20 Most Recent Cobra 25 WX-NW-ST 40-Channels Base CB Radio Questions & Answers
No audio transmit or recive
check your final for voltage, work your way from IC 1 on up then check audio transistor . Work your way through the transmit section then the receive section . Check your volume control ,make sure its working alright Just have patience and it might jump right out at you.
3/24/2016 3:38:48 AM • Cobra 25... • Answered on Mar 24, 2016
I wish to tune and
do you have a spectrum analyzer? A function generator , bird 43 watt meter,multimeter etc. ? If you have all these then go to www.cbtricks.com and get the information you need .
2/15/2015 11:35:47 PM • Cobra 25... • Answered on Feb 15, 2015
My Cobra 25 NW ST
you probably had it plugged in wrong to begin with. get an external speaker and plug it into the external speaker plug on the back of the radio.
12/22/2014 12:32:42 AM • Cobra 25... • Answered on Dec 22, 2014
How to set the dead key on a cobra nightwatch
If you were to turn it up how would you do it ? well the process is the same but only do the opposite . you will need an external SWR Watt meter to do this correctly.
12/1/2014 12:38:09 PM • Cobra 25... • Answered on Dec 01, 2014
Channel not lighting up
check you power voltage
11/25/2014 7:27:24 PM • Cobra 25... • Answered on Nov 25, 2014
What is the mic wiring for 636l to cobra 25 wx nw st
If you have not bought it yet some dealers may have them already set up.Cobra is a popular radio so before you buy ask. you could just match it up to a cobra 25 mic though.
10/30/2013 6:58:39 PM • Cobra 25... • Answered on Oct 30, 2013
I have a cobra 25 ltd classic and im wanting to
It sounds like the switch is bad. I'd have Cobra warranty it for you.
10/18/2013 8:38:30 PM • Cobra 25... • Answered on Oct 18, 2013
2answers
Radio reception
Cb radio is line of sight. If there is a hill in the way, or some other kind of structure it will block the radio waves.
But also, radio waves, will bounce of the ionosphere and come back down.
So whats probably happening is...
You hear people close because they are near. You can't hear some one some what far away because of hills or something, but you talk to people far away because the are within range of the radio waves bouncing back down to them
8/26/2012 6:24:09 AM • Cobra 25... • Answered on Aug 26, 2012
On my Cobra 25 WX
  • What size fuse are you using? Is this radio a new radio to you? Is it new out of the box? How many muddy footprints are in it. In other words any mods been done to it? If so which?
  • Since you have your multi meter out I'd like you to look at the board that the WX/CB switch is. There will be some resistors and diodes in the general area. One or the other is not letting current flow and is blowing the fuse. Check the resistors and diodes right before the wire that goes to the board the little switch is on. Resistors can test other side and should test for the appropriate Ohms. Diodes should have current in only one direction and if it does not it is bad. If a part is suspect unsolder it to get a conformation of it's functionality. Check for bad solder joints or loose wires too.
  • You may need a new meter as well. You can get one at a great price here. http://www.texxcomm.com/ at the moment their website is being updated but he is a great dealer in CB parts.
  • Check around the mic connector on the inside of your CB. Check for cracks and loose soldier joints. This is gonna take a bit of time for you to go through things.
Regards, Tony
12/23/2011 9:40:04 PM • Cobra 25... • Answered on Dec 23, 2011
I need to know what
If your meaning a fuse its a 2amp min-5amp max...
9/26/2011 2:13:46 AM • Cobra 25... • Answered on Sep 26, 2011
Test
check check.
3/5/2011 8:12:07 PM • Cobra 25... • Answered on Mar 05, 2011
I don't know how I
it depends on what radio if you have a cobra 18wx style or maxon's, or a radioshack type the red is constant power 12v, orange is a switched 12v.. IE key like a stereo, and black is ground. if you have a 25 or 29 ltd types or exports they only have 2 wires red 12v and black ground. but you do find some power cords that have all three, and the orange on the 25 / exports are not used.
2/9/2011 3:33:43 AM • Cobra 25... • Answered on Feb 09, 2011
Wich color wire is + and wich one is -
If you have red and black wires, the black is negative (-) and the red is positive (+).
2/9/2011 1:52:36 AM • Cobra 25... • Answered on Feb 09, 2011
Cobra 25 wxnwst. no
did you repace the driver aswell
1/13/2011 7:51:11 PM • Cobra 25... • Answered on Jan 13, 2011
I CANNOT TRANSMIT
1st check mic then coxial /antinna ground/then if still haveing probblem check to see if SWR is set to antinna
1/3/2011 11:42:22 PM • Cobra 25... • Answered on Jan 03, 2011
I have a cobra 25
Hi, my name is John. Welcome to FixYa. Turn your MIC GAIN or DYNAMIC to MAX. Try another mic on it , if that does not do the job, let me know I will have further. Thanks for choosing FixYa. good luck John
10/30/2010 4:30:26 PM • Cobra 25... • Answered on Oct 30, 2010
No matter were the squelch is at it just buzzes a
Try backing off the RF gain just a bit. there is a lot of noise in the airwaves these days.
6/13/2010 3:06:27 PM • Cobra 25... • Answered on Jun 13, 2010
Can't talk to anybody, but can hear them just fine.
Could be a few things.One as simple as a bad soilder on the board or your voltage regulator could have went out. If you take the top cover off and talk in the mic and its starts transmitting then you have a bad soilder to check the regulator is a little harder and not for just anyone to do.
5/8/2010 12:25:33 AM • Cobra 25... • Answered on May 08, 2010
3answers
Blows fuses
When you open up the radio and look at the component side (top of pc board), the diode you are looking for is D17. It is located basically in front of where the PA jack connected to the pc board. Just make sure when you solder the new one in place, observe the side that the grey band is on, which should be facing toward the point of the arrow pic.
You can pick the diodes up at most Radio shacks or online through www.partsexpress.com. I use Parts Express for all of my small electrical components and tools. They are very reasonable and very trustworthy. The diode you are wanting is called a Rectifier Diode. The part numbers range from 1N4001 and 1N4008. I use 1N4007 (the only one Parts Express stocks) and it works just fine. Here is a direct link to the page with this diode http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=1N4007
They are only .09 each. I hope you get your radio back in working order.
Dean Pitts
Rollin CBs
Mt. Vernon, TX
7/3/2008 8:07:41 AM • Cobra 25... • Answered on Jul 03, 2008
2answers
Model year 2000 COBRA 25 NW ST CB RADIO
I found a download for the manual but it didn't start and IE complained about the file:
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=adb5f85959d0f501edd8fa88e16ac7a6&q=Cobra+25-NW
Maybe you will have better luck.
6/24/2008 8:31:54 PM • Cobra 25... • Answered on Jun 24, 2008
Cobra 25 WX-NW-ST 40-Channels Base CB Radio Logo
20 questions posted
Top Cobra Radio Communications Experts
Mike Cairns
Mike Cairns
eradiostore
eradiostore
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Cobra Radio Communications
Most Popular Question
blows fuses
  • Radio Communications
