20 Most Recent Audiovox 150W DVD Home Theater System - STS93 System Questions & Answers
check the audio settings make sure they match where you plugged the source. and if all of your sources run into the tv first you will need to have an audio out to the reciver
Audiovox 150W... | Answered on Apr 25, 2010
It all depends on the TV transmission. If it is stereo, you will get the surround sound. If it is not then you have to listen to ordinary sound.
Audiovox 150W... | Answered on Dec 20, 2009
You can try lense cleaner, and if that do not work, it requires repair in which the laser assembly needs replacing cuz they do go out often. Laser diodes are easy to go bad because of current surge.
Audiovox 150W... | Answered on Nov 28, 2009
make sure that they are all from the same region. Also check to see if they are NTSC or PAL...based on your DVD player.
PLEASE VOTE IF THIS WAS HELPFUL..THANKS AND GOOD LUCK.
Audiovox 150W... | Answered on Nov 22, 2009
here is the manual for that unit. basically you have to study it and use the remote to take you to whatever section of the menu you have changed.
http://www.1800customersupport.com/productdocuments/STS93.pdf
before you do all that make sure you have not changed the tv channel away from channel 3 or 4 whichever it uses
Audiovox 150W... | Answered on Oct 26, 2009
I have similar problem with a Philips CL034 Universal Remote and a Memorex MVD2047. The Philips/Magnavox codes listed at this link did NOT resolve the problem. I tried all Memorex codes and tried the "all coded step-through" method. http://www.universal-remote.net/philipsmagnavox.html The above is NOT a solution, rather a note on a time consuming attempt to a solution.
Audiovox 150W... | Answered on Jun 15, 2009
I need the codes for a Phillips Magnavox Universal Remote for a Samsung tv.
Thanks,
Nita
Audiovox 150W... | Answered on May 25, 2009
I use a pocket knife to help mine open and then push it close. As far as i can tell the tray for this model was ill designed coupled with a crappy motor that may go out with out reason or warning...
Audiovox 150W... | Answered on Nov 07, 2008
I would get a copy of the manual first. Check the speaker settings in the menu or front panel to deterimune if the "A" channel for the front are turned on. Center speaker will work under Pro logic settings(all). A stero source is required for at least Pro Logic processing. I looked unit up on e-coustics and found some speaker set-up problems related to input level.
Audiovox 150W... | Answered on Apr 30, 2007
You need to get an HDMI cable going from your Cable Box to the Surround Sound system. If you are low on HDMI ports, you can RGB cables for Video.
Your quote: " I have a HDMI cable plugged into the TV and the Cable box." move that cable to Surround Sound and Cable Box, and use RGB cable or HDMI to go from Cable box to TV!
If your Surround Sound has no HDMI, use a Fibre Optic to go Cable to Surround. It will work Great!
Good Luck!
Audiovox Audio... | Answered on Aug 29, 2018
This item is a USB2.0 device. Older computers use USB1.0 and new computers USB3.0. Depending on your computer age, this may not be recognized. I suggest you make certain all USB device drivers are up-to-date.
Audiovox Audio... | Answered on Feb 07, 2018
26 questions posted
Top Audiovox Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
ThaMp3Doctor
ThaMp3Doctor
Are you an Audiovox Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Audiovox Audio Players & Recorders
Most Popular Question
speakers being bypassed
  • Audio Players & Recorders
