20 Most Recent Seloc Johnson Outboards 2002-2007 Repair Manual Questions & Answers
All 2stroke engines need 2stroke oil in the fuel !!! 50 to 1 mixture ! fuel to oil !...
Seloc Johnson... | Answered on Feb 24, 2015
Hi, mix the gas and oil at 50 to 1 and use two cycle outboard oil. Regards Phil.
Seloc Johnson... | Answered on Aug 19, 2014
What a neat little fisher motor. All needle bearing motor so you can run it on 50/1 --would use synthetic for the best operation. Take care of that starter spool- slowly engage the plastic gear to the flywheel before you pull the starter for the start.
Seloc Johnson... | Answered on Oct 14, 2012
You may have left the fuel vent closed. If working, put a clear plastic fuel line between the fuel pump and the carb. Look for bubbles indicating an air leak between the tank and the carb.
On a rear occasion you can have some varnish flakes floating round the fuel bowl. But these tend to cause random problems than the "about 5 min" problems you are having.
Seloc Johnson... | Answered on Oct 11, 2012
sounds like a fuel venting problem. Loosen the cap to the gas can and see if that works.
Then (if that fixed it) you will find the vent built into the cap is sticking shut or you forgot to open it.
Seloc Johnson... | Answered on Sep 30, 2012
Contact the manufacturer/distributor to request it.
Boating | Answered on Dec 10, 2020
Lots of things needed when you go for kayaking. It depends on you and where you want to kayak. If you go for fishing you need fishing types accessory but if you go for tour or adventures you need that types of thing. Considering these things, I will select some materials that you need. They are those :
Dry Bags and Dry Box ,Bilge Pump or Sponge ,Lightweight Tent ,Synthetic Sleeping Bag,Life Jacket,Water Filter or Iodine Tablets,Sunscreen,Watch,Paddle float,Compass (that floats),Towline,Maps and charts in waterproof case,Lip balm (SPF 15+),Insect repellent (as needed),Water in bottles or reservoirs-shielding hat,GPS (loaded with map files,Emergency flares or strobe,Two-way radios (1 in lead, 1 in sweep boat).
To know more about kayak you may visit here
Best Inflatable Kayaks in 2018 List of The Top Selling Models
Boating | Answered on Sep 29, 2020
Hold down the 88/pri and the DW buttons while switching on the radio into programming mode. You'll then need the programming soft and hardware to read the radio., add the 27mhz channels and write it back to the radio. The GX300 can only store additional freq. in the p1-p0 modes
Boating | Answered on Aug 29, 2020
5_22_2013_9_45_08_pm.jpgvs.5_22_2013_9_44_20_pm.jpgA powerboat is the type of boat you traditionally think of as a motorboat or speedboat. Imagine a water skier behind it. A jet ski is a personal watercraft for 1-4 people. The passangers sit on top of a jet ski with their legs on either side.
Boating | Answered on Aug 26, 2020
First, make sure that you are trying a lifejacket that fits your weight and height. The best way to test it is to work in a pair. Hold your hands straight above your head and have someone else pull up the tops of the arm openings. If the jacket covers your face or chin, it is too large.
Boating | Answered on Aug 25, 2020
It should be on the makers tag sewed onto the jacket
otherwise contact the manufacturer on the net
I think that google might have a manual for your 1996 35 doral SC. You can always try searching on google and type in the google search engine.
Boating | Answered on Aug 04, 2020
Not sure if this link will help
https://www.bitchute.com/playlist/zdU7Ihae6i4C/
A little history on the glastex later sold as sea star and sea spirit
http://www.fiberglassics.com/library/index.php?title=Sea_Sprite
Boating | Answered on Jul 06, 2020
Seloc Johnson Outboards 2002-2007 Repair Manual Logo
16 questions posted
Top Seloc Boating Experts
Marvin
Marvin
Bill Boyd
Dariusz Zalewski
Dariusz Zalewski
Are you a Seloc Boating Expert? Answer questions, earn points and help others
View Most Popular
Seloc Boating
  • Seloc Boating
Most Popular Question
gas mixture 9r 70c
  • Boating
