20 Most Recent HEWLETT-PACKARD HP DV6000 Laptop Motherboard OEM 446476-001 446476001 Questions & Answers
Dv6000 black screen
WOW NO OS STATED why even post? the black screens of *****, know them well , i do these only. mostly... or found on road dead, found this in and attic, or in a dumpster well it can be any thing right, 3billion transistors and GB of of windows files endless ,to fail. yah or the HDD dead or 1/2 dead. but windoz is last. always. first is BIOS, screens, i presume BIOS never ever shows text or the HP logo so that means what the CCFL is dead, as most are now this old dead as a brick the black light see here. see the flash light trick test, this always test 1, on any of the below listed LT (yours) http://pcdied.com/monitors.html#Laptop check out the CCFL Laptop and monitor lest there, hard to get that.
8/2/2017 1:57:06 PM • HEWLETT-PACKARD... • Answered on Aug 02, 2017
Get webcam to work with hpdv6000 laptop
if your webcam has a usb connection plug it in click start control panel view devices and printers you should see your webcam from there if you are have trouble with your webcam click start control panel view devices and printers you should see your webcam click start right click on my computer select properties then device manager scroll down image devices expand you could see a yellow question exclamation mark? ! or a red X right click to reinstall drivers or update driver software W7 click start control panel view devices and printers you should see your webcam from there if you are have trouble with your webcam click start control panel administrive tools ,computer management ,device manager scroll down image devices you could see a yellow question/exclamation mark ? ! or a red X a new driver will need to be installed right click to reinstall drivers or update driver hope this helps
7/16/2012 4:31:50 AM • HEWLETT-PACKARD... • Answered on Jul 16, 2012
Power circuit 446476-001
Components open in the power circuit near the battery plug-in?Hmmmm, lemme go see...............http://www.getpartsonline.com/446476-001.htmlClick on the photo of the motherboard views, (Top view/Bottom view)View on the right side is the Bottom view. Up above the purple Processor socket, are the interface pins to plug the Battery into.Above those interface pins, (Battery connector), is a Power MOSFET.It is FDS6679,http://www.datasheetcatalog.com/datasheets_pdf/F/D/S/6/FDS6679.shtmlOn this page click on the blue -> FDS6679 datasheet <- in the sentence - Download FDS6679 datasheet from Fairchild Semiconductor.As you can see the chipset is mounted with J leads.This is information on the AON6500 on the other side.Another Power MOSFET,http://www.aosmd.com/On this page go to the right under the subheading - Featured Product.Click on the blue -> More <- at the end of the sentence -Alpha and Omega Semiconductor's New 30V Power MOSFET Slashes Conduction Losses - MoreGives you a PDF datasheet.http://en.wikipedia.org/wiki/Power_MOSFETNow to the main article on the subject I recently found,http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html(Mayo Hardware you are the MAN!)Be sure you use a low wattage soldering iron, and a heatsink,http://www.radioshack.com/product/index.jsp?productId=2103242(Clip to EACH J lead, when soldering each one, or you will 'Smoke' that chipset)Regards,joecoolvette
6/25/2012 8:45:26 PM • HEWLETT-PACKARD... • Answered on Jun 25, 2012
Hp dv6000 wont start up
Switch ON the PC, boot the PC in 'Safe Mode' by continuously tapping F8 button after you switch On until you get the Safe Mode Option. Let windows boot in Safe Mode and log in to windows. Go to 'Start'--->Programs--->Accessories--->System Tools--->Click 'System Restore'
A 'System Restore' window will appear. Here you will have to check "Restore computer to an earlier time' and click Next
Now you will find one Month Calendar window with Dates below, go to the previous month by clicking the '<' sign in the upper left hand corner of the Month Calendar and select any date that you see in Bold.
Note: It is better if you could remember from which date you are facing the issue, try to select a date prior to that date.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a reboot. After reboot your problem should be resolved.
