20 Most Recent GPX HTD2804DT System Questions & Answers
Here is the link for the user manual if you need it; http://www.gpx.com/supp_dnld.php?&cod=146&code=DVD# I am assuming that power is on and you have tried the eject button. If you feel confident to try, then unplug machine and take off the top cover (looks like 5 screws at the back and then it should lift forward and up (just possibly the volume knob will need pulling off too, but maybe not) being careful not to touch anything inside, plug the machine back in and try eject and see if anything moves inside at all. sometimes cables can get bent in such a way as to block the tray form coming out. If you get nothing at all then i suspect either the tray drive motor is faulty, or the section of the power supply that powers it has failed. Just have a look in the back left corner where the power cable goes into the box and see if there are any fuses and check them. try plugging the machine into a different power socket in a different room just in case the supply voltage is the problem, if that works then call an electrician. Hope this helps :)
GPX HTD2804DT... | Answered on Mar 17, 2007
This is a website for the soundbar.
https://gpx.com/in-home/home-music-systems/18-sound-bar-with-bluetooth-wireless.html
There is a pdf of the manual on the page
Regards
Geoff
GPX Audio... | Answered on Jan 08, 2020
Most of those types of screws only require a 1/2 turn to unlock.
GPX Audio... | Answered on Dec 11, 2019
What happens is that a mechanical system under the turntable pushes on a micro switch to operate the motor. Clearly either the mechanical system has moved out of position or the switch has. You take the bottom off the turntable and see what happens when you move the arm.
GPX Audio... | Answered on Oct 19, 2018
Google (gpx)(sp60)(manual) without parens for instructions.
GPX Audio... | Answered on Sep 10, 2018
Google (GPX)(D606)(manual) without parens.
GPX Audio... | Answered on Sep 01, 2018
Google (gpx)(KC 220s)(manual) without parens.
GPX Audio... | Answered on Aug 11, 2018
First, I'm not a GPX reapresentative.
* Check your warranty. Call for support.
* User instructions; https://images-na.ssl-images-amazon.com/images/I/B1JjZHqCJCS.pdf
* Customer help line; 888-999-4215
*** Following is for information only.***
* Specs; https://www.bestbuy.com/site/gpx-micro-hi-fi-system-black/2878063.p?skuId=2878063
* Amazon also supports this brand; https://www.amazon.com/GPX/b/ref=bl_dp_s_web_2529506011?ie=UTF8&node=2529506011&field-lbr_brands_browse-bin=GPX
* Cnet review; https://www.cnet.com/products/gpx-hm3817dt/specs/
* Another model review; https://www.youtube.com/watch?v=cJIx-x45LYQ
Aloha, ukeboy57
PS; If your using a 3d party remote (that must be GPX compatible)then the codes will be on the (remote)papers.
GPX Audio... | Answered on Aug 03, 2018
Whats rong w it
GPX Audio... | Answered on Jul 29, 2018
First check if the tape is moving during playback. If it is not there could be something wrong with the mechanism, such as a drive belt being off. If it is moving. Then it could be that a tiny leaf switch has become broken or bent cutting the sound off. Other issues include a faulty switch that controls the switching from the radio to tape. Could be just dirt in the switch. Or the pre-amp failure of the cassette player.
GPX Audio... | Answered on Jun 25, 2018
Google (GPX)(C224B)(manual) without parens for instructions.
GPX Audio... | Answered on May 31, 2018
GPX HTD2804DT System Logo
2 questions posted
Popular Products
Top GPX Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Ekse
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • GPX Audio Players & Recorders
Most Popular Question
dvd player
  • Audio Players & Recorders
