20 Most Recent
Kidde Firex 21007624 Ac Carbon Monoxide Smoke Alarm Questions & Answers
I have two firex smoke and carbon dectectors, and 3 smoke detectors in bedrooms.
do they beep three times, pause then beep three times again? if so, they are going into alarm. since they all ring together, the only way to tell which one is causing the problem is to look for one where the leds are different than the others. If your detectors are more than 10 years old, replace them all as required by the national fire code (NFPA72). If they are only doing single chirps, that is usually an indication of a low battery...perhaps the breaker for the circuit has tripped causing them to run on battery only. good luck
Are there any reported problems
I do not know of any reported problems specific to the Kidde CO/smoke alarm, but I spent a significant part of my career servicing toxic gas sensors and can give you some general advice:
1- Most important: treat an alarm as a REAL alarm and DO NOT suspect that your alarm is a "false alarm". My experience has been that most "false alarms" ARE REAL and the source needs to be identified! With Carbon Monoxide detectors, it is usually a blocked vent for a gas fired appliance- a hot water heater, furnace, or oven. Call your fire department or a service professional to make sure that there is no carbon monoxide. They have portable detectors that will be able to double check your alarm.
My advice to you at this moment is to act as if you have a real alarm condition and do not place you or others in a life threatening situation. Ventilate the room/ apartment/house IMMEDIATELY!
I will post more after I send this because you may be in a life threatening situation!
Co2 detector
Check to see if the unit has a replaceable battery. If not, you will likely find instructions on front or back that tell you exactly what the beeping means.
11/19/2014 11:00:35 PM •
Kidde Home
Answered
on Nov 19, 2014
Smoke detector keeps chirping after battery is
The chirp means the battery you chose wasn't good enough... it has to be the newest '''alkaline''' you can get hold of. If it isn't alkaline that's why you are having trouble. Upon replacement press the button to do a hard reset.
10/16/2013 2:20:53 AM •
Kidde Home
Answered
on Oct 16, 2013
What are the different types of powder coating?
Thermoplastic and thermoset are the two types of powder coatings used by leading
Powder coating services. Thermoplastic coating don't undergo any chemical change when heated. Therefore they can be softened and hardened by heating repeatedly. Unlike thermoplastic coatings thermoset coatings changes into infusible materials on heating. Nylons and vinyls are thermoplastic while acrylics and polyesters are thermoset.
4/24/2024 12:02:34 PM •
Home
Answered
Yesterday
What is a meat tenderizer?
This is used to tenderize meat before you cook it. It makes the meat easier to chew and digest. You can also use it before you boil or fry meat. You can do this mechanically, with something like a meat mallet that cuts up the meat fibres. You can do it thermally by putting the temperature really high to break down the connective tissue of the meat. The last method is enzymatic and uses enzymes to break down the collagen. This method is either slow with dry-aging the meat or you can use fruit to marinate the meat.
4/16/2024 6:28:01 AM •
Home
Answered
on Apr 16, 2024
Lost half of my jets on one side of the tub only.I have tried closing the jets that do work half,does not make a difference to the jets not working.Would it be best to empty the tub and start over?
it's likely due to an air lock. Here's what you can do to resolve this issue:
Manually Clearing an Airlock:
Run the jets on low for about 30 seconds.
Then run the jets on high for another 30 seconds.
Repeat this process 3 or 4 times.
If you hear a gurgling sound and see air bubbling up, continue running your hot tub until it pushes all the air out.
If this doesn't work after several attempts, try a different approach.
Bleeder Valves or Pump Method:
Some spas have bleeder valves that allow you to bleed air out of the lines.
First, turn off the spa at the breaker.
Access the pump and loosen the valve to allow the air to escape.
When the air has bled out (you'll notice it turns from hissing air to a stream of water), close the valve.
Run the pump to ensure the jets are now pumping water as expected.
Why Are the Jets Not Working on One Side Only?:
Many hot tubs have two water pumps.
If the jets on only one side of your hot tub stop working, there could be an airlock in only one of the pumps.
It could also be a blockage in the jet lines for that side or a problem with the internal mechanism of the jet itself.
Can You Use a Spa with an Airlock?:
It is not recommended to use a hot tub with an airlock.
4/3/2024 4:33:08 AM •
Home
Answered
on Apr 03, 2024
Restarting my marcel hour strike quartz clock nrms603.
To restart your Marcel Hour Strike Quartz Clock NRMS603, follow these steps:
Stop the Pendulum: Gently stop the pendulum from swinging by holding it still.
Remove the Battery: Open the clock case and locate the battery compartment. Remove the existing battery.
Wait for a Minute: Leave the clock without a battery for about a minute to allow any residual charge to dissipate.
Insert a New Battery: Insert a fresh battery into the compartment, ensuring the correct polarity (usually marked on the battery holder).
Start the Pendulum: Gently release the pendulum and let it start swinging.
Set the Time: Use the clock's time-setting knob or buttons to adjust the time to the correct hour and minute.
Your clock should now be restarted and keeping time accurately
4/3/2024 4:30:05 AM •
Home
Answered
on Apr 03, 2024
