20 Most Recent Jensen MP5620 CD Player Questions & Answers
she's gone, i have same problems.. buy a cig lighter mp3 player with remote for less than $10 and just tune ur radio into the brodcast station
Jensen MP5620 CD... | Answered on Sep 21, 2010
I dont know if this will work for the mp, but for my jensen 2010x ,while it is on, you press on the (disp) button for 5 seconds untill the clock starts flashing, then on the FF to set minutes and the rewind button to set hours. I literally spent 2 hours playing with it till i figured this out!!!
Jensen MP5620 CD... | Answered on Aug 11, 2007
poor connection somewhere or heat problem causing cold solder joint as such to lose conductivity. Time to look for it using cold spray. Good luck
Jensen MP5620 CD... | Answered on Mar 05, 2006
I used to own Jensen cd player for a while but I can't remember the solution of loop loading. Check Jensen cd-players manuals http://jensen.manymanuals.com/cd-players
Jensen Car Audio... | Answered on Nov 21, 2020
There is always a chance that you "bricked" the unit with the update. IT happens. When you get to the cross hairs you are supposed to hold your finger in the middle till it asks for the next step. IF it wont go to this, then can you retry the whole process over again. If not you have bricked it and it has to be sent in for reflash
Jensen Car Audio... | Answered on Nov 10, 2020
In the back of the set you should find a small 'spade' type fuse, replace with Fuse: 15-amp, mini ATM type
There is a fuse holder in on the yellow wire on the wiring harness, pull out the unit and replace fuse.
User manual: http://www.jensenmobile.com/docs/common/UV10/UV10_OM.pdf
Wiring diagram http://www.manualslib.com/manual/674477/Jensen-Uv10.html?page=4#manual
Good luck.
Jensen Car Audio... | Answered on Aug 06, 2020
I just purchased the VX7020 and went to Settings-Language-typed in 5,4,3,2,1,0 but the menu never came up. Any ideas?
Jensen Car Audio... | Answered on May 20, 2020
This info is on the bottom of it.
Jensen Car Audio... | Answered on Mar 15, 2020
Ground - negative
12v positive - switchable positive (for example, on when ignition is on, usually connected to accessory side on ignition switch)
auto ant - connected to your electric antenna or to turn on external amplifier.
Memory - connected to always on positive (to keep all your stereo presets )
Jensen Car Audio... | Answered on Feb 11, 2020
YOU HAVE TO GO INTO THE MENU SETTING
Jensen Car Audio... | Answered on Sep 12, 2019
Ribbon from player to screen not properly connected or broken due to unfolding and folding.
Jensen Car Audio... | Answered on Jul 17, 2019
Jensen MP5620 CD Player Logo
Popular Tags
7 questions posted
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Muntejaya Ginting
Muntejaya Ginting
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Jensen Car Audio & Video
Most Popular Question
jensen mp5260 wont play any cds
  • Car Audio & Video
