20 Most Recent
Skil 12 Volt Drill/Driver with Built In Bit Size Questions & Answers
How do i take out
Hi ladogers,
Welcome to fixya!
This
drill has a keyless chuck. To remove the bit, just turn the chuck to
the right (looking from the handle to the front) to open the jaws. To
put in another bit, tighten the chuck to the left to close. You have to
use both hands. You will see where the ridged portion of the chuck is in
two sections. Hold on to the back section with your left hand to keep
it from turning while you turn the front section with your right hand.
A
lot of the time I just push the button to put the drill in reverse,
hold on the front section of the chuck and turn it on. It will loosen by
itself. Then when you put the new bit in, put it in forward and hold on
to the chuck and press the switch. The bit will be in nice and tight.
Good luck,
Please place a vote when you accept this solution.
Thanks,
Handie Andie
How do you tighten bit?
Not 100% sure about SKIL cordless, but try turning a collar part just behind the chuck. It may be a friction chuck. Others use a hexagonal female shaft, which has a magnet inside to stop the bit falling out.
11/5/2017 5:22:48 AM •
Skil Drills
Answered
on Nov 05, 2017
I disassemble my skil power drill model 6426,
The process of reassembling must be done with your mechanically logic mind. Assemble the motor, then connect the wires to the motor. Next set the geared assembly to be connected to the motor and set the body over. You can manually turn to simulate the working and after the body is replaced and screwed the power can be connected to test. If the gear box was removed then take help if your logic does not solve.
10/1/2011 6:14:16 AM •
Skil Drills
Answered
on Oct 01, 2011
