20 Most Recent GPX DV7500 System Questions & Answers
Hi, Open the CD and press return on the remote to reset it back to Interlace mode. Thanks Annarr
GPX DV7500... | Answered on Oct 30, 2014
tweezers...
GPX DV7500... | Answered on Apr 25, 2012
There is a small strap that looks like a black rubber band that actionate the door mecanism. open the cab and clean it with qtip and alcohol, otherwise replace it, you'll find some at local electronics parts shop...
GPX DV7500... | Answered on Oct 08, 2009
hello there. name is ryan lets see if this helps.
typically in a combination unit there is no rca audio ouputs on the tv. reason being is it is a combo unit not meant to be a item within a home theater system. it has the whole home theater built in it. ;) however if there is any audio output jacks on the tv you should be able to wire the surround sound unit up via rca cable output from tv to input on reciever for surround sound
GPX DV7500... | Answered on Feb 18, 2009
You can get a user manual from http://manualfox.com
Just send them a search request.
sounds like you gotta power supply problem in the main unit. to repair this your gonna need a service manual most likely or you have to take it in to a repair shop to estimate for you .. if you post a schematic we will assist you in trouble shooting if you have any previous experience. Good luck.
GPX DV7500... | Answered on Jan 02, 2009
I've seen this problem before with devices that have audio amplification circuitry.
In the cases I've seen, the connections to the speakers were the culprits.
First of all, you should only use the GPX speakers that came with the device. I don't know what their impedance is, but if it was 8ohms, you should only use 8ohm speakers. The same for 4 ohm, 6 ohm, etc. The safe bet is to use the speakers that came with the system.
If you are using the intended GPX speakers, and they're hooked up correctly, (only one speaker per output) then I would suspect a short in at least one of the speaker wires.
Amplification circuits apply fluctuating power to the speakers which correlate the sound wave. The power reaches the speaker, has an electromagnetic effect on the speaker cone, which pushes it out or pulls it in. This produces sound. The speakers job is to be affected by the amplifier, and convert the electric power into a mechanical movement. Speakers of different impedances respond to different levels of power. Ideally, your amplifier will supply power to speakers that will use it all up and return none.
An amplifier designed to drive 8 ohm speakers will get too much kickback from little 4 ohm speakers. When I've seen this sympton before, the amplifier had another circuit designed to monitor dangerous conditions such as this and shut down to prevent permanenet damage. Another dangerous condition might be a short in one or more of the speaker wires. Inspect each and make sure none got stuck under the table, or slammed in a drawer or pinch by a staple or whatever.
--Matt
GPX DV7500... | Answered on Nov 02, 2008
hi the remote isnt the problem check the connections from the deck to the TV the little angle probably pulled a couple of pluges back there or something like that... very dangerous by the way he can get electrocuted!! have a good one
GPX DV7500... | Answered on Apr 02, 2008
sounds like a bad solder joint that is cracked...as GPX heats up, the crack starts to get bigger and cutting off electric circuit, then cool down closes the gap and current resumes. First try breaking and then making all possible connections outside then inside unit. Then, if no success, remove the circuit board and clean it with alcohol and brush then carefully look at each solder joint with a magnifying glass. If one found, simply re-solder it.
GPX DV7500... | Answered on Nov 27, 2007
Sorry I don't have a solution. We have this model and ours is loud also, at the very lowest setting. I disconnected some of the speakers, and sometimes have to put the working speakers into a drawer to lower the sound.
GPX DV7500... | Answered on Dec 12, 2006
This is a website for the soundbar.
https://gpx.com/in-home/home-music-systems/18-sound-bar-with-bluetooth-wireless.html
There is a pdf of the manual on the page
Regards
Geoff
GPX Audio... | Answered on Jan 08, 2020
Most of those types of screws only require a 1/2 turn to unlock.
GPX Audio... | Answered on Dec 11, 2019
GPX DV7500 System Logo
19 questions posted
Popular Products
Top GPX Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Ekse
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • GPX Audio Players & Recorders
Most Popular Question
gpx dv7500 dvd player will not power
  • Audio Players & Recorders
