20 Most Recent
HTC Evo Shift 4G (2 GB) Smartphone Questions & Answers
How can I delete an Adobe pdf file?
Open the file manager (install Astro File Manager from the market if there isn't one installed). Navigate to where the pdf file is. Tap and hold on it until the menu comes up and select Delete. Hope this helps.
Ray
My evo shfit is cracked
The only way you can get that fixed is if you return it to the store, have warranty or insurance on it and get a new one. Can't do much for cracked screens :/
What do you do if lotion gets in your touch screen and it stops working
1. Gently wipe the display with a dry, lint-free, soft cloth. If you see a scratch-like mark on your display, it might be a stain transferred from the keyboard or the TrackPoint pointer when the cover was pressed from the outside.2. Wipe or dust the stain gently with a dry, soft cloth.3. If the stain remains, moisten a lint-free, soft cloth with water or a 50-50 mixture of isopropyl alcohol and water that does not contain impurities.4. Wring out as much of the liquid as you can.5. Wipe the display again; do not let any liquid drip into the computer.6. Dry the display before closing the lid.
How to enable pattern unlock on HTC shift
You directed this question at me, but unfortunately I'm unable to provide you with a real solution at this time.FixYa has discontinued direct questions, so if you would care to repost your question, the repost will be visible to all members of the FixYa community. Hopefully one of them will be able to provide you with a real solution.Thank you for using FixYa.
My phone wont turn on and when I try to charge it,
First thing to do is try to replace battery for a test,usually when phone is often used,it can easily discharge like using wifi or any,then simultaneously charger is plug in.this will damage the battery and can be easily drained.
I want to flash my htc evo shift to a different
When Unlocking, always use a unlock code - This method is the simplest and safest method to unlocking your phone. You can hook it up to servers; I would suggest code is if want to pay less (take the risk of trouble) on older models. New phones cannot be unlocked by software.
give your IMEI number & get the unlock code for ur mobile .......... you also get through online..........i will suggest the website
Unlock-Zone.com/ which is doing good service .....you can approach this website.
What is the Telus network unlocking code for an htc phone
Only Telus can unlock it and only if the rent to own contract is paid off. If you take it to a third party unlocker, Telus can still lock it on you by using the IMEI number.I would urge you to edit out your IMEI number as it can allow the unscrupulous to clone your phone and make calls at your expense.
