20 Most Recent Toshiba Satellite C655D-S5120 Notebook Questions & Answers
      Click the "Start" button and click "Control Panel." Click "Hardware and Sound" and click the "Mouse" link under Devices and Printers to open the Mouse Properties box. Click the "Touchpad" or "Buttons" tab depending on your PC, then select the "Disable" option next to thetouchpad installed on your computer.
      How to Disable TouchPad While the USB Mouse Is Plugged in
      smallbusiness.chron.com/disable-touchpad-usb-mouse-plugged-52685.html
    Feedback
    How To Turn Off Touchpad When Mouse Is Connected In ...
    www.intowindows.com > Windows 10
    Dec 14, 2015 - How To Turn Off Touchpad When Mouse Is Connected In Windows 10/7/ ... who always use a mouse and don't want to use the built-in trackpad ...
    How to Disable Your Laptop Touchpad ' PCWorld
Toshiba... | Answered on Jan 31, 2016
Synaptic makes most mouse pads, try a different driver from them depending on the identified hardware. Remove the old drivers.
Toshiba... | Answered on Jan 11, 2015
SATA plug.
Toshiba... | Answered on Feb 24, 2014
check the anti virus or your windows firewall,if they are not the cause,uninstall suspicious pro
grams...
Toshiba... | Answered on Nov 21, 2013
sounds like you have a bad hard drive,,try putting a bootable cd and start it like that,or at the start up hit the f2 key and go into the setup and seee if there is a hard drive loaded
Toshiba... | Answered on Sep 13, 2013
Have you been to the repair center yet?
Toshiba... | Answered on Jan 24, 2013
Change the boot startup order back to the hard drive as the first boot device in the BIOS. If you still have this problem then -
Go to this WEB site to fix Bootmgr is missing problem.
http://pcsupport.about.com/od/findbyerrormessage/a/bootmgr-is-missing.htm
Toshiba... | Answered on Mar 30, 2012
Take the laptop back "asp" you should not be getting messages on the screen, it indicates device issue and maybe a bigger problem.
Toshiba... | Answered on Mar 07, 2012
To turn Windows Sidebar off:
vista_sidebar_icon.jpg 1. Right-click the Windows Sidebar icon on the taskbar (it looks like the image to the left). If you do not see this icon, click the "Show Hidden Icons" arrow (it looks like the image to the right), then right-click the Windows Sidebar icon.
2. To temporarily disable the Windows Sidebar, click "Exit". Or, to permanently disable it:
* Click "Properties"
* The "Windows Sidebar Properties" dialog box will appear. Uncheck "Start Sidebar when Windows Starts".
* Click "OK".
* Finally, right-click the icon again and click "Exit".
To turn Windows Sidebar on:
1. Click the Windows button on the taskbar, enter "sidebar" (without quotes) and press the Enter key.
2. Now, if you want to permanently enable the sidebar when Windows starts:
* Right-click the Windows Sidebar icon, choosing "Properties".
* The "Windows Sidebar Properties" dialog box will appear. Check "Start Sidebar when Windows Starts".
* Click "OK".
Toshiba... | Answered on Aug 14, 2011
Hi! Welcome to www.fixya.com.
1. Copy all your files and documents to an external storage device. 2. Shut down the computer. 3. Turn the PC back on and hit the F8 key repeatedly until the Advanced Boot Option Screen appears. 4. Click "Repair Your Computer" if you are not already on it and then press ENTER 5. choose your country and click OK 6. On the "System Recovery Options Screen" click "Restore Application" which is the last option. 7. Follow the on-screen instructions 8. When prompted, click on "Full Factory Recovery" 9. "Next" 10. Click "Yes" 11. you will notice for a while it seems like nothing is happening, give it some time. 12. After some minutes, recovery will complete and you click "Finish"
Hope this resolution fix the problem on your computer. Thanks for contacting Fixya. Bye for now.
Toshiba... | Answered on Jul 27, 2011
Just restore your system from a backup taken before the error code started.
If you have no backup then you need to format your hard disk and do a complete reinstall of all your software.
Toshiba... | Answered on Mar 19, 2020
If you know the DVD and the DVD drive is in proper working order, it could mean that the software you are running just may have some problems. Try downloading a copy of VLC (VideoLan Client) this application is free and open source (and no it's not something I created and am just trying to get people to use...it's just something that works great, and completely free) VLC can play almost any video file or DVD that it encounters. If VLC can't play it, I would think it's likely there may be something with your disk or your DVD drive.
Toshiba... | Answered on Mar 11, 2020
dvd players play vob or mp4 format. so try "convert x to dvd" software to burn your dvds in the right format http://www.vso-software.fr/products/convert_x_to_dvd/
Toshiba... | Answered on Feb 16, 2020
If you want to play DVDs from any region you maybe able to upgrade the firmware to make it region free BUT if you make a mistake or installed the wrong firmware the player will be a piece of junk.
The best solution to make the player region free is to install a piece of software (Passkey for DVD) that allows you to play DVDs from any region and Passkey for Blu-ray that allows you to play Blu-rays from any region.
There are several available on the Internet but my favourite is DVD-Region Free
www.dvdfab.com/products,free.htm
Toshiba... | Answered on Dec 05, 2019
Do you have a wifi card in the computer? It is a hardware part that you need so that the computer can connect to the wifi. If you have that but can't find it in the operating system. I suggest that you either install or update the driver for it.
You can use RadarSync to scan your computer for the available updates of your wifi driver. Make sure that you connect to the internet first using your ethernet so that it will detect the available driver updates somewhere in the databases of the manufacturer.
David
http://goo.gl/CxsY9u
Toshiba... | Answered on Sep 25, 2019
to get the driver for your Toshiba, follow the steps below:
go to http://support.toshiba.com/drivers
enter your laptop model ( Satellite L505) and download sound drivers and other necessary drivers needed for your laptop to operate well.
Good luck.
Toshiba... | Answered on Sep 12, 2019
uninstall the software and put it again
Toshiba... | Answered on Sep 06, 2019
All drivers are available free of charge from Toshiba's web site.
Toshiba... | Answered on Jul 23, 2019
Toshiba Satellite C655D-S5120 Notebook Logo
17 questions posted
Top Toshiba Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
want
  • Computers & Internet
