20 Most Recent Jensen MP5720 CD Player Questions & Answers
Best bet, find a non working pioneer with the same plug and salvage it. try repair shops or ebay.
Jensen MP5720 CD... | Answered on Mar 14, 2010
7. Clock
CLOCK DISPLAY
Press the DISP (16) button to show the clock in the display. The clock will display for a few
seconds and then return to the previous display.
CLOCK ADJUSTMENT (TIME)
Press the DISP (16) button to show the clock, and then press the DISP button again and hold for
> 3 seconds until the clock flashes. Press the DOWN TUNING (<<-) button (18) to change the
minutes and UP TUNING (+>>) button (17) to change the hour. Continue changing the hour to
move between AM and PM.
Here is a link to the manual where this text cam from:
http://www.audiovox.com/manuals/owners/MP5720_123103_FINAL.pdf
Jensen MP5720 CD... | Answered on Jun 01, 2009
I was always afraid this might happen to me so I never removed the faceplate from the radio. This strategy worked fine for two years until two weeks ago. I didn't lock my car because of the freezing rain and somebody stole my faceplate and remote. Anyway I ordered a replacement radio from Amazon last week so I don't have rewire a new one. The replacement cost me $100. I don't really need the rest of the radio so make an offer, my email is [email protected]
Regards, Chas
Jensen MP5720 CD... | Answered on Jan 17, 2009
the auxiliary input is the 2 RCA cables dongling out of the rear of the unit , you can get an adaptor to turn them into a jack , or an adapter cable for your ipod to jack into the rca inputs .
Jensen MP5720 CD... | Answered on Jan 03, 2009
Do you get sound when you use the radio? If so, the blue wire from the back of the radio needs to be disconnected and you need to use the blue/white wire instead.
If that doesn't work, try connecting either a test speaker or one speaker at a time. Your problem could be a short in the wiring - if the (+) wire to a speaker is touching the (-) wire, the deck will cut out all sound to keep itself from overheating. Let me know if you need more help.
Jensen MP5720 CD... | Answered on Mar 14, 2008
It could be that the wires in the harness that go to speaker from stereo are not connecting to the leads on the stereo. If this is the case the wires to speakers are not connecting, but the wires from the power source are still good. Try taking the harness out of the back of the stereo that connects all the wires to the leads. Hopefully your wiring is labeled from the factory. If it is it might say "Left front speaker". Isolate this wire and wiggle it inside the harness back and forth. If it moves even a 1/16 of an inch it may be that the leads are not connecting. You can try jerryrigging it by shoving something in their in hopes that it will hold it in place. You may need to replace the harness.
Jensen MP5720 CD... | Answered on Jan 04, 2008
What type of vehicle is it in? Is there a blue/white wire connected?
Jensen MP5720 CD... | Answered on Sep 22, 2007
I used to own Jensen cd player for a while but I can't remember the solution of loop loading. Check Jensen cd-players manuals http://jensen.manymanuals.com/cd-players
Jensen Car Audio... | Answered 2 days ago
There is always a chance that you "bricked" the unit with the update. IT happens. When you get to the cross hairs you are supposed to hold your finger in the middle till it asks for the next step. IF it wont go to this, then can you retry the whole process over again. If not you have bricked it and it has to be sent in for reflash
Jensen Car Audio... | Answered on Nov 10, 2020
In the back of the set you should find a small 'spade' type fuse, replace with Fuse: 15-amp, mini ATM type
There is a fuse holder in on the yellow wire on the wiring harness, pull out the unit and replace fuse.
User manual: http://www.jensenmobile.com/docs/common/UV10/UV10_OM.pdf
Wiring diagram http://www.manualslib.com/manual/674477/Jensen-Uv10.html?page=4#manual
Good luck.
Jensen Car Audio... | Answered on Aug 06, 2020
I just purchased the VX7020 and went to Settings-Language-typed in 5,4,3,2,1,0 but the menu never came up. Any ideas?
Jensen Car Audio... | Answered on May 20, 2020
This info is on the bottom of it.
Jensen Car Audio... | Answered on Mar 15, 2020
Ground - negative
12v positive - switchable positive (for example, on when ignition is on, usually connected to accessory side on ignition switch)
auto ant - connected to your electric antenna or to turn on external amplifier.
Memory - connected to always on positive (to keep all your stereo presets )
Jensen Car Audio... | Answered on Feb 11, 2020
YOU HAVE TO GO INTO THE MENU SETTING
Jensen Car Audio... | Answered on Sep 12, 2019
Jensen MP5720 CD Player Logo
13 questions posted
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Muntejaya Ginting
Muntejaya Ginting
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Jensen Car Audio & Video
Most Popular Question
set time car stereo set time jensen mp
  • Car Audio & Video
