Click on Start, then RIGHT-click on My Computer, click on Manage. In the left pane expand Storage if necessary and click on Disk Management. Look in the LOWER RIGHT pane and scroll through all the hardware devices it shows there.
Do you see that external drive there?
If not, you have a hardware problem.
IF you can see the unit in Disk Management's lower right pane, look at the main block which has info on it. It will show a Volume Name like My Disk or something, a Windows letter name like E, a size, a File System like NTFS, and a status. What are those?
If it simply has no letter name you can assign one by right-clicking on it.
If its File System is shown as "RAW", you have a little corrupted info in the disk control files. It may ask if you want to Format the disk and you are right to NOT do that.
3. Does it display the same info if you connect it to another PC?
4. IF the unit lights up but does not show anywhere as a valid piece of hardware, it is still possible that the HDD inside it is OK with good data, and the problem is with the case - its power supply or communication interface chips.
If that is the case, a simple way to check is to open the external case , uninstall the HDD unit inside, then install it temporarily in a desktop PC.
BUT your external unit MAY be one designed for use with laptops, and those have slightly different connectors on the, you would need an adapter to make the connections to the desktop machine.
But if you can do that, a good HDD will just show up like any other installed HDD. If that happens you can look more closely at the empty case as the culprit.
hope this helps
w7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for xp
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
hope this helps
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red xright click to reinstall drivers or
if you can see your usb but its not workingports(com&lpt)right click update driver
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap hope this helps
46 questions posted
736 Questions
430 Questions
332 Questions
330 Questions
306 Questions
