20 Most Recent Toshiba Satellite C655D-S5084 Laptop Questions & Answers
bad hdd
or if windows XP is fully corrupted.
we test the HDD first, (hard disk drive) . ask. or get it repaired?
Toshiba... | Answered on Mar 11, 2019
Hi
I have seen this problem many times, and in every case, it has been a wire broken between the output of the charger and the plug that goes into the laptop. If your laptop has a "power connected" led, then that should give you the answer, assuming you don't have a voltmeter to test the output.
Toshiba... | Answered on Mar 17, 2017
You need to hold down the FN key at the same time.
Toshiba... | Answered on Jun 17, 2015
It is possible but usually not worth the hassle.
Changing to another CPU chip that fits your motherboard may only show a 3-10% performance change.
See videos of CPU replacement in laptops like yours:
http://www.youtube.com/watch?v=aPdZ4PQhqyo
or
http://www.youtube.com/watch?v=I9a0hIPdVmc
In general, you are better off adding more RAM (memory) or replacing the hard drive with a faster SSD (Solid State Drive) to make a laptop "fly". Your laptop can hold a max of 8 GB RAM:
http://www.crucial.com/upgrade/Toshiba-memory/Satellite+C655+Series/Satellite+C655D-S5084-upgrades.html
In MOST laptops, slower 5400 RPM drives are used, and this is the main performance bottleneck. A 7200 RPM drive or (better yet) a SSD drive will help matters, as will more RAM (the most cost-effective speed increase).
Toshiba... | Answered on Mar 07, 2014
You have to know the installed operating system's edition (home/pro/enterprise, 32/64 bit), and use the same edition to fix your C655c laptop.
Toshiba... | Answered on Mar 03, 2014
The web camera software for your particular model is located at the following: http://support.toshiba.com/support/modelHome?freeText=2836000
Go to the Drivers & Updates tab, select Camera and then Select the top link available.
Toshiba... | Answered on Dec 16, 2013
Check your ram.
Take ram out and replace back.
Toshiba... | Answered on Oct 30, 2013
from the web -
1 Removed the battery
2 Removed the AC power
3 Plugged in the AC power again
Note:- At this point the light from flashing amber light to solid green indicating AC Power
4 Plugged in the Battery
Note:- Solid green AC power light and Amber charge light
In Windows 7
Press start, right click on computer and press properties.
Toshiba... | Answered on Oct 15, 2013
If your using Windows 7
Click on start, right click on computer and click properties.
The software may be corrupted or not working try reinstall it again
Toshiba... | Answered on Sep 25, 2013
has the unit done an upgrade if so use go back feature to 2 weeks ago and then try
Toshiba... | Answered on Aug 18, 2013
try booting from a Windows installation disc. Choose the repair installation option. If this does not work, you may have to erase (format) your whole drive and start over again by reinstalling Windows from scratch.
Before erasing the drive, you might want to pull it out, put as a second drive in another working computer or inside a USB hard drive case and download all of your information from it. Otherwise you may have a mess on your hands with lost data/documents/photos.
Toshiba... | Answered on Jan 22, 2013
Hi ,
The BIOS chip is located near the usb ports , I should tell you its a non removable chip ....
Goodluck Roy
Toshiba... | Answered on Jul 22, 2011
Hi ,
why do you need to know this , its somthing that you should not have to touch , I have the same unit you do so I can tell you its under the cover on the bottom side of your laptop .....it will be marked bios on the chip ..........goodluck Roy
Toshiba... | Answered on Jul 21, 2011
Just restore your system from a backup taken before the error code started.
If you have no backup then you need to format your hard disk and do a complete reinstall of all your software.
Toshiba... | Answered on Mar 19, 2020
If you know the DVD and the DVD drive is in proper working order, it could mean that the software you are running just may have some problems. Try downloading a copy of VLC (VideoLan Client) this application is free and open source (and no it's not something I created and am just trying to get people to use...it's just something that works great, and completely free) VLC can play almost any video file or DVD that it encounters. If VLC can't play it, I would think it's likely there may be something with your disk or your DVD drive.
Toshiba... | Answered on Mar 11, 2020
Toshiba Satellite C655D-S5084 Laptop Logo
Popular Tags
25 questions posted
Top Toshiba Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
usb port not working
  • Computers & Internet
