20 Most Recent RCA AM/FM Stereo Cassette Recorder Radio/Cassette Boombox Questions & Answers
This sounds like a dirty or sticky pinch roller - use a commercial cassette head cleaner - or ear but with a alcohol cleaner -
If the capston is not rolling the cassette forward this my be due to a broken belt - or may have just jumped off - power down the product and disconnet from the mains - then open it up - normaly the front come away undo the mounting screws from around the cassette mechanism normaly around 4 and carefuly look at the back there should normaly be 2 rubber band one to the capston and 1 to the pich roller the belt that may be broken is the smaller of the too. most cassette deck use the same size belt
RCA AM/FM Stereo... | Answered on Oct 09, 2020
What model RCA boombox?
RCA AM/FM Stereo... | Answered on Oct 02, 2013
You can order for it online at ebay.com or just walk into electronic workshop within your area to get it.
RCA AM/FM Stereo... | Answered on Apr 06, 2011
The subwoofer is much more than just another bass unit and the purpose is to reproduce sub-audible content in order to add ambience to the listening experience and before it can reproduce the sound it must first be part of the recording or performance. Even if a recording is rich in sub-audible content, unless the amplifier is designed to process and filter sub-audible frequencies, the amount of content available at the output is likely to be minimal.
A pair of good 3-way loudspeakers will, most of the time produce a purer and more realistic sound with plenty of power and render a subwoofer superfluous.
The fact your amp doesn't have an output for a sub means, even if you successfully connect it there is unlikely to be much activity from it.
The only sensible way to connect it would be as a ghost speaker as used by many hi-fi enthusiasts since the introduction of stereo.
The purpose of a ghost speaker is to fill a gap between the channels and is driven by the difference in emf between the loudspeaker positive of each channel. Unfortunately the difference between the channels isn't great enough to drive a loudspeaker so another amplifier will be needed.
As it is a surplus subwoofer you are trying to find a use for you should either obtain the signal from the bass unit of each speaker or use a crossover type filter in the output of the second amp.
RCA Audio... | Answered 8 hours ago
Contact RCA directly to inquire.
RCA Audio... | Answered on Nov 29, 2020
Request the manual from RCA.
https://www.fixya.com/support/t13862396-set_clock_rca_model_rp_5606_b_disc_clock
RCA Audio... | Answered on Nov 21, 2020
I love the form of your question, as I wanted to wing the sucker myself, but got online before I actually pulled an Office Space on it. I found nothing, but I DID actually figure it out. Not super intuitive though. To set the time: Hold down the memory key in the middle until the number flashes. Use the arrow up/down on the right to set hour. Press Memory key again, repeat with arrow keys to set minutes. Hit memory key again. Alarm: Press/hold the Alarm button until the Alarm 1 or 2 flashes and press the side you want, 1 or 2, to set. Arrow time up/down, then do minutes, press alarm 1 again, select alarm or tuner, press alarm 1 again. Now I need to see if it will work in the morning. I know the flipping time is set though! Good luck. If you wing it, please post photos! :D
RCA Audio... | Answered on Nov 02, 2020
This could be a lot of things. IT could be a switch connection or a chip that has failed, could be a solder connection that is bad. Without proper equipment to send a signal into the unit and trace it, you may not be able to find the problem.
RCA Audio... | Answered on Aug 15, 2020
You did not list the model numbers of either item but I can tell you that the new televisions use HDMI to send and receive audio. With that in mind, there is no way to do what you want to do unless you buy a converter like this one: https://www.amazon.com/AGPtek-SPDIF-Extractor-Converter-output/dp/B00ECTHIKK
RCA Audio... | Answered on Apr 20, 2020
Slide the switch Lock/Wake/Clock on the top of the unit to clock position. Press REV or FWD to set the clock time. The time decrements or increments will follow by a faster rate when you press and hold the buttons. The ":" between hour and minute time flashes when you are setting the time.
https://voxxintl.zendesk.com/hc/en-us/articles/225310027-Operating-the-RCA-RP5420-Dual-Alarm-Clock-Radio
RCA Audio... | Answered on Apr 16, 2020
I bought a new universal remote because my RCA Home Theater remote went bad,
took a few hours to figure out that I had to use the Audio remote code on the list.
I have RCA RCRN06GR Blu-Ray Home Theater. The audio codes that came
with my new remote are 41609, 41254, 41390, 41511, 42041. I believe it was 41254 but try them all if it doesnt work.
RCA Audio... | Answered on Apr 07, 2020
First the music files need to be converted to mp3 file format before copying to your MP3 player. Please click on this link for instruction on converting music files and copying to your player :-
http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
RCA Audio... | Answered on Apr 03, 2020
PCM mode is a digital audio file that should be sent to the soundbar via an optical or coaxial digital audio cable. The coaxial digital audio cable uses an RCA plug but not the L/R stereo channels of analog audio. The aux input is usually the 3.5 MM cable from a computer, CD or MP3 player or a cell phone or tablet.
First, which type of RCA cable is connected between the sound bar and the TV? Second, are you sure that the TV connection is an audio out? (A number of recent TVs have only one audio output. This means there is only the optical audio out and not even a headphone jack.)
Once you double-check the input at the sound bar, choose the Line In input if you are using the stereo RCA cable. If you are using the Optical input, select that input. Use either the Mode button or the specific input button on the remote. Then double-check that the TV is set for the appropriate audio out.
I hope this helps. Please add a comment with the model of the TV and the sound bar for further information. I looked at the ONB18SB001 documentation for some of this. The manual for this Onn soundbar is available at Manuals Lib. See https://www.manualslib.com/manual/1498038/Onn-Onb18sb001.html?page=12#manual for the list of input modes and the input to which they correspond. Here is the image of the inputs on the back of the ONB18SB001: https://www.manualslib.com/manual/1498038/Onn-Onb18sb001.html?page=7#manual .
RCA Audio... | Answered on Feb 26, 2020
RCA AM/FM Stereo Cassette Recorder Radio/Cassette Boombox Logo
11 questions posted
Top RCA Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
Jean Sintulaire
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • RCA Audio Players & Recorders
Most Popular Question
rca boom box cassette player works
  • Audio Players & Recorders
