20 Most Recent
Tivo R54040 140-Hours Video Recorder Questions & Answers
Can i use the same
Short answer "Yes"
of course only if your Laptop has an HDMI output. The only possible hiccup
would be if the the source, in this case your Laptop, demands a certain speed cable.
HDMI cables have speed ratings...
- Standard HDMI cables tested to perform
at speeds of 75Mhz or up to 2.25Gbps, which is the equivalent of a
720p/1080i signal.
- High Speed HDMI cables tested to
perform at speeds of 340Mhz or up to 10.2Gbps can successfully
handle 1080p signals
Does a TIVO work at
Yes, the service is just for the Guide and associated extra, like ratings. Without it you must find, tune in and program to record the shows manually.
Playback in B/W
no you can't transfer then to another hard drive because of the format they have been saved in, burn them to dvd if you can, try reset the machine to factory settings, this in theory should ironout any clitches
hope this helps
regards
