20 Most Recent
Canon A3300 IS Digital Camera Questions & Answers
On?Off switch failure
Not sure the A3300 has two AA sized batteries, but if it had:
Sure your batteries are still tip top?
Try two new AA sized NiMH rechargeable batteries or if you have some new alkaline batteries, put them in. the alkaline batteries won't last long, but it it could hint if the camera is still working and worth buying new rechargeables.
AA manganese (Zinc-Carbon) batteries cannot be used with this camera.
But even if it has one battery, check the battery.
Read other parts about batteries, in other help text I wrote for other users.
Lens error
Remove the battery and put it back in and restart.
Canon A3300 IS lens wont go in or out
take both your fingers lightly push both sides of the lens till its completely in and the lens closes then turn back on it should work I just did this fixed one that was dropped in about 5secs
I have a Canon Power
If you can see past photos on the lcd screen then its probably the ccd that damaged .
It should be still under warranty.
I have a new Canon
Insert the card into a card reader and format it on the computer. See if that works. Format using FAT32 as its more reliable than the FAT it uses by default. If the camera supports FAT32 you can expect it to last atleast a year before you need to format it again
My Mac will not install
This must be because you have a widescreen monitor or because you have set a screen resolution that's too low for anything.
Most programs ask for a screen resolution higher than 1024x768 (which they rarely actually need) to install.
So you can change yours to that value (or higher) for the installation and if it distorts your display, set it back to the original value later.
To see how to change your resolution, go to this site;
http://www.ehow.com/how_2064940_change-display-resolution-mac-osxchange-display-resolution-mac-osx.html
After setting the resolution to 1024x768 or higher, run the installation and it should proceed with no problems.
Canon 12x36 is ii stabilization is not working properly. Stabilization
tends to want to stray.
Hello, I think dust, smudges, or fingerprints on the lenses can affect image quality and stabilization performance. Use a soft, lint-free cloth or lens cleaning solution to gently clean the lenses of your binoculars. Make sure not to apply excessive pressure or use abrasive materials that could scratch the lens surface. Moreover, when using image-stabilized binoculars, it's important to hold them steadily and avoid sudden movements. Rest your elbows on a stable surface or use a tripod if possible to minimize hand tremors. Ensure that you're using proper stabilization techniques to maximize the effectiveness of the stabilization feature.
