20 Most Recent
Altec Lansing FX6021 System Questions & Answers
Re Altec lansing FX6021 Unit previously working
I have the same problem I tested the power volume controller with in my friend sub-woofer and same issue, is not the sub-woofer neither the speaker, is the power volume controller definitively.
Altec Lansing MX6021 Expressionist ULTRA 2.1
The "pluc pluc pluc" noise you're hearing from your Altec Lansing MX6021 Expressionist ULTRA 2.1 speakers could be a sign of a few different issues. Here are a few things you can try:
- Check the cables: Make sure all cables are connected properly and there are no loose connections. Try using a different cable to see if that solves the problem.
- Check the power supply: Ensure that the power supply is plugged in and working properly. Try using a different power outlet or power supply to see if that solves the problem.
- Check the volume: Make sure that the volume on your device is turned up and the speakers are not on mute.
- Try a different device: Connect the speakers to a different device to see if the issue is with your laptop or the speakers.
- Check for software updates: Visit the Altec Lansing website to see if there are any software updates or firmware updates available for your speakers.
If none of these solutions work, it may be time to consider contacting Altec Lansing customer support or a professional audio technician for further assistance.
