20 Most Recent Traulsen Freezer Refrigeration 4 - 1/2 Door ''G Express Series'' Upright Reach-In Commercial Freezer Questions & Answers
Freezer wont freeze
HI,
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
  • Is the refrigerator completely dead? If so, see “It's stopped completely.”
  • Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush (see the Appliance Accessories section) and your vacuum cleaner to clean the coils of any lint, pet hair, etc. You may not be able to get to all of the condenser from the front, it may be necessary to clean the remainder of the condenser from the rear of the refrigerator.
7/3/2009 3:55:03 PM • Traulsen Freezer... • Answered on Jul 03, 2009
Traulsen 6 half door moel 31300 freezer
To check if the expansion valve is faulty in your freezer, you can follow these steps:
  1. Safety Precautions: Ensure the power is disconnected and the freezer is fully defrosted before proceeding.
  2. Locate the Expansion Valve: The expansion valve is typically located near the evaporator coil in the freezer. It is a small valve with an inlet and outlet.
  3. Visual Inspection: Inspect the expansion valve for any visible signs of damage or leaks. Look for corrosion, loose connections, or frost accumulation around the valve.
  4. Temperature Measurement: Use a thermometer to measure the temperature at different points in the refrigeration system. Check the temperature at the inlet and outlet of the expansion valve. There should be a noticeable temperature drop across the valve.
  5. Pressure Measurement: If you have the necessary tools and experience, you can also measure the pressure at the inlet and outlet of the expansion valve using a pressure gauge. Compare the pressure readings to the manufacturer's specifications to determine if the valve is functioning properly.
  6. Consult a Professional: If you are unsure about performing these checks or don't have the necessary tools, it is recommended to contact a professional technician or an authorized service center. They will have the expertise and equipment to accurately diagnose and repair any issues with the expansion valve.
6/28/2023 5:23:12 AM • Traulsen... • Answered on Jun 28, 2023
Need to know the age of my Traulsen freezer Model G22000 Serial T78014104
The telephone number of the manufacturer is on their web site. You can call them to request assistance. https://www.traulsen.com/service/owners-manuals I am not typing their phone number here because so many fraudulent1 scammers post on FIXYA, so beware.
3/16/2020 3:45:15 PM • Traulsen... • Answered on Mar 16, 2020
Can a traulsen commercial fridge be changed to a freezer by changing out a thermostat or a set point somewhere?
probably not. you would need to change the expansion device. You could probably get as low as 15-20 degrees but I doubt you could do much more than that without some system changes.
6/19/2017 7:13:41 PM • Traulsen... • Answered on Jun 19, 2017
How do I fix the temperature on my Traulsen Model G22010 freezer: it is at 14 degrees and I want it to be 0 degrees
https://my.hobartcorp.com/resourcecenter/ProductDocumentation/TR35924%20Owners%20Manual%20Quick%20Guide.pdf. Check out page 2 to see if these instructions will help with resetting the control.
2/11/2017 11:09:07 PM • Traulsen... • Answered on Feb 11, 2017
Traulsen freezer with intella true continuously frosting the evaporator coil and blocking the air flow?
Your defrost circuit ... should (about twice each day) gently warm up.. and remove the frost to an evaporation tray at the bottom of your FREEZER (refrigerator?)... Regardless of the design... THERE are only two reasons for excessive FROST. - massive air intrusion (check seals & gaskets) - defective defrost circuit (check defrost timer/controller)... EZ trouble to fix...Post comment reply: 7/3/2016...In general... there are only three elements to the defrost circuit: - 1st failure is usually the "timer" (in your case (other cases it is being replaced by the power control board (do remove power: line voltages present). - 2nd failure (inside ... usually atop the evaporator) is the "DEFROST THERMOSTAT" (designed the keep the heating element from getting much hotter than 55 degrees Fahrenheit, ("failing" = open.. prevents the heater element from being energized at all). - 3rd the heating element... itself goes open (usually below the evaporator (caution: line voltages on 2nd & 3rd)).Anytime you don't feel you've got this surrounded just comment me back... I'll be around. Go to Bing homepage http://www.bing.com/search?q=traulsen+freezer+wiring+diagrams&qs=AS&pq=traulsen+freezer&sk=LS1AS5&sc=8-16&sp=7&cvid=47349AEC29CA4E1D8902F3954D86C0BF&FORM=QBRE&ghc=1
7/3/2016 12:14:19 PM • Traulsen... • Answered on Jul 03, 2016
Solenoid diagram
that sounds like the hardstart relay that energizes the start windings in the compressor . if that or more likely the capacitor fails when it is first energized the compressor will pull excessive amps and cause the overload protector to open until it cools for a minute or two.
5/22/2014 5:40:12 AM • Traulsen... • Answered on May 22, 2014
0answers
0answers
Bad Temperature Controller
you can go to either aJohnstone Supply, United refrigeration, or baker supply, Insco Distributing, refrigeratin hardware supply company( they shio it from eithe dunver or someshere in california
Thank for using FixYa
12/24/2008 5:29:28 AM • Traulsen... • Answered on Dec 24, 2008
How do I remove shelves if they are attached to tubes connected to the back inside of the upright freezer
you do not leave them alone they may have refrigerant flowing through them. look in your owners manual/instructions for more info.
4/14/2024 10:55:01 PM • Freezers • Answered Yesterday
Norfrost C6AEW Chest Freezer. Wiring help please.
Question edited for clarity and add CAPS. It seems to be a common occurrence on that model due to bad design. https://www.fixya.com/support/t17110008-norfrost_c6aew_chest_freezer_compressor Norfrost is owned by Ebac. Contact their customer service. https://www.johnogroat-journal.co.uk/news/caithness-freezer-name-lives-on-in-england-170710/ https://www.ebac.com/support/customer-service Another way would be to study the wiring as it is pretty standard. The video may help. https://www.google.com/search?q=freezer+wiring+diagram You may be able to freeze this video to note the wiring, although this only shows the thermostat wiring and is a bit fuzzy. Also an refrigeration appliance technician would know the wiring by heart and take 20 minutes maximum to work it out.
2/11/2024 5:45:01 PM • Freezers • Answered on Feb 11, 2024
Freezers Logo
1 questions posted
Top Traulsen Freezers Experts
deton8 von Splosion
Douglas Makokha
Level 1 Expert
Are you a Traulsen Freezer Expert? Answer questions, earn points and help others
View Most Popular
Traulsen Freezers
  • Traulsen Freezers
Most Popular Question
freezer wont freeze
  • Freezers