6/16/2012 9:00:06 AM • HEWLETT-PACKARD... • Answered on Jun 16, 2012
I have a hp dv6000 laptop it is stuck in a reboot loop with a black screen when i hit F10 i can get it to stop but still have a black screen what can i do?
If so, I assume that you can't access the BIOS setup screen, yes? Okay, if you can't, it seems that you have hardware problem. By disassembling the laptop, check the connection of the RAM, plug out and in the BIOS battery and carefully check the motherboard for any faulty circuit. But it is always better to leave it to the expert to do those things. ;)
6/16/2012 8:58:51 AM • HEWLETT-PACKARD... • Answered on Jun 16, 2012
Hp dv 6000 graphics card troubles
Some laptops have to have external monitor "enabled" in the setup/configuration. Try that.
5/9/2012 4:42:42 PM • HEWLETT-PACKARD... • Answered on May 09, 2012
How do I get more people to leave feedback when I
You could try having a 'signature' for your answers, at the bottom have a "If you found this answer helpful please leave feedback to help us continue helping others"
2/18/2011 10:29:51 PM • HEWLETT-PACKARD... • Answered on Feb 18, 2011
2answers
When I try to download into quicken the documents page comes up. How do I correct this situation?
If your bank statement is not in the Quicken format, you cannot do that. Best see if it will download into MS Excel. If not, get in touch with the Bank
10/19/2022 4:47:44 AM • HEWLETT-PACKARD... • Answered on Oct 19, 2022
3answers
Back Slash on HP keyboard ProBook
Try now~ Then you can reset your keyboard if you like
5/4/2022 2:32:08 PM • HEWLETT-PACKARD... • Answered on May 04, 2022
HP G72-253NR Laptop - Using an External Keyboard
I think you have a broken USB keyboard or USB port. Simply plugging in the keyboard should be enough to make it work. First try the keyboard in a different USB port. Test the caps lock to see if the LED goes on and off. Also try a different keyboard and also test it in a different computer.
1/31/2019 6:37:16 PM • HEWLETT-PACKARD... • Answered on Jan 31, 2019
Pano pag ang laptop sa HP ay hindi na mag on pero meron syang power?
please use English, ok?
10/30/2018 1:04:04 PM • HEWLETT-PACKARD... • Answered on Oct 30, 2018
3answers
User manual Hewlett-Packard G2 tablet or the instruction booklet
https://support.hp.com/us-en/product/hp-10-g2/8223709/model/9078231/manuals
this is the manual pdf just download it
10/1/2018 11:15:14 AM • HEWLETT-PACKARD... • Answered on Oct 01, 2018
2answers
My Hewlett-Packard w2207 monitor is showing no input signal when I power it on what does that mean and how can I fix it
1) Reset your computer. 2) Unplug the cable from the computer to the monitor and check to see if its damaged, if OK plug it back in. 3) On windows computer, click windows key / windows system / control panel / device manager / display adapters (click on icon) / Update driver
5/1/2018 3:23:11 PM • HEWLETT-PACKARD... • Answered on May 01, 2018
HP A6519FH Black Screen Issue: I
what computers.?? 1000's of models over 30 years. made F10 is BIOS screens, so if that works, BIOS. and any screen then the PC is not booting. try booting to CD? *(a free linux live cd?) as a test. if that works run HDD tests. next ill stop here, if you can get this far, we go to next step F11 HDD reload the OS, if PC is 2006 or newer from HP.
