20 Most Recent
Traulsen 69.1 cu. ft. / 1957 liter Commercial Freezer G31310 Questions & Answers
Not pulling down to temperture
The most common problem is low refrigerant (freon). If you don't have gauges to check the pressure of your refrigerant, do this: the compressor has one small line running to the coils on the top of the freezer. That small line should be hot enough to burn your finger if you touch it when the compressor is running. Also the big copper tube running into the compressor should be cold to the touch, almost freezing. If not you are probably low on refrigerant. Without gauges and the ability to buy freon, you will need to hire a refrigeration repair service to find the leak in your system, repair it and then gas it up. But there are a couple of other things to check first. Near the compressor is a radiator like set of coils in front of a fan. If the compressor is running that fan should be running too. if not, the unit won't cool. Also the radiator coils may be covered with dust or grease. You must have a good flow of air through these coils to dissapate the heat put out by the compressor.If it is stopped up, brush the dust from the front of the coils. Look inside the freezer as well and make sure the inside coils are not frozen over. Is so unplug the unit and let the frost melt off. If that is happening you may need a new timer on your drfrost system.
Freezer Unit Isn't Functioning
Inside the refrigeration system alot is goning on. You have to check the pressures low/high to determine the problem. It is easy to say that your unit needs freon but that is not always the case.
here is a list of possible problems:
dirty condenser
dirty evapoator
fans not working
defrost not working
lost of freon
bad compressor
bad compressor valves
slugging
flooding
lack of oil
super heat off
txv is stuck open/close not sensing
incompatilbe unknown freon mix...
well these are just some of the problems you can encounter. this was meant to tell not fix because each problem needs attention but hope this was a little helpful anyways
Traulsen 6 half door moel 31300 freezer
To check if the expansion valve is faulty in your freezer, you can follow these steps:
- Safety Precautions: Ensure the power is disconnected and the freezer is fully defrosted before proceeding.
- Locate the Expansion Valve: The expansion valve is typically located near the evaporator coil in the freezer. It is a small valve with an inlet and outlet.
- Visual Inspection: Inspect the expansion valve for any visible signs of damage or leaks. Look for corrosion, loose connections, or frost accumulation around the valve.
- Temperature Measurement: Use a thermometer to measure the temperature at different points in the refrigeration system. Check the temperature at the inlet and outlet of the expansion valve. There should be a noticeable temperature drop across the valve.
- Pressure Measurement: If you have the necessary tools and experience, you can also measure the pressure at the inlet and outlet of the expansion valve using a pressure gauge. Compare the pressure readings to the manufacturer's specifications to determine if the valve is functioning properly.
- Consult a Professional: If you are unsure about performing these checks or don't have the necessary tools, it is recommended to contact a professional technician or an authorized service center. They will have the expertise and equipment to accurately diagnose and repair any issues with the expansion valve.
6/28/2023 5:23:12 AM •
Traulsen...
Answered
on Jun 28, 2023
Solenoid diagram
that sounds like the hardstart relay that energizes the start windings in the compressor . if that or more likely the capacitor fails when it is first energized the compressor will pull excessive amps and cause the overload protector to open until it cools for a minute or two.
5/22/2014 5:40:12 AM •
Traulsen...
Answered
on May 22, 2014
Bad Temperature Controller
you can go to either aJohnstone Supply, United refrigeration, or baker supply, Insco Distributing, refrigeratin hardware supply company( they shio it from eithe dunver or someshere in california
Thank for using FixYa
12/24/2008 5:29:28 AM •
Traulsen...
Answered
on Dec 24, 2008
