20 Most Recent Kenwood KDC-W6027 CD Player Questions & Answers
Code put in wrong 4times;
try pressing the reset switch.
7/11/2020 2:18:26 AM • Kenwood... • Answered on Jul 11, 2020
0answers
Hi , i forget miss
The whole point of a security code is to be secure. if you could just post on a public website and get the code by return it would, by definition, be insecure and totally useless.
First, check all the the vehicle paperwork as the code is often printed on a card or written in the service book.
If that fails then you must contact Kenwood with proof of ownership, in some territories they charge a fee. If you can't prove ownership then the head unit becomes a spare parts donor.
You will find advertisers on auction websites and similar offering to sell codes, but you pay your money before you find out whether the code works. When you complain you'll then find out whether they honour their pre-sale promises of a refund. When you complain to PayPal you'll find that non-tangible goods aren't covered. In short, you take a big risk on being scammed.
2/23/2011 12:09:23 AM • Kenwood... • Answered on Feb 23, 2011
0answers
Unlock codes for a Kenwood KDC-W6027
Please see my fixya tip CLICK HERE for unlocking Kenwood radios.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
4/22/2010 9:23:39 PM • Kenwood... • Answered on Apr 22, 2010
Kenwood head unit not powering up help please.
find your remote wire. it would help to know the type of car and the kind colors of wires your using as your 3 main wires.
normally in most chevy and fords they are yellow 12 volt.
black as ground.
red sometimes even a tan as your remote start.
deff check your start
5/27/2009 2:16:55 AM • Kenwood... • Answered on May 27, 2009
My kenwood kdc-u2159b display call n no sound out
Me radio kdc2159b is displaying the ward call,how do i remove it
4/14/2024 10:44:35 AM • Kenwood Car... • Answered on Apr 14, 2024
Reset a Kenwood 8070 without a remote?
To reset a Kenwood 8070 receiver without a remote, you typically need to locate the reset button on the device itself. This button is often small and recessed, so you may need a paperclip or a similar tool to press it. Consult the user manual or look for the reset button near the power or input/output ports on the receiver. Once located, press and hold the reset button for a few seconds until you see the receiver reset. Keep in mind that this process may vary slightly depending on the specific model of the Kenwood 8070 receiver.
3/6/2024 3:50:24 AM • Kenwood Car... • Answered on Mar 06, 2024
KDC-138 CD PLAYER/RECEIVER. What does code E-004 indicate?
Kenwood KDC-138 Instruction Manual [Page 18]
ManualsLib https://www.manualslib.com > ... > Instruction manual If the "E-99". code does not disappear, consult your. nearest service center. IN (Blink):. The CD player section is not operating. properly. ? Reinsert the CD.
My Kenwood KDC-d301 is giving me a E-4 error message ...
JustAnswer https://www.justanswer.com > car-electronics Aug 9, 2010 - Hello, The issue is most likely that the laser lens in the CD player itself is dirty, and not the disc. It may have been initially caused by a ... 1 answer · Top answer: You need the Kenwood radio keys that came with the unit to slide it out of the dash. It sounds ... Missing: 138 ‎' Show results with: 138
I have a KDC 138. It is stuck on OCER and will not reset.
JustAnswer https://www.justanswer.com > car-electronics > 5lw8u-... Sep 27, 2011 - This actually is DCER - you have a blown speaker. The radio is sensing a ground on the speaker circuit. Check that and let me know. If you leave ... 1 answer · Top answer: Thanks for stopping by: This actually is DCER - you have a blown speaker. The radio is sensing ... Missing: E- ‎' Show results with: E-
Cd Player Unit - Kenwood KDC-138/138CR Service ...
ManualsLib https://www.manualslib.com > ... > Service manual Kenwood KDC-138/138CR Manual Online: components description, Electric Unit, Switch Unit, Cd Player Unit. Controls Fm/Am Tuner, The Changer, Cd Mechanism, ...
