20 Most Recent Kenwood KDC-116S CD Player Questions & Answers
Yes.
The YELLOW wire is connected to 'constant' 12v power. This is necessary for the receiver to retain the memory settings (i.e. station presets etc).
So, yes... your unit will draw power, but this will be very minimal.
Try disconnecting the Yellow wire for a few days and see if this makes any difference. If not, you will need to inspect the wiring loom to determine if there is another short somewhere. If everything looks ok, then the short must be somewhere else, within the vehicle.
Kenwood KDC-116S... | Answered on Mar 04, 2013
You can get the wire diagram on the link below page 26.
http://a248.e.akamai.net/pix.crutchfield.com/manuals/113/113kdc116s.pdf
Kenwood KDC-116S... | Answered on May 17, 2011
are there rcas on the back of the deck that say subwoofer????? if not then there is probably not . you can also go into the menu and see if it has subwoofer on/off.
Kenwood KDC-116S... | Answered on Aug 31, 2010
My Advise is to REWIRE all SPEAKERS SEPERATLY & INDEPENDENT From Factory Wiring, as it is Safer to do this than to INCORPERATE Your Sterio Wiring into the Original Wiring, Some Vehicles Use Spicific Wiring to OTHER Components. I'm Sure this is NOT the Answer you WANT But I have Installed more than I can Countof Stereo Systems into Cars/Trucks ,Tractor trailers and Inicialy I Only Ran Into PROBLEMS When Incorperating into Factory Wiring Thus I Refined MY METHOD By Simply Wiring all EXEPT the BATTERY & IGNITION < Key ON Wires. ONE SLIP In INCORPERATING INTO FACTORY WIRING Can CAUSE SERIOUS PROBLEMS/DAMAGE the ELECTRICAL SYSTEM. I Realize that in MANY Vehicles this CAN and HAS Been DONE But at the Same time When you ISOLATE the NEW STEREO WIRING You KNOW EXACTLY what you Have. As Far as Color Codes they CAN and DO VARY from Year to Year and Makes Also. What I am Recomending May be SLIGHTLY more Expensive and Require Some Time BUT the End Result will be Well Worth it. Thank you for your time !
Kenwood KDC-116S... | Answered on May 12, 2010
is there a cd stuck inside??
Kenwood KDC-116S... | Answered on Jul 19, 2009
Read your user manual and type in the code.
Kenwood Car... | Answered 3 days ago
just been in the same situation having swapped cars press
Together the little triangle (need a pin) volume button in and the power button or the one below it if power doesn't work
Kenwood Car... | Answered on Sep 07, 2020
1. Open fuse
2. Defective power switch
Kenwood Car... | Answered on Aug 03, 2020
Any video file that is .avi requires codecs. Most players don't have a comprehensive list of codecs on their chips though they have divx and xvid on many devices these days. divx and xvid are codec types of .avi. Types such as .mpg or .mpeg or mp3 or mp4 are older and more compatible with most equipment. mkv may not work
Kenwood Car... | Answered on Jul 25, 2020
is the volume controled on the phone? then you might want you dail it up before turning on the kenwood.. also make sure that your phone is in an accepable bluetooth distance
Kenwood Car... | Answered on May 06, 2020
Data science is on a rapid growth trajectory which is finding a place for itself in all industries that exist in the world today. Healthcare and medicine are integral parts of our lives because in the face of any ailment, we rush to hospitals and surrender ourselves to their care. The traditional way of diagnosis was based on doctors, treatment was also by doctors. But technology in the healthcare industry has moved leaps and bounds in its application. Human error was taken into consideration and hence, a shift towards advancement in computers and computer-based treatments was deemed necessary to increase precision and success-rate.
Getting into the data science aspect
With the advent of data science, today, accurate diagnostic measures are obtainable. Medical imaging, genetics, **** discovery and many other fields within healthcare also depend on data science. Various imaging techniques like MRI, CT scans, X-ray etc are used to observe the inner parts of the body. With deep learning technologies of data science making its way into this technique, now, doctors are able to detect microscopic deformities in these scanned images. Image segmentation and processing also helps in enhancing and reconstructing these images.
Data science and genomics
The sequencing and analysis of genomes is called genomics. Organizations used to invest a lot in analyzing the sequence of genes before big data and data science entered the scene. It was a time-taking, expensive ordeal. Now, advanced data tools analyze and derive insights in a much shorter time and for lesser costs. Data scientists analyze genetic sequences and find correlations between parameters contained within.
Predictive analytics and healthcare
This is one of the most important domains of data analytics. The predictive model utilizes historical data to find patterns and generate accurate predictions. Various correlations and association of symptoms is done between habits and diseases and this ultimately results in meaningful predictions. This type of analytics also plays a prominent role in improving patient care, managing chronic disease and increasing efficiency of pharmaceutical logistics. A data-driven approach of preventing disease that is commonly prevalent in society is gaining momentum.
Active monitoring and prevention
Hospitals can predict the deterioration of a patient's health and provide measures of prevention using data science. This can help in early treatment to reduce risk when it comes to patient health. Data science plays a great role in IoT (Internet of Things) and these devices can help in monitoring health indicators. Wearable devices that track heart rate, temperature, and other medical parameters are widely available in the market today. There is tech that even administers the medicine, like a wrist band that pumps insulin based on the sugar levels of a patient. Such data is also collected and analyzed using analytical tools to get an over understanding about the health of the population. From calorie counting to blood pressure, doctors can monitor a patient's health from home devices itself. Use of real-time analytics when it comes to chronically ill patients is very useful in keeping track of their movements and to predict if they will face any issues on the basis of their current condition.
Resource box
Data Science is rapidly growing in the world today and is exceptionally transforming the healthcare and medical industry. Take data science courses to understand more about its applications. check this too Data science Interview Questions.
Kenwood Car... | Answered on Apr 27, 2020
Sandbox games are my favorite! All the Sandbox Games are awesome!
Kenwood Car... | Answered on Apr 01, 2020
Kenwood KDC-116S CD Player Logo
10 questions posted
Top Kenwood Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Kenwood Car Audio & Video
Most Popular Question
need wiring diagram
  • Car Audio & Video
