20 Most Recent Traulsen 46 cu. ft. / 1303 liter Commercial Freezer G22010 Questions & Answers
2answers
Looking for a wiring diagram for a GLT-2-32
1. Freezer coil must be cold enough to deactivate fan delay control.
7/20/2012 2:40:34 AM • Traulsen 46 cu.... • Answered on Jul 20, 2012
I need to set the
Hi.
To download the manual Register with Hobart/Traulsen resources website.
Once you have an account sign-in and open the resources tab on this page.
Regards.
Ginko
9/8/2011 2:39:49 PM • Traulsen 46 cu.... • Answered on Sep 08, 2011
How can I get the wiring schematic diagram
call traulsen at 1-800-825-8220. Get tech support and give them the model and serial numbers. They will send you a diagram. Nothing on their web site.
6/26/2010 5:16:21 AM • Traulsen 46 cu.... • Answered on Jun 26, 2010
Traulsen 6 half door moel 31300 freezer
To check if the expansion valve is faulty in your freezer, you can follow these steps:
  1. Safety Precautions: Ensure the power is disconnected and the freezer is fully defrosted before proceeding.
  2. Locate the Expansion Valve: The expansion valve is typically located near the evaporator coil in the freezer. It is a small valve with an inlet and outlet.
  3. Visual Inspection: Inspect the expansion valve for any visible signs of damage or leaks. Look for corrosion, loose connections, or frost accumulation around the valve.
  4. Temperature Measurement: Use a thermometer to measure the temperature at different points in the refrigeration system. Check the temperature at the inlet and outlet of the expansion valve. There should be a noticeable temperature drop across the valve.
  5. Pressure Measurement: If you have the necessary tools and experience, you can also measure the pressure at the inlet and outlet of the expansion valve using a pressure gauge. Compare the pressure readings to the manufacturer's specifications to determine if the valve is functioning properly.
  6. Consult a Professional: If you are unsure about performing these checks or don't have the necessary tools, it is recommended to contact a professional technician or an authorized service center. They will have the expertise and equipment to accurately diagnose and repair any issues with the expansion valve.
6/28/2023 5:23:12 AM • Traulsen... • Answered on Jun 28, 2023
Need to know the age of my Traulsen freezer Model G22000 Serial T78014104
The telephone number of the manufacturer is on their web site. You can call them to request assistance. https://www.traulsen.com/service/owners-manuals I am not typing their phone number here because so many fraudulent1 scammers post on FIXYA, so beware.
3/16/2020 3:45:15 PM • Traulsen... • Answered on Mar 16, 2020
Can a traulsen commercial fridge be changed to a freezer by changing out a thermostat or a set point somewhere?
probably not. you would need to change the expansion device. You could probably get as low as 15-20 degrees but I doubt you could do much more than that without some system changes.
6/19/2017 7:13:41 PM • Traulsen... • Answered on Jun 19, 2017
How do I fix the temperature on my Traulsen Model G22010 freezer: it is at 14 degrees and I want it to be 0 degrees
https://my.hobartcorp.com/resourcecenter/ProductDocumentation/TR35924%20Owners%20Manual%20Quick%20Guide.pdf. Check out page 2 to see if these instructions will help with resetting the control.
2/11/2017 11:09:07 PM • Traulsen... • Answered on Feb 11, 2017
Traulsen freezer with intella true continuously frosting the evaporator coil and blocking the air flow?
Your defrost circuit ... should (about twice each day) gently warm up.. and remove the frost to an evaporation tray at the bottom of your FREEZER (refrigerator?)... Regardless of the design... THERE are only two reasons for excessive FROST. - massive air intrusion (check seals & gaskets) - defective defrost circuit (check defrost timer/controller)... EZ trouble to fix...Post comment reply: 7/3/2016...In general... there are only three elements to the defrost circuit: - 1st failure is usually the "timer" (in your case (other cases it is being replaced by the power control board (do remove power: line voltages present). - 2nd failure (inside ... usually atop the evaporator) is the "DEFROST THERMOSTAT" (designed the keep the heating element from getting much hotter than 55 degrees Fahrenheit, ("failing" = open.. prevents the heater element from being energized at all). - 3rd the heating element... itself goes open (usually below the evaporator (caution: line voltages on 2nd & 3rd)).Anytime you don't feel you've got this surrounded just comment me back... I'll be around. Go to Bing homepage http://www.bing.com/search?q=traulsen+freezer+wiring+diagrams&qs=AS&pq=traulsen+freezer&sk=LS1AS5&sc=8-16&sp=7&cvid=47349AEC29CA4E1D8902F3954D86C0BF&FORM=QBRE&ghc=1
7/3/2016 12:14:19 PM • Traulsen... • Answered on Jul 03, 2016
Solenoid diagram
that sounds like the hardstart relay that energizes the start windings in the compressor . if that or more likely the capacitor fails when it is first energized the compressor will pull excessive amps and cause the overload protector to open until it cools for a minute or two.
5/22/2014 5:40:12 AM • Traulsen... • Answered on May 22, 2014
0answers
0answers
Traulsen 46 cu. ft. / 1303 liter Commercial Freezer G22010 Logo
7 questions posted
Top Traulsen Freezers Experts
deton8 von Splosion
Douglas Makokha
Level 1 Expert
Are you a Traulsen Freezer Expert? Answer questions, earn points and help others
View Most Popular
Traulsen Freezers
  • Traulsen Freezers
Most Popular Question
looking wiring diagram glt 2 32
  • Freezers
