20 Most Recent HEWLETT-PACKARD HP Compaq Presario CQ62-410US Notebook Questions & Answers
Help on startup error message System Fan (90)
You should be able to feel the far blowing warm air. You could take the back off the laptop and clean the dust out of the fan and heat exchanger.
4/9/2019 3:58:27 PM • HEWLETT-PACKARD... • Answered on Apr 09, 2019
2answers
Hi, I bought my Compaq
hold f2 on startup and select accounts and change permissions
4/23/2017 12:13:24 PM • HEWLETT-PACKARD... • Answered on Apr 23, 2017
I have a HP Presario CQ62 laptopo and I would put it as whennit came from the factory.What do I do?
read this http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01867418&cc=us&dlc=en&lc=en
10/28/2014 9:31:56 PM • HEWLETT-PACKARD... • Answered on Oct 28, 2014
Why cann't I get on facebook on my laptop
Try to reset your internet explorer settings back to default. By performing this procedure will erase any particular settings on your browser and set it back to default settings. On Internet Explorer go to Gear (tools) - Internet Options - Advanced - Reset - mark "Delete personal settings" and press reset Close and open back IE and see if it works. If you are still unable to access facebook your machine might have a malware preventing access to facebook.
10/18/2014 6:01:36 AM • HEWLETT-PACKARD... • Answered on Oct 18, 2014
No Stereo Mix
Have you checked the device manager? It may be disabled as mine was. You my also need to go to the web site of you mixer an get an update. Updates sometimes are needed with updates
3/26/2014 4:10:56 AM • HEWLETT-PACKARD... • Answered on Mar 26, 2014
How do i dry out a compaq keyboard from coffee?
If you can remove the keyboard,lift it off carefully. With a Q-tip dipped in alcohol, wipe the coffee spots clean. It dries rather quickly. replace keyboard. Should be as good as new. GOOD LUCK
7/2/2012 5:22:05 AM • HEWLETT-PACKARD... • Answered on Jul 02, 2012
No sound
check sound driver if presently installed if not try to installed the sound driver
7/27/2011 1:53:34 AM • HEWLETT-PACKARD... • Answered on Jul 27, 2011
I have encountered a problem
Most likely you will have problem trying to install windows XP in a windows 7. It is better to use a virtual machine on your windos 7 instead. Windows XP mode will not work on a Home edition of Windows 7. you can download the Virtual machine in this link: http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=4580
Once you have downloaded and install this run it. then install the XP on this mode by -run the virtual machine -go through the setup -insert the installation disk -wait for the installation is complete
Then every time you will run the virtual machine it will go to the XP that you installed.
hope this helps
6/27/2011 1:39:05 PM • HEWLETT-PACKARD... • Answered on Jun 27, 2011
2answers
When I try to download into quicken the documents page comes up. How do I correct this situation?
If your bank statement is not in the Quicken format, you cannot do that. Best see if it will download into MS Excel. If not, get in touch with the Bank
10/19/2022 4:47:44 AM • HEWLETT-PACKARD... • Answered on Oct 19, 2022
3answers
Back Slash on HP keyboard ProBook
Try now~ Then you can reset your keyboard if you like
5/4/2022 2:32:08 PM • HEWLETT-PACKARD... • Answered on May 04, 2022
HP G72-253NR Laptop - Using an External Keyboard
I think you have a broken USB keyboard or USB port. Simply plugging in the keyboard should be enough to make it work. First try the keyboard in a different USB port. Test the caps lock to see if the LED goes on and off. Also try a different keyboard and also test it in a different computer.
1/31/2019 6:37:16 PM • HEWLETT-PACKARD... • Answered on Jan 31, 2019
Pano pag ang laptop sa HP ay hindi na mag on pero meron syang power?
please use English, ok?
10/30/2018 1:04:04 PM • HEWLETT-PACKARD... • Answered on Oct 30, 2018
3answers
User manual Hewlett-Packard G2 tablet or the instruction booklet
https://support.hp.com/us-en/product/hp-10-g2/8223709/model/9078231/manuals
this is the manual pdf just download it
10/1/2018 11:15:14 AM • HEWLETT-PACKARD... • Answered on Oct 01, 2018
2answers
My Hewlett-Packard w2207 monitor is showing no input signal when I power it on what does that mean and how can I fix it
1) Reset your computer. 2) Unplug the cable from the computer to the monitor and check to see if its damaged, if OK plug it back in. 3) On windows computer, click windows key / windows system / control panel / device manager / display adapters (click on icon) / Update driver
5/1/2018 3:23:11 PM • HEWLETT-PACKARD... • Answered on May 01, 2018
HP A6519FH Black Screen Issue: I
what computers.?? 1000's of models over 30 years. made F10 is BIOS screens, so if that works, BIOS. and any screen then the PC is not booting. try booting to CD? *(a free linux live cd?) as a test. if that works run HDD tests. next ill stop here, if you can get this far, we go to next step F11 HDD reload the OS, if PC is 2006 or newer from HP.
