20 Most Recent RCA RP3720 Clock Radio Questions & Answers
This is a very excellent
12/17/2017 9:02:07 PM • RCA RP3720 Clock... • Answered on Dec 17, 2017
Don't have a manual for my RP 3720A clock
Copy of the user manual can be downloaded from this link, just click HERE.
9/23/2011 7:04:26 PM • RCA RP3720 Clock... • Answered on Sep 23, 2011
Snooze set to 1 minute
First, move the slide switch at the left rear of the top of the unit all the way to the right. You'll see the colon blinking, indicating that you are in 'set' mode. Now turn the dial that surrounds the ON/OFF button on the top of the unit. You can move it clockwise or counterclockwise, to change the time forward or backward. When done, move the slide switch back to the far left. Done.
4/23/2010 6:43:17 PM • RCA RP3720 Clock... • Answered on Apr 23, 2010
RCA RP3720 Light Problems
I need help with this as well.
7/12/2008 4:13:25 AM • RCA RP3720 Clock... • Answered on Jul 12, 2008
How do I hook up RCA home stereo receiver to RCA SP9978AW
Question edited for clarity. Presumably the letter 't' on its own was supposed to be 'to'. The model number refers to a Sub Woofer. https://www.google.com/search?q=rca+sp9978aw+manual You should also search the receiver which you give no clue. make model manual https://www.google.com/search?q=rca+%28receiver+model%29+manual ..
11/9/2022 11:30:52 PM • RCA Audio... • Answered on Nov 09, 2022
My sister gave me her old RCA boombox I need the manual for it the model # is RP7958A
Hi, Please call RCA and ask them to email you the manual please. You can use this phone number to reach them (800) 968-9853. Thank you.
9/26/2022 5:00:38 PM • RCA Audio... • Answered on Sep 26, 2022
2answers
Got an ONN TV and an ONN soundbar. Hooked up via RCA cable. TV audio in PCM mode. Soundbar in AUX mode. Can't get any sound from soundbar. What have I missed?
PCM mode is a digital audio file that should be sent to the soundbar via an optical or coaxial digital audio cable. The coaxial digital audio cable uses an RCA plug but not the L/R stereo channels of analog audio. The aux input is usually the 3.5 MM cable from a computer, CD or MP3 player or a cell phone or tablet. First, which type of RCA cable is connected between the sound bar and the TV? Second, are you sure that the TV connection is an audio out? (A number of recent TVs have only one audio output. This means there is only the optical audio out and not even a headphone jack.) Once you double-check the input at the sound bar, choose the Line In input if you are using the stereo RCA cable. If you are using the Optical input, select that input. Use either the Mode button or the specific input button on the remote. Then double-check that the TV is set for the appropriate audio out. I hope this helps. Please add a comment with the model of the TV and the sound bar for further information. I looked at the ONB18SB001 documentation for some of this. The manual for this Onn soundbar is available at Manuals Lib. See https://www.manualslib.com/manual/1498038/Onn-Onb18sb001.html?page=12#manual for the list of input modes and the input to which they correspond. Here is the image of the inputs on the back of the ONB18SB001: https://www.manualslib.com/manual/1498038/Onn-Onb18sb001.html?page=7#manual . Cindy Wells
9/8/2022 7:23:00 AM • RCA Audio... • Answered on Sep 08, 2022
2answers
Detailed instructions to download music to a RCA MP3 Player, M62 series?
download the audio converter and then covert the music to the format u want.....................
8/24/2022 3:29:39 AM • RCA Audio... • Answered on Aug 24, 2022
I boiught an RCA MP3
MP3 players can only play music files in mp3 file format. You can download mp3 music files off the Internet, some WEB sites charge a fee for music downloads. OR
You need to convert your CDs to mp3 music files onto yourcomputer or download them from the Internet and then copy them to your MP3player.
You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.
Click on this link for instruction on converting music files to mp3 file format:- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
8/24/2022 3:24:33 AM • RCA Audio... • Answered on Aug 24, 2022
Speaker volume is too low in my turntable setup. How can I fix it?
remove rca plugs from speaker wires and wire the speakers to speaker connections on the back of receiver. The receiver may already have a phono input for a turntable.
8/10/2022 12:55:44 AM • RCA Audio... • Answered on Aug 10, 2022
Hi good morning allof you"My marantz avp 8802a sub out 1 not working properly ones remove rca cable and fit back then sub work ? and it self will shut down after sometime.
so you posted 2 times? why? once = ones? see your other post and read the simple answers. shut down can be overheating makes the AMP is not in some cabinet an zero air flow possible the cooler the amp the longer it last, I have USB fan in my cabnet that is on purpose super quiet, so my amps all run cool. we can not see your system so answers will be hard won or wrong.
7/4/2022 2:06:02 PM • RCA Audio... • Answered on Jul 04, 2022
2answers
I have a Rca S2001 Jet Series Music player. I charged it using my computer. When attempting to turn it on, it would not. When connected to the wall on the charger it will work, but if not it wont.
Do you use the same cable to charge your device on computer and wall socket? If not that might be your problem. It might show that it’s charging but actually there’s no power supplying to the battery. If it is the same cable try another USB socket your motherboard or driver could start causing problems so I would suggest to try the cable you use on the wall socket on another computer if possible.
6/28/2022 7:31:15 AM • RCA Audio... • Answered on Jun 28, 2022
How to hook up technics sh-ge70
Normally the turntable is connect to the amp via phono inputs on back (RCA connectors) the tape out to equalizer and equalizer out to tape in on amp. The equalizer does not have phono preamp. The equalizer may not clean up record scratches ,or pops or record track noise. good luck
5/20/2022 3:04:20 PM • RCA Audio... • Answered on May 20, 2022
Does the sound quality decrease when using any of the different methods of connecting soundbar?
Line input is line input. It probably will vary depending upon the lead used and signal source impedance.
5/10/2022 7:05:30 AM • RCA Audio... • Answered on May 10, 2022
RCA RP3720 Clock Radio Logo
8 questions posted
Top RCA Audio Players & Recorders Experts
Steve
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Audio Players & Recorders
Most Popular Question
snooze set 1 minute
  • Audio Players & Recorders
