20 Most Recent Master Lock 1590D Set-Your-Own Combination Lock, Steel, 1 7/8"Wide, Assorted Questions & Answers
had your looking for a combo, throw it out. no way to find the combo for it. serial only refers to the model of the lock. its like asking for a part for " my ford truck " not enough info.
Master Lock... | Answered on Jan 02, 2013
If you remember the first letter/number you're still in luck. What you need to do is start off with that letter. If you know what you tried to set, ex. ATE
Work with
A
A, D, E, H, J, L As for the last number/letter, all you have to do is keep spinning it right and you will hit it.
For me, I tried fooling around and setting ALT
However, when I was entering the new combo, I turned 3times or more right when key was in to A, then a full circular left turn past A to L. From L, I turned the same direction 4 clicks to T and locked it. I realized I entered it wrong when I locked it. How these locks were designed isn't that complicated. It consists of 3 different turns. Right, left, right. Right to A, left to L, right to T. When I had entered, right to A, left to L, and left again to T. It automatically makes the second letter/digit the same as your first letter/digit. I cracked my lock trying all combinations of A,L,T. Writing a list helps. But I also suggest your write down a list of your first digit twice.
A, A, L A, L, A
A, L, T A, A, T (That's what my code was after incorrectly trying to set it as "ALT")
However, this is only one method. When I had purchased the lock a year ago and set a combination. I approached it with a different method. The first one as I mentioned. I had tried to set EAT to test. The combo ended up being a letter or two off in the combo itself. So my cracked combo was not EAT but something _AT or EA_ or E_T. Combos usually aren't off by a whole lot. I was going to throw my lock away and buy a new one, but I cracked it :) I know this is alot about my own experience, but don't give up! I was planning on solving it, but I did it within 10mins! Not so tough !
Master Lock... | Answered on Sep 04, 2011
  • Set your own combination using 3-letters or numbers or a mix of both
  • Combination easy to change with included reset tool
  • Maximum security with anti-shim feature
  • Hardened steel shackle for increased bolt cutter protection
  • High precision dial clicks for fast accurate dialing
Master Lock... | Answered on Aug 16, 2011
Sorry, I don't think there is a remedy, but you could try removing it, and reinstall again.
Master Lock... | Answered on Apr 21, 2011
Hey, Mine did the same thing, this is what I did. I entered "0000" for the pin and was able to reset the unit (0000 is the factory default) It may not work for you, but it's worth a try.
Home Security | Answered 23 hours ago
Changing combinations can be done from the reset button. It exists at the topmost part of the device. To reset - Hold it down for a few seconds until the light indicates green, release and enter your new preferred code. Repeat the procedure until the light goes red and re-enter the new code. Then repeat for a third time until the light gives you five blinks. TO know A depth review about this product You much visit here: Bulldog Cases Car Safe with Key Lock Review
Home Security | Answered Yesterday
http://www.promet-safe.com/Instruction_for_BST_fire_safes.PDF
Heres a link to a manual I found online! Good Luck!!!
Home Security | Answered on Jan 18, 2021
yes, such a product does exist
Driveway Patrol Infrared Wireless Alert System: Amazon.ca ...
www.amazon.ca > Driveway-Patrol-Infrared-Wireless-S...
The Driveway Patrol Infrared Wireless Alert System keeps you aware of intruders or visitors anywhere around your home. This amazing system is wireless so you ... Rating: 4.1 · ‎118 reviews
Driveway Patrol Garage Motion Sensor Alarm Secure System ...
www.amazon.ca > Driveway-Patrol-Garage-Wireless-In...
Product description. This wireless driveway alarm system employs advanced infrared motion detection technology. When someone approaches, it sends a signal ...
Safety Driveway Patrol Infrared & Wireless Home Security ...
www.walmart.ca > Safety-Driveway-Patrol-Infrared-Wi...
Description. ; Battery Powered Wireless Driveway Alarm System uses a new smaller infrared PIR Sensor that detects people and cars up to 20 meters away and ...
Home Security | Answered on Jan 15, 2021
Master Lock 1590D Set-Your-Own Combination Lock, Steel, 1 7/8"Wide, Assorted Logo
22 questions posted
Top Master Lock Home Security Experts
ray gallant
john h
Andrew Taylor
Andrew Taylor
Are you a Master Lock Home Security Expert? Answer questions, earn points and help others
View Most Popular
  • Master Lock Home Security
Most Popular Question
found old masterlock combination lock
  • Home Security
