20 Most Recent Garmin StreetPilot 2610 GPS Receiver Questions & Answers
The GPS signals will not be affected by clouds, rain, fog,
snow, etc. You probably need to relocate the position of the gps in your vehicle due to weak signal where it is now located.
Garmin... | Answered on Apr 10, 2017
No, it will need to be serviced. Please see this link:
http://www.sharc.net/gps_bootup_repair.htm
Garmin... | Answered on Jun 01, 2016
There is no battery on Garmin Streetpilot 2610 so you have to plug it in !!!!
Garmin... | Answered on Feb 16, 2014
Try calling Garmin Support for assistance.
1-800-800-1020
Garmin... | Answered on Jan 23, 2012
I'm sorry that the touch screen of the Street Pilot is not working. Please reset the GPS Receiver and it should resolve the issue. Please follow the below steps to reset the GPS system:
  1. Connect the StreetPilot to a power source.
  2. Turn off the unit.
  3. Press and hold the "Page" and "Menu" buttons.
  4. Turn on the StreetPilot while still holding down the "Page" and "Menu" buttons. A confirmation message will appear on the screen.
  5. Release the "Page" and "Menu" buttons. Tap "Yes" to confirm the reset.
Thanks for understanding. Please let me know if you require further assistance.
Garmin... | Answered on Sep 17, 2011
Back up the unit then do a master reset.
Switch OFF, Press Page + Menu and turn on, holding the buttons for 5 seconds.
Then recalibrate. I did the recalibrate a few times before it was OK. If you use a stylus when the cross appears and hold it on the screen and move it to the corners you can see the error. Make a mental note and go halfway between the two if it does not calibrate at first go. Then when it calibrates, do it again. I recalibrate every now and again. I think it could be a firmware problem. I will try going from 4.8 to an old version
Garmin... | Answered on Sep 08, 2011
You don't say what problem you are having, and I don't know what you mean by the disc.
The Garmin knows where you are, and for navigation, you don't need to tell it where you live.
You may want to reset the location for "Home" in your favorites.
Some Garmins have a security feature that requires you to enter a password, or be at a specific location, before they can be used. If this feature is enabled, and you don't have the required information, there is no easy way to override it except by sending it back to Garmin.
Garmin... | Answered on Oct 26, 2010
Get an old plug in from another device, or buy a cheap one at Radio Shack. Take the speaker apart and cut the wires to the old tip. Cut the wires from the new tip leaving a few inches to work with. Solder and tape the new to the old, and put the speaker back together.
Garmin... | Answered on Aug 24, 2010
Why not just get anouther compact flash card?
get the restoff your stuff from the garmin site?
Garmin... | Answered on Mar 12, 2010
You can take it apart and clean the visible terminals.
Garmin... | Answered on Nov 02, 2009
My 2730 would not calibrate. I saw this on a forum and it worked like a charm.
1) Fill a bowl or sink with warm water and a small amount of neutral soap. AJAX worked for me!!!!
2) Turn the SP2xxx screen down towards the water and immerse the front of the unit in the water.
3) Using a *soft* toothbrush, *gently* clean around the frame edges of the screen. With care, the soft bristles should dislodge any foreign object that may have become lodged between the screen and the unit case.
4) Rinse the front of the unit under running water.
5) Gently dry the outside of the unit with a soft towel or cloth.
6) If desired, leave the unit in a warm airing cupboard overnight to completely dry out.
Hook up the unit and try it out! All reports I've read elsewhere reported that the touch screen worked again after this process. If it fails, you were going to send it back to Garmin anyway so you haven't lost anything by trying it. This worked and I plugged it in right after with hair drying on cool for a couple minutes.
Garmin... | Answered on Aug 28, 2009
http://www8.garmin.com/manuals/StreetPilot2610GPS_OwnersManual.pdf
My suggestion is to verify the batteries...regardless if its connected to another power source .....I attached a manual .and any other issue should be there ...but ..removing the memory card ..and the inside batteries should reset it anyway ...also ...try to look for a small hole ...just like the ones on modems...usually this is the way the reset button is present ..(as a protection )..
Garmin... | Answered on Jul 16, 2009
Garmin StreetPilot 2610 GPS Receiver Logo
Popular Tags
56 questions posted
Top Garmin GPS Experts
Marvin
Marvin
John Egan
John Egan
Janelle Schoonover
Janelle Schoonover
Are you a Garmin GPS Expert? Answer questions, earn points and help others
View Most Popular
StreetPilot Garmin
  • StreetPilot Garmin
Most Popular Question
when try unlock maps wizard tells me
  • GPS
