20 Most Recent
Nikon 50mm f/1.8 AF Nikkor Lens Questions & Answers
D3100 DOESN'T RECONIZE NEW AF-S 50MM 1.8G LENS
There are a series of small brass "buttons" on the outside bottom of the lens where contact is established. If a new lens, there may be some dirt or grease on them preventing contack. Wipe lens and camera buttons carefully with a lent free cloth and retry. Then it is time to go back to the seller.
Hi where can i get instructions on how to use my
That depends on the lens in question.
50mm f/1.8 AF-D:
http://www.nikonusa.com/pdf/manuals/lenses/AF/AF50mm.pdf
50mm f/1.4 AF-D:
http://www.nikonusa.com/pdf/manuals/lenses/AF/AF50f1.4D.pdf
50mm f/1.4 AF-G:
http://www.nikonusa.com/pdf/manuals/lenses/AF/AFS50G.pdf
I locked my nikon 50mm lens aperature ring to the
Sounds like the coupling pin on the body is missing, Try a diff auto focus on the body, If it still does it then I believe that\'s the problem, On the body next to the lens mount, About 7 o clock there should be a lever that couples with the lens when is is at f22 or larger
Stuck lens adapter
Try sending it to PhotoTech Repair Service in NYC. They are Nikon authorized, and can do the repair under warranty if you still have it. Also if you join they're facebook page, they will give you a 10% discount.
Here is the facebook page link, it has everything you need to send it in.
http://www.facebook.com/pages/New-York-NY/PhotoTech-Repair-Service-Inc/102527215194
'' Fee'' problem...
Turn the aperture ring on the lens to its smallest aperture (largest f/number) and lock it in place. If you need to, you can control the aperture by turning the subcommand dial (the one in front, under the shutter release button, unless you've swapped the dials).
Dropped lens and is stuck.
There are lots of electronics in these modern lenses... a drop, just like a small digital camera, and it's toast. A 50mm F1.8 is a very common lens, E-bay should have plenty as most people now have zooms.
Pictures are white after taking a shot. But when I'm in indoors it's quite normal.
Way, Way Over exposed Gracey. Read the manual for the mystery Nikon Camera and set the camera to Automatic Exposure. Film 'Speed' is measured in ASA Rating, 200 ASA would be standard for outside, 400 ASA for lower light, up to 1200 ASA for very low light like candle light. The higher the ASA Rating, the more grain you will get in an image. In the old days, we used a light meter set to the actual film speed of the roll of film in the camera and the sensor in the light meter told you what to to set the lens aperture and shutter speed to. Now with digital cameras, it is all automatic, or you can choose to go with manual exposure.FULL 'make model (what it is)' in all questions please first 3 words.GoogleNikon (model) manualRead it it LEAST 3 times and at least once with the camera in your lap. Use the camera every day for a week and read it again...
I encounter a problem r07 using my Nikon D3100 with 18-55mm kits lens or my 55-200mm lens. How can I fix this? Thank you.
On Nikon cameras this isn't normally an error code. Have you got a memory card in the camera? Check that it isn't nearly full.
r07 common comes up as an information prompt referring to the memory space in the camera. '07' being 7 shots remaining.
If the card isn't full try this. Turn the camera off. Remove the battery. Remove the memory card. Leave it like that for at least 15 minutes. Connect the memory card to a computer or a laptop and check you can still look at and move the images that are on there. This is to check the memory card isn't corrupted (developed a fault).
Error clock R49 error on Nikon D80
this error message is usually caused by a low battery. Here are some steps you can try to fix the issue:
Remove the battery from your camera.
Fully charge the battery using the Nikon D80 battery charger.
Remove the memory card and reset the camera by using the reset option in the menu or by pressing the reset switch on the camera's body, under the connector cover .
If the error persists, Nikon recommends waiting for one or two days before sending the camera in for inspection
How do I fix the err low f4.8 on my Nikon d80
From the sites I've looked at al say this about f....
Most of the time, this
F Error message is limited to Nikon DLSR cameras. This particular
error message appears when the camera is not able to communicate with the lens.
To
fix F- error message, clean the contacts on the rear of the lens with the help of microfiber cloth and make sure that the lens is locked into its place.
If the problem still persists, then try different lenses to identify whether the problem is in the lens or camera. If you are not able to fix it by yourself, then you can take your camera to the service center.
I'm not a camera buff but I thought I'd pass this on.
other sites too....
https://duckduckgo.com/?q=err+low+f4.8+on+Nikon+d80&t=ffab&atb=v159-1&ia=web
Best to you.
