 to b7, here's a formula that will find all those that are less than 6 ($6.00):
=COUNTIF(B3:B7, "<6")
If you're using multiple criteria, such as you want to find all the prices that are greater than $5 and less than $8, the following will accomplish it. (The ABS gives you the absolute value of the result, in case the smaller number is first.)
=ABS(SUM(COUNTIF(B3:B7, ">5") - COUNTIF(B3:B7, "<8")))
Oracle 10g... | Answered on Oct 23, 2012
pls send me reply for this how to work tally 4.5 xp
Oracle 10g... | Answered on Dec 09, 2011
The .sdf or standard data file is used for storing data in a structured format; uses fields of fixed lengths to store values; can be imported and exported by various database and data analysis programs; commonly used for transferring data between different programs.
Oracle 10g... | Answered on Sep 03, 2011
ring up the lockal microsoft call center and you may get it from them. just follow the promps
Oracle 10g... | Answered on Mar 20, 2011
this will be close:
SELECT ROUND( (SYSDATE - DOB)/365.24,0) FROM MYTABLE;
Oracle 10g... | Answered on Dec 16, 2010
if you have cd, then install manually otherwise proceed online install which ever is easier for you! have fine!
Oracle 10g... | Answered on Dec 17, 2009
http://filext.com/file-extension/SDF , you will find here info about a .sdf, it has more meanings
Oracle 10g... | Answered on Oct 28, 2009
Does it connect after the error ?. First try to connect from your client to Oracle server using SQL plus client.
Second - Do a tnsping <server name>
This will give you the correct Host name, SID and Port number.
Make sure that your JDBC connection parameters match with the actual connection from TNS output
Oracle 10g... | Answered on Sep 27, 2009
If it is not supported in XP, then you should change your operating system or change the version of Tally that matches the system you already have.
Oracle 10g... | Answered on Aug 22, 2009
You can probably use the key (top-left of your key-board) Esc (or "Escape"). If that doesn't work try "End".
Oracle 10g... | Answered on Jul 26, 2009
Oracle 10g Database Standard (ODBSEONUPP0) Logo
Popular Tags
59 questions posted
Top Oracle Computers & Internet Experts
STEVE SPAM REMOVER
JonSnell Electronic
JonSnell Electronic
John Walker
John Walker
Are you an Oracle Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Oracle Computers & Internet
Most Popular Question
whst difference between mdf ldf amp
  • Computers & Internet
