20 Most Recent GE 27GT619 27" TV Questions & Answers
0answers
27GT624
Be the first to answer 2/25/2014 4:01:48 AM • GE 27GT619 27"... • Posted on Feb 25, 2014Be the first to answer
TV to AV mode
you can press the tv/av button at the tv front panel button or through the remote controller.
12/24/2012 1:18:51 AM • GE 27GT619 27"... • Answered on Dec 24, 2012
The image is zoom in,
observe the tv if its focusing well..if not the,the horizontal stage is defective..if the focusing is ok,you need to set the unit to service mode to make the adjustment nessesary to fixed the problem..or sometimes ther is an internal adjustment..if you are lucky enought
7/19/2011 12:09:51 PM • GE 27GT619 27"... • Answered on Jul 19, 2011
Where can I get an
Try website like Remotes.com should have an original remote or very close to it.
12/31/2010 10:06:22 PM • GE 27GT619 27"... • Answered on Dec 31, 2010
TV just went off and wont turn back on, Is there a reset button?
There is no reset button per say, try unplugging the tv for a few minutes and plug it back in again and see if it will reset. If not then you may have a component failure in your set.
9/2/2009 12:45:49 AM • GE 27GT619 27"... • Answered on Sep 02, 2009
2answers
DVD player won't work on my 27gt615
alexa,
good day, if youre saying that you program the DVD to work on channel 2 or 4 does it mean you convert the signal of your dvd player from A/V output to RF out?
because the simpliest way to connect your DVD player to TV screen is by using RCA cable ( 3 wired cable being color marked as yellow/red/white) yellow = video red and white = audio
the connection would be: from dvd back part you'll see colored socket yello/red and white. connect the RCA to those socket following the same color .
and from the TV screen there should be A/V input socket. can be locate at the BACK/Side or FRONT of the screen marked as
"INPUT" ( AV1, AV2,AV3 if multiple inputs). Then select which input you want to place your DVD player ex.AV1 (from AV1 there will be 3 scoket in a row, yellow/red/white)
Connect the other end of your RCA cable following the same color code to TV "AV1 INPUT" yellow = yello/red =red/white=white. then from the remote commander of your TV screen locate a button marked as "TV/AV" or "A/V" press this button until the screen display switch to AV1.
cheers,
mark
8/4/2009 11:35:49 PM • GE 27GT619 27"... • Answered on Aug 04, 2009
GE 27GT613 tv. has no video button
Use the remote to tune to channel 00. THis will give you the component inputs. The channel up down buttons will skip it so you have to actually push 00 on the remote.
2/24/2009 8:42:55 PM • GE 27GT619 27"... • Answered on Feb 24, 2009
Focus the picture on a Model 27GT619 Television
The focus control is on the flyback transformer (Usuallly black or brown with three wires coming out of it. The bigger wire goes to the pix tube with a rubber cap at the end.) The focus control is on the side. There are two. The top is focus. Good Luck!
1/13/2009 5:15:26 PM • GE 27GT619 27"... • Answered on Jan 13, 2009
Not actually a problem...
don't actually have a problem with my set. i need to find an owners/users manual and a remote for it. its been in storage for a little while and i cant remember how to do anything with it. and some feature need the remote i think, which i don't have. if anyone can help me find one i can download i would be very thankful. i've been searching for over 6 hours. plesae refer www.eserviceinfo.com for manual& circuit. for owner manual please contact manufacture. remote control easily available in market accordindg to model no. thanks
9/11/2007 9:42:23 AM • GE 27GT619 27"... • Answered on Sep 11, 2007
Green tint on screen
Is it a green tint at some areas alone, oris the entire image having a green tint? If it is a color patch at the corner or other areas of the screen, in all likelihood it is a degaussing problem. Color patches happen when the TV is moved from one location to another, or if some magnetic source is placed close to a CTV. Did you put a radio or Tape recorder or Walkie talkie toy or any magnetic source near the TV? if yes, remove it. And the automatic Dregaussing circuits in the TV will resolve the problem in a couple of days. But if there is an overall Green tint on the picture, it signifies a problem in the Video output stages, and there is nothing you can do, but call the technician (unless you know solid state servicing?)
8/8/2007 2:38:52 PM • GE 27GT619 27"... • Answered on Aug 08, 2007
Tv problem
Does it like tune and detune and then retunes back to a pic all by itself??? sounds like the typical problems rca/ge sets mostly have in common with bad tuner grounds.. you must open the set remove the bottom tuner sheild and resolder all the grounds along with the little post that hold on the sheild to the tuner. Now this is not a job for the hobbiest!!! You can cause a small solder splash and ruin the set for life cause you may think that you got out that little solder splash BUt unaware to you you also have taken out some very tiny parts that look like a pieces of dirt that are surface mount resistors and capacitors.
3/24/2006 4:59:27 PM • GE 27GT619 27"... • Answered on Mar 24, 2006
I can't find a code that works to program my ge universal remote to my trutech tv/dvd combo
most universal remotes are not compatible to tv/dvd combo units
10/6/2021 2:15:15 PM • GE Televison &... • Answered on Oct 06, 2021
2answers
I have a ge uni remote and cant figure out how to
Just download the user manual to your converter box from net. It wil have all details.
9/27/2021 4:28:45 AM • GE Televison &... • Answered on Sep 27, 2021
The clock on my GE range is flickering (not flashing). I have tried to reset the clock, but that does not work.
check voltage to clock possible bad transformer or board
8/12/2021 5:07:02 AM • GE Televison &... • Answered on Aug 12, 2021
My ge microwave door fogs up,
Will using microwave don't cover it. it might don't led to fog again
7/15/2021 10:46:23 AM • GE Televison &... • Answered on Jul 15, 2021
Need code for ge universal r here
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name of your device in its search box at the right column of the display window. It will help you to find the details easily. https://homenol.blogspot.com/ https://elektrotricks.blogspot.com/ https://remotesearch.blogspot.com/ https://electrohelponline.blogspot.com/
7/11/2021 1:25:52 PM • GE Televison &... • Answered on Jul 11, 2021
Televison & Video Logo
Popular Tags
18 questions posted
Top GE Televison & Video Experts
 Francisco Mauricio...
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • GE Televison & Video
Most Popular Question
codes universal remote 27gt619 27 tv
  • Televison & Video