2/1/2018 12:20:26 PM • HEWLETT-PACKARD... • Answered on Feb 01, 2018
Ce 3700, no model HP stated
Try again with the model number
1/30/2018 12:32:03 PM • HEWLETT-PACKARD... • Answered on Jan 30, 2018
My laptop hp compaq 6715s, the battery is charging
what is a device? did you mean PC, a collections of devices and chips:? a PC Is not a DEVICE it is a system.(or machine) why in the world not buy a new battery first? if charging fails. mine sometimes go bad even 1 year old, when I abuse it. and I fully expect that, if you read the battery makers pages, youd learn how that happens' (cycling the snarf out of it) if i remove the word DEVICE and add LAPTOP OR PC THE ANSWER IS THIS. IF the Pc does not run with the battery (main big) out ! the power pack is bad. the PC will run forever on AC power, a fact, !!! I do so all the time, or even the wrong AC pack used, (mixed up with other pc:) get a new pack, get one matching your systems, needs (watts) the laptops can come with 5 processor options and 4 graphic chip options, the worse mix is 100watts, HP will tell you that match. but only if YOU tell your full service tag data.... that magic, nnnnnnnABA# number tells the HP pro what is inside this laptop and what power park is right or just buy the 19v, 100watt pack. here is real HP, fixya is NOT. they can match you up as can the hp PARTS SURFER, https://h30434.www3.hp.com/
1/24/2018 1:56:50 PM • HEWLETT-PACKARD... • Answered on Jan 24, 2018
2answers
How to fix the sound of HP pavilion dv6345us
sure, get the Correct HP driver for this exact pc but, but but...The windows sounds are dead. (do that yet>, CP + sound test)CP = control paneltry to know , most HP made, dv6345us, can have 3 sound chips as an option day 1 new!what you have is clearly stated in the service tag that you did NOTpost, the number ending in ABA# is THAT number.the chip and PC and the unstated OS all must matchwindows what? you never said so i cant match that either.VISTA????????? vista 32 bit or 64????????but the other way is what, sure, guess.read the drivers at HP and try all there.for sound chips (aka audio)This HP computer is 11 years old. now. (2007)HP dropped most support on it this old, (SOP) one sound chip is Conexant AC -Link Audiolets say you said (service tag) RV214UA#ABAand you said VISTA> what works there.the secret is deep, lacking full spec, from HP.finding Conexant drivers is not easy, lots of hits all virus sites now.lets first look .does device manager show it as bad.CP+DM see sound there. is it red, yellow or Unknown marked.go to CP again control panelclick sound is the Conexant still there.the window for sound has a speaker is it selected?select speaker then properties lower right.then pick enhancementshit checkmark, disable all sound effectsclick tab levels, turn up volume.can you do all that, i bet not, its got bad drivers for this chipVISTA btw is dead so asking MS to update driver is dream of dreams, hopeless, now and for sure forward.you dont have the HP install disks so that source too is missing.,leaving you , VISTA and MS and HP and conexant in the lurch.if microsoft was not dead and your internet was alive (is it)the remove the driver, and reload, it under device manager.it then magically PnP reloads from MS but not if the MS driver servers are off line as they sure are. (1/2 or all) (ms secret this is)Hard this is,::::, 1ST OFF, is HP ended support,ON YOUR PC NOW.2nd VISTA support has ended at MS. (double dead)3rd factor (bad) IS Conexant maker of chip and their Driver. IS DEAD. TRIPLE DEAD.SHORT WHY>?synaptics Bought out Conexant in 2017, and shows no support NOW. FOR THAT. the Snaptics web site lists nothing on the words driver or conexant. zero support, but do call them,,,? SO that ends that foray. leaving all those malwares sites offering this driver, only. ? many we can find it this magical way. the FAMOUS DRIVER PACKS site. (all safe ask) the one place on earth with no malware is here.this is the vista set 32bit only 64 is on other pagethere are 15 drivers for Conexant. there. get them try them.end storyhttp://driverpacks.net/driverpacks/windows/7/x86/audio/11.11
1/5/2018 4:29:57 PM • HEWLETT-PACKARD... • Answered on Jan 05, 2018
HEWLETT-PACKARD HP DV6000 Laptop Motherboard OEM 446476-001 446476001 Logo
14 questions posted
Top HEWLETT-PACKARD Computers & Internet Experts
Paul Bade
Grand Canyon Tech
Grand Canyon Tech
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HEWLETT-PACKARD Computers & Internet
Most Popular Question
get more people leave feedback when
  • Computers & Internet
