20 Most Recent Samsung Digimax U-CA 5 Digital Camera Questions & Answers
Camera not charging
Sorry for the trouble you are having. It seems the camera is functioning somewhat with ac cord hooked on. You want to make sure you can take picture with power cord consistently without fail. I worry because you mentioned multiple problems for the camera and it is not good sign that camera is good for the reliability. You may want to borrow a backup camera from a friend just in case. If all symtoms you've decribed is correct, camera need full repair by a technician and maybe beyond economical.
9/10/2008 3:07:55 AM • Samsung Digimax... • Answered on Sep 10, 2008
4answers
Owners manuel in english
Check this link and see your unit http://www.samsungcamera.com/customer/download/cus_down_main.asp?page=9&keyfield=&key=
Hope that helps.....
7/22/2008 5:56:17 PM • Samsung Digimax... • Answered on Jul 22, 2008
Cant download
have you tryed to take the memory card from the camera and putting it in the computer?
6/28/2008 7:05:17 PM • Samsung Digimax... • Answered on Jun 28, 2008
Share & download videos
If you copy the files from CD whoever you send it to needs a DIVX plug in to view the videos. That can be loaded for free at DivX.com
Unless you have video editing software in your computer that can read the files and convert them into another file format for you that would be the other option.
6/11/2008 10:36:42 PM • Samsung Digimax... • Answered on Jun 11, 2008
Unable to share video
In order to view video off of that camera, everyone needs Divx software.
It is available for free at www.divx.com
6/11/2008 8:08:03 PM • Samsung Digimax... • Answered on Jun 11, 2008
Samsung Digimax U-CA 5 : won't turn on....
You might want to try a new battery for it.
Before you do that, plug the camera into the charger and see if if opens. If that works, you need a new battery. It isn't charging anymore.
6/11/2008 7:49:01 PM • Samsung Digimax... • Answered on Jun 11, 2008
Card locked
Greetings Burtie,
There should be a small slide tab on your memory card which locks it. Please slide that tab to the unlocked position and this should fix your issue with a locked memory card.
Sincerely,
Agent Dort
4/7/2008 7:45:35 PM • Samsung Digimax... • Answered on Apr 07, 2008
0answers
Flash problems
I assume you mean when ever you switch the flash off. This is because there is not enough light for the particular setting the camera is on and the images are blurred because of the long exposure is causing camera shake. Check the menu and see in you can select a higher ISO figure- Say 400
6/1/2007 10:46:12 AM • Samsung Digimax... • Answered on Jun 01, 2007
Images are to bright even after reset
This can be a broken shutter cable inside the lens. Toes it still make the "click" (not from the speaker)?
3/16/2015 11:44:14 PM • Samsung DigiMax... • Answered on Mar 16, 2015
How do I use the focus
be sure your lense and autofocus sensors are clean first thing.. then push the take picture button half way and it will autofocus. Pressing hte take picture button fully then will snap the picture.
1/3/2015 4:07:56 AM • Samsung DigiMax... • Answered on Jan 03, 2015
How do I get camera to recognise new card. It asks to configure,I press ok, it tells me to check card.It only goes in one way.How do I fix?
If you have a computer, insert it into the card reader,l select it and format with your computer
12/28/2014 3:20:00 AM • Samsung DigiMax... • Answered on Dec 28, 2014
What is the card type which can be inserted in Samsung Digimax 401
The 401 takes MMC and SD cards, 2GB or smaller.
10/6/2014 2:48:17 PM • Samsung DigiMax... • Answered on Oct 06, 2014
How to use a camera?
You should be able to follow the instruction available at this website. http://downloadcenter.samsung.com/content/UM/201301/20130129135843169/WB30F_English.pdf
7/31/2014 12:11:24 PM • Samsung DigiMax... • Answered on Jul 31, 2014
Samsung wb500 drivers windows xp
You need to install Intelli-Studio, Please view the following guide how to start this installation. http://skp.samsungcsportal.com/integrated/popup/FaqDetailPopup3.jsp?cdsite=uk&seq=1038212 Or download Intelli-Studio here: http://samsung-intelli-studio.updatestar.com/
5/25/2014 3:45:27 PM • Samsung DigiMax... • Answered on May 25, 2014
Taking picctures outside they come out completly white and inside they are fine.
Not sure what type or model of camera you have. But most camera's have a Mode dial. The best thing to do is to turn that dial to the little green camera logo. That is the automatic mode. If you have chosen the moon and star, you only can make pictures in bad light situations.
12/9/2013 3:51:59 PM • Samsung DigiMax... • Answered on Dec 09, 2013
Samsung Digimax U-CA 5 Digital Camera Logo
11 questions posted
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
View Most Popular
DigiMax Samsung
  • DigiMax Samsung
Most Popular Question
unable share video
  • Cameras
