20 Most Recent Panasonic CT-2789VYD 27 inch TV Questions & Answers
No horizontal and vertical deflection available:- audio OK
Check its horizontal output stage circuit. Replace damaged component/s. Vertical output stage gets its working voltage from the horizontal output transformer. If you want to get vertical deflection, this transformer, otherwise known as {LOT] should work to produce the supply voltage to vertical output stage.
10/13/2012 11:24:58 AM • Panasonic... • Answered on Oct 13, 2012
How to connect my Panasonic TH-42PW6 television with DStv decoder please?
Buy a new television! This old dinosaur appears to be made to connect to a laptop only! No HDMI ports and no Composite Video connections that I can see. You would need an HDMI to Serial Port cable https://www.manualslib.com/manual/648891/Panasonic-Th-42pw6.html#manual https://www.google.com/search?q=Panasonic+tv+th-42pw6+connect+to+DStv ..
11/20/2022 7:21:05 PM • Panasonic... • Answered on Nov 20, 2022
I cannot pair my cordless Panasonic KX-TGEA 40 handset to the base
If you only have the handset, if I remember, you have to unregister it from the base that was paired with it. If you haven't got that base unit, you are stuck. The standard reset is to remove the battery for a couple of hours.
11/20/2022 7:20:40 PM • Panasonic... • Answered on Nov 20, 2022
Panasonic TC-P42C2 Horizontal Lines in Picture
problem could also be inside the display panel.
11/19/2022 4:32:15 PM • Panasonic... • Answered on Nov 19, 2022
Panasonic Viera TH-37LZ85 television. I want to set up my tv but it's in Chinese language?
Question edited for clarity. The language of China is 'Chinese' not 'chaina'. TH or TC? This might be close enough. https://www.google.com/search?q=Panasonic+Viera+TH-37LZ85+manual ..
11/11/2022 1:25:54 AM • Panasonic... • Answered on Nov 11, 2022
My Panasonic 42 plasma turns on then off
Plasma TV sets are impossible to get parts for. The problem that you are describing could be many things but the most likey is failing capacitors in the power supply
11/4/2022 1:34:27 AM • Panasonic... • Answered on Nov 04, 2022
Pt-d5700 Panasonic projector image needs to be adjusted
You could adjust the resolution on your laptop to match the projector, before you start your presentation.
11/2/2022 8:02:17 AM • Panasonic... • Answered on Nov 02, 2022
2answers
The sound stopped working on Panasonic LCD TV model TC-32LX24. I've reset to factory defaults with no luck. Is there a PCB and / or speakers that can be replaced
Hi, You can replace parts but first I would check that your remote volume-down button isn't jammed because this might cause the volume to constantly be low or lower. I would also examine the volume-down button on your tv. Thank you.
10/11/2022 12:09:30 AM • Panasonic... • Answered on Oct 11, 2022
2answers
I have a anko big button remote and I'm trying to pair to a Panasonic plasma modelTH-42px8a I need codes thanks
These are for a Universal Remote. They might work. If not please add the remote manufactuer and model # to comments.
NEC TV 070 130 134 040 056 007 019 024 004 213
NEC VCR 012 023 043 048 039
Good luck,
Techjoel
OR
Turn on your TV.
On your Tune In remote, press TV and release.
Press and hold Set until the green light on Tune In blinks once, pauses and then blinks twice. Now release the Set key.
Enter the first three-digit TV code for your NEC from the list which follows:
030, 056, 019
These codes are listed in order of popularity, and the green light will blink twice if you perform this procedure correctly.
Aim Tune In at your TV and press Power. Your TV should turn off. If it does not, repeat steps 2-5, trying each code listed in step 4 until you find the one that operates your TV.
Now Test Your TVWhy test? Many times more than one code appears to work. Testing is desirable to be sure you have the correct code for your TV or the other devices you are setting up.
Press the Power key to turn on the TV, then press mute, channel scan ("CH") and volume ("VOL") keys. Tune channels 7 and 11 by entering the number followed by the Enter key.
If your TV does not pass the test, return to Step 2 at the top of this page. Enter the next three-digit code and repeat the process.
10/6/2022 6:39:33 PM • Panasonic... • Answered on Oct 06, 2022
2answers
My Panasonic DMP-BDT300 has suddenly stopped playing sound most of the time for DVD's? What should I do?
First try this. Does your player have a place to plug in ear phones or head phones? If so use this to see if you can get sound. Then we can work on next step.
10/5/2022 7:50:04 AM • Panasonic... • Answered on Oct 05, 2022
How can I use my GE JC012 Universal Remote to control my Panasonic PV-D4744S ?
003, 054, 055, 062, 070, 148, 149, 170, 171, 374, 381, 437 https://www.directutor.com/content/New_3_digit_codes_GE_Universal_remote_TV
9/29/2022 7:02:02 PM • Panasonic... • Answered on Sep 29, 2022
How can I use my NB100 Remote to control my dvd/vcr combo that has no remote.
google PV-D4744S remote for more. https://www.remotes.net/products/replacement-remote-for-panasonic-pvd4744s
9/28/2022 4:28:04 PM • Panasonic... • Answered on Sep 28, 2022
TH-P50V20A panasonic Viera remote codes
have you tried all these with the remote? 13833 18250 14039 15716 19503 12362 14333 12055 15532 15355 19617 15659 10508 16940 17845 12001 10916 14912 16513 18310 18810 11520 17127 17731 18649 18029 14852
9/18/2022 4:34:56 PM • Panasonic... • Answered on Sep 18, 2022
2answers
Panasonic tc-p55st60 7 blinks of red light.. replaced TNPA5764 and TNPA5717... no change what next?
Normally when the screen is blank and the power indicator is blinking, it means the TV is in the shutdown mode to protect itself. Try unplugging it for several minutes. This will give the system time to cool down and also reset itself. While it is unplugged make sure there is nothing blocking the vents and clear them of dust and debris. Use a non-abrasive cloth. (You can dampen the cloth with water, but do not use any chemical cleaners.) You can also use a can of compressed air made for electronics to help clear the vents.  If this doesn't clear up the problem, then what you read about the SU and/or SD board is most likely the issue. The number of times the power indicator light blinks in a sequence identifies for the technician what parts to test. I have included the chart for you. Because of the high voltage parts in the TV, unless you have done this type of repair before, I recommend having a technician diagnose and complete the repair. If You Need An Expert 6ya.com Best, Donald Deane MCSE,ASE,CPO
9/17/2022 12:24:45 AM • Panasonic... • Answered on Sep 17, 2022
4answers
Panasonic MODEL NO-TC21GX20CB please tell TDA12166H1/N3/3 protection pin nuber
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
9/16/2022 10:13:47 AM • Panasonic... • Answered on Sep 16, 2022
Where to print instruction manual for panasonic tape recorder model RQ-194S
These were manufactured before computers were used and it is unlikely there will be any trace.
9/12/2022 8:23:10 PM • Panasonic... • Answered on Sep 12, 2022
Panasonic CT-2789VYD 27 inch TV Logo
2 questions posted
Top Panasonic Televison & Video Experts
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Televison & Video
Most Popular Question
no horizontal vertical deflection
  • Televison & Video
