20 Most Recent
ICOM Informatique IC-F121 VHF 136-174MHz mobile 128Ch 50W Microphone Questions & Answers
Ipod ma446zp
Not all iTunes video can be transferred to iPod, please make sure your video is compatible with iPod. If the video resolution or video bit rate beyond iPod limitation, even though they are mp4 video, you can't upload them to iPod. For example, some iTunes purchased movie are High definition movie, the resolution is too high to play on iPod, you can't sync it to your iPod. For more information about iPod compatible video, you can visit apple official website. Or you may take a look at this step by step direction, it's about how to convert and put video to iPod, it works pretty well for me.
http://www.dvdintoipod.com/how-to-convert-dvd-video-to-ipod.html
Hope it helps. Contact me if you need further assistance.
Audio Players &...
Answered
2 days ago
McIntosh MC7106 Amplifier not powering up
It can be a variety of reasons but I feel that your amplifier is shutting off after powering on. There is nothing that can be done from the outside but If you are familiar with basic electronics and can attempt to take a look I can try. Open the set after you have pulled off the power, then look into the set and tighten all the connectors and cords. Power on and see where the click comes and goes off. If the relay is not holding on then your protect circuit is shutting it off. Armed with a multimeter turn on the power and check if the main +B power is coming to the output stages.If there is momentary swithch on , then disconnect power and test the continuity in the output stages. If hsort open the leads to the output section and then power on. If the relay stays we have found the fault. you can go on to change the failed outputs. If however the outputs were tested ok, then your fault could be the relay or the protect circuit, Hold a rely for a moment to see if the amplifier powers on, if so check the relay drive transistor , the biasing to the stage. Try this out and I hope my advice helps. Good day
Audio Players &...
Answered
3 days ago