2/1/2018 12:20:26 PM • HEWLETT-PACKARD... • Answered on Feb 01, 2018
Ce 3700, no model HP stated
Try again with the model number
1/30/2018 12:32:03 PM • HEWLETT-PACKARD... • Answered on Jan 30, 2018
My laptop hp compaq 6715s, the battery is charging
what is a device? did you mean PC, a collections of devices and chips:? a PC Is not a DEVICE it is a system.(or machine) why in the world not buy a new battery first? if charging fails. mine sometimes go bad even 1 year old, when I abuse it. and I fully expect that, if you read the battery makers pages, youd learn how that happens' (cycling the snarf out of it) if i remove the word DEVICE and add LAPTOP OR PC THE ANSWER IS THIS. IF the Pc does not run with the battery (main big) out ! the power pack is bad. the PC will run forever on AC power, a fact, !!! I do so all the time, or even the wrong AC pack used, (mixed up with other pc:) get a new pack, get one matching your systems, needs (watts) the laptops can come with 5 processor options and 4 graphic chip options, the worse mix is 100watts, HP will tell you that match. but only if YOU tell your full service tag data.... that magic, nnnnnnnABA# number tells the HP pro what is inside this laptop and what power park is right or just buy the 19v, 100watt pack. here is real HP, fixya is NOT. they can match you up as can the hp PARTS SURFER, https://h30434.www3.hp.com/
1/24/2018 1:56:50 PM • HEWLETT-PACKARD... • Answered on Jan 24, 2018
2answers
How to fix the sound of HP pavilion dv6345us
sure, get the Correct HP driver for this exact pc but, but but...The windows sounds are dead. (do that yet>, CP + sound test)CP = control paneltry to know , most HP made, dv6345us, can have 3 sound chips as an option day 1 new!what you have is clearly stated in the service tag that you did NOTpost, the number ending in ABA# is THAT number.the chip and PC and the unstated OS all must matchwindows what? you never said so i cant match that either.VISTA????????? vista 32 bit or 64????????but the other way is what, sure, guess.read the drivers at HP and try all there.for sound chips (aka audio)This HP computer is 11 years old. now. (2007)HP dropped most support on it this old, (SOP) one sound chip is Conexant AC -Link Audiolets say you said (service tag) RV214UA#ABAand you said VISTA> what works there.the secret is deep, lacking full spec, from HP.finding Conexant drivers is not easy, lots of hits all virus sites now.lets first look .does device manager show it as bad.CP+DM see sound there. is it red, yellow or Unknown marked.go to CP again control panelclick sound is the Conexant still there.the window for sound has a speaker is it selected?select speaker then properties lower right.then pick enhancementshit checkmark, disable all sound effectsclick tab levels, turn up volume.can you do all that, i bet not, its got bad drivers for this chipVISTA btw is dead so asking MS to update driver is dream of dreams, hopeless, now and for sure forward.you dont have the HP install disks so that source too is missing.,leaving you , VISTA and MS and HP and conexant in the lurch.if microsoft was not dead and your internet was alive (is it)the remove the driver, and reload, it under device manager.it then magically PnP reloads from MS but not if the MS driver servers are off line as they sure are. (1/2 or all) (ms secret this is)Hard this is,::::, 1ST OFF, is HP ended support,ON YOUR PC NOW.2nd VISTA support has ended at MS. (double dead)3rd factor (bad) IS Conexant maker of chip and their Driver. IS DEAD. TRIPLE DEAD.SHORT WHY>?synaptics Bought out Conexant in 2017, and shows no support NOW. FOR THAT. the Snaptics web site lists nothing on the words driver or conexant. zero support, but do call them,,,? SO that ends that foray. leaving all those malwares sites offering this driver, only. ? many we can find it this magical way. the FAMOUS DRIVER PACKS site. (all safe ask) the one place on earth with no malware is here.this is the vista set 32bit only 64 is on other pagethere are 15 drivers for Conexant. there. get them try them.end storyhttp://driverpacks.net/driverpacks/windows/7/x86/audio/11.11
1/5/2018 4:29:57 PM • HEWLETT-PACKARD... • Answered on Jan 05, 2018
HEWLETT-PACKARD HP Compaq Presario CQ62-410US Notebook Logo
15 questions posted
Top HEWLETT-PACKARD Computers & Internet Experts
Paul Bade
Grand Canyon Tech
Grand Canyon Tech
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HEWLETT-PACKARD Computers & Internet
Most Popular Question
help startup error message system fan 90
  • Computers & Internet
