20 Most Recent Samsung Digimax A50 Digital Camera Questions & Answers
Is 4gb SDHC card compatible with Samsung A50 camera,will not format,says card error
The A50 works with MMC and SD cards, 2GB or smaller. It does not work with higher-capacity SDHC cards.
9/20/2014 6:20:00 PM • Samsung Digimax... • Answered on Sep 20, 2014
Connect pc
Try NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
10/18/2013 6:27:52 PM • Samsung Digimax... • Answered on Oct 18, 2013
Can samsung a 50 take
Yes this camera can support 2 GB of memory card.
8/19/2011 10:53:51 PM • Samsung Digimax... • Answered on Aug 19, 2011
I need book on how to operate my camera
Hello
OK, you will be able to download the manual HERE.
Kind regards
Andrea
8/29/2010 5:35:40 PM • Samsung Digimax... • Answered on Aug 29, 2010
Card error - samsung a50
the card reading error appears when the card is locked by the side button ..and you try to make an operation forbidden by this locking action ...another thing may be a reading issue based on the card reader driver malfunction ...so reinstalling the card reader will be a point to start ..after that be sure that the card is not physically locked by the side slide button ..and the last thing be sure the files are not protected...another issue that may cause the error is the contacts of the card itself ...insert it proper and be sure they are not oxidized ...
If you do not have important files on it ..a formatting will be a good thing to do ...
8/2/2010 1:06:10 PM • Samsung Digimax... • Answered on Aug 02, 2010
My digimax a50 camera keeps saying card locked
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
6/16/2010 8:17:32 PM • Samsung Digimax... • Answered on Jun 16, 2010
All of a sudden, my
Base from the description of your problem there;s a big chance that this is a settings problem on your camera, so what you can try to do here first to correct the problem is to reset your camera;s settings to its default settings and then check if the problem is solve.
6/15/2010 8:39:50 PM • Samsung Digimax... • Answered on Jun 15, 2010
0answers
Problem
it isnt the infra red.
on you dvr machine there should be settings or settings on the camera for mirror and flip.
these are features on better cameras and are normally on the camera body, but veiwable on the cctv monitor. they should be menu driven.
I hope this will be of help
Neil
1/19/2009 8:37:40 PM • Samsung Digimax... • Answered on Jan 19, 2009
Not connecting to pc
try to download a driver for your camera
1/13/2009 2:55:34 PM • Samsung Digimax... • Answered on Jan 13, 2009
Annoying menu chimes
Hi - You can download the manual from the link underlined in blue below:
Digimax A50
The shutter sound is set on page 93:
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
8/31/2008 1:46:36 PM • Samsung Digimax... • Answered on Aug 31, 2008
Audio level problemos
This may sound silly,but did you have your finger over the mic on the camera? Its just underneath the lens at the front.
I have generally found that the sound on movies taken with this camera is poor, you need the sound source to be quite close to the camera for clear sound.
8/31/2008 12:12:00 PM • Samsung Digimax... • Answered on Aug 31, 2008
File error
First off... let's make sure you are doing one thing correctly. After you take a picture, it writes the information to your memory card. Make sure you allow it to complete that process _before_ you change and dial settings, go into the menu, or try to review it. If you interrupt it while it is writing to the card, the image will often become corrupt and give you the file error message. Next, I want you to format the card. Use your manual to find out the correct steps to follow. But be aware that it will remove all the information and photos from the card. It essentially erases the card so it looks empty and brand new to the camera. If the problem persists, you more than likely have a bad card. If it's still under warranty, try to return it. Otherwise, you may have to purchase a new one. Thanks in advance for reviewing me.
7/4/2007 3:46:44 AM • Samsung Digimax... • Answered on Jul 04, 2007
Images are to bright even after reset
This can be a broken shutter cable inside the lens. Toes it still make the "click" (not from the speaker)?
3/16/2015 11:44:14 PM • Samsung DigiMax... • Answered on Mar 16, 2015
Cameras Logo
22 questions posted
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
View Most Popular
DigiMax Samsung
  • DigiMax Samsung
Most Popular Question
samsung 50
  • Cameras