2/16/2024 6:44:56 PM • Kenwood Car... • Answered on Feb 16, 2024
How to power supply of kCSWA900 Kenwood sub whooper power supply 10 pin
Take a look at this manual diagram. https://www.manualslib.com/manual/359815/Kenwood-Ksc-Sw10.html?page=5#manual Given the above is not your model, at least it shows the 10 pin. Ironically, below I offer a diagram of your model. The irony comes in the fact that the diagram appears labeled in Japanese But if you compare the two diagrams, maybe something will make sense from the one with the English labels. Otherwise, you might fire off a query to Kenwood customer support. https://www.manualscenter.com/manuals/kenwood/kscsw900-owner-manual.html Here is a 10 pin harness compatible with the subwoofer. Kenwood Subwoofer Amp KSC Wa100 Wa80 Sw10 10 Pin Harness for sale online ' eBay I don't have any information on how to power supply a kCSWA900 Kenwood subwoofer. However, I can tell you that the Kenwood KSC-SW10 compact powered subwoofer has a built-in amplifier with a 38 watts RMS power and a wired remote for control over volume level, variable low-pass crossover (50-120 Hz), and selectable phase control (0°, 180°) . The subwoofer comes with a power/ground wiring harness and preamp (RCA) and speaker-level inputs .
1/26/2024 3:58:54 AM • Kenwood Car... • Answered on Jan 26, 2024
2answers
I have 2 mtx 12"woofers (8ohms each wired parallel to get to 4ohms) which Kenwood amp would be best to use: kac-7252 or kac-9104d?
The Kenwood KAC-7252 and KAC-9104D are both great amps, but they have different strengths and weaknesses. The KAC-7252 is a 5-channel amp that can output 75 watts per channel at 4 ohms. It also has a built-in crossover and time alignment, which can be helpful for getting the most out of your woofers. The KAC-9104D is a 4-channel amp that can output 100 watts per channel at 4 ohms. It also has a built-in subwoofer output, which can be used to power a separate subwoofer. If you are looking for an amp that can power all of your speakers, the KAC-7252 is a great option. It is also a good choice if you want an amp with built-in crossover and time alignment. However, if you are looking for an amp that can power a subwoofer, the KAC-9104D is a better choice. It is also a good choice if you want an amp with more power output. Ultimately, the best amp for you will depend on your specific needs and budget. If you are not sure which amp is right for you, it is always a good idea to consult with a professional car audio installer. Here is a more detailed comparison of the two amps: Kenwood KAC-7252
  • 5-channel amp
  • 75 watts per channel at 4 ohms
  • Built-in crossover and time alignment
  • MSRP: $399
Kenwood KAC-9104D
  • 4-channel amp
  • 100 watts per channel at 4 ohms
  • Built-in subwoofer output
  • MSRP: $499
I hope this helps!
12/13/2023 2:44:37 PM • Kenwood Car... • Answered on Dec 13, 2023
3answers
- Kenwood KDC-X396 the Brown mute wire gets connected to what to get the phone to work through it
whatever makes it mute from whatever it is you are in
12/5/2023 7:21:12 AM • Kenwood Car... • Answered on Dec 05, 2023
MANUAL for kenwood dpx-6200m
12/5/2023 6:53:47 AM • Kenwood Car... • Answered on Dec 05, 2023
2000 Subaru outback w type c radio/CD/weather replacement
This often doesn't work because the radio is monitored by the Body Control Module on the 5 volt computer network. Wiring
Subaru Legacy, Outback, Baja (1993-2008) Car Stereo ...
Pinout Guide https://pinoutguide.com > ... > Subaru pinouts Oct 22, 2019 - Pin #. Function. Legacy / Outback / Baja Factory Radio Connector Wire Color (wires go to car's Speakers, etc.) Subaru After-market Harness ...
2000 Subaru Impreza Car Stereo Wire Colors and Locations
the12volt.com https://www.the12volt.com > installbay > stereodetail 2000 Subaru Impreza Stereo Wiring ; Left Front (-), Green/Black ; Right Front (+), Red/Yellow ; Right Front (-), White/Black ; Rear Speakers, 6 1/2" Rear Doors. Installation kits https://www.google.com/search?q=2000+subaru+outback+stereo+installation+kit ./.
11/4/2023 3:37:26 PM • Kenwood Car... • Answered on Nov 04, 2023
Kenwood pm900 got to keep my finger on the green buton to work
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjVy_3gwJSCAxXPtokEHVevBRMQFnoECA8QAQ&url=https%3A%2F%2Fwww.fixya.com%2Fsupport%2Ft20296183-kenwood_pm900_only_runs_hold_green&usg=AOvVaw1SY6YdYg_TxXi9l6iEL8Xc&opi=89978449
10/26/2023 8:02:28 PM • Kenwood Car... • Answered on Oct 26, 2023
Kenwood KDC-W6027 CD Player Logo
Popular Tags
11 questions posted
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Kenwood Car Audio & Video
Most Popular Question
code put in wrong 4times
  • Car Audio & Video
