20 Most Recent Kenwood KDC-415S CD Player Questions & Answers
What wire is the one to hook to live power to
the yellow wire coming from the deck is constant power.
10/19/2010 12:42:53 AM • Kenwood KDC-415S... • Answered on Oct 19, 2010
Kenwood kdc-415s
if there is no amplifier separate from the radio - the blue /white wire from the back of the radio goes to the solid blue wire on the harness attached to the car's plug. the orange wire is not supported by the kenwood radio, so make sure you tape it well- if your not using a separate amp also tape up the blue/white wire coming off the harness you have coming out of the harness to the car. if this helps you please give me a good rating- if not please e-mail me at [email protected] respectfully M. Merle
10/13/2008 5:12:04 PM • Kenwood KDC-415S... • Answered on Oct 13, 2008
I have a Kenwood HDC-MPV622 radio, I forgot the security code and I lost the remote control
Please try understandable grammar. Thank you
10/10/2021 8:25:14 PM • Kenwood Car... • Answered on Oct 10, 2021
Which way to run my current setup? Help!!
Put the kickers with the xplode 1 per channel giving each sub around 450-500 watts. Make sure you select a good ground connection, use think copper wire and both connections must be tightened enough to not move. 10 gauge is good. Run think battery pos+ cable wire from your battery to your apps install spot. Have a fusible link in between the battery and amp. Dont run your speaker wire or rca amp cable with your pos+ wire or it will pick up current causing a high pitched tone. Run remote connection to blue wire on radio harness or to the fuse box ign. Label. Make sure them kickers have a tight seal, and adequate air space. Ported boxes do hit harder but i prefer all sealed myself. Face subs to back of vehicle and roll windows down 15 percent. Good Luck. Holler Back
10/3/2021 6:47:09 PM • Kenwood Car... • Answered on Oct 03, 2021
I have a kenwood cd reciver and I can't turnoff standby mode
This is usually an indication that the power board has a bad component and the signal wont switch on. The problem is usually related to capacitors and unless you want to replace the whole power supply (if you can find it,) the repair is down to the individual components and it technical in nature requiring troubleshooting gear and soldering skill
9/30/2021 4:17:35 PM • Kenwood Car... • Answered on Sep 30, 2021
2answers
I need a security code of keenwood dpx-MP4100 or rest tips
The best is if you try making one or try to figure it out.
9/11/2021 6:59:56 PM • Kenwood Car... • Answered on Sep 11, 2021
How to change language in Kenwood lz-755 to EN, or how to reset?
Hi did you ever find the answer? I'm looking to do the same
8/12/2021 3:15:54 PM • Kenwood Car... • Answered on Aug 12, 2021
Need unlock code for a kenwood kvt-815 dvd
Discussion at the internet link site below that may work. https://www.ecoustics.com/electronics/forum/car-audio/106618.html
8/5/2021 7:40:37 PM • Kenwood Car... • Answered on Aug 05, 2021
Kenwood kdc-w3041 protect mode
Hello ia737,
The "protect" display is probably being caused by a shorted or grounded (touching vehicle chassis or other ground) speaker wire. Check the speaker wires for bare spots, etc and insulate or replace as necessary.
You do not need to remove the fuses to force a "cold reset" of the W-3041. You can simply press the "reset" button on the front of the unit. It's the little recessed button at the lower left of the volume control. Use the straightened end of a paper clip or ballpoint pen to momentarily hold the button in.
Hope this helps.
8/5/2021 11:12:50 AM • Kenwood Car... • Answered on Aug 05, 2021
3answers
Hi i have a kenwood
you can send your stereo back to Kenwood to have the security code reset.
7/11/2021 4:29:04 PM • Kenwood Car... • Answered on Jul 11, 2021
2answers
I need the wiring diagram for a Kenwood Z828/UF4 stereo
Request the diagram from Kenwood.
3/23/2021 3:08:46 AM • Kenwood Car... • Answered on Mar 23, 2021
Need user manual for Kenwood kvs 410 speakers, how to get one?
Request the manual from Kenwood.
3/23/2021 3:04:07 AM • Kenwood Car... • Answered on Mar 23, 2021
Hello, I Have A Kenwood KDC-X817 CD RECEIVER THAT EVERYTHING WORKS BUT THE CD PLAYER I INSTALL A CD AND 3 SECONDS LATER IT COMES BACK OUT WITH ANY CD I PUT IN IT WHAT CAN BE MY PROBLEM???
Buy yourself an Optics Cleaning Disc from Walmart. It has little brushes that clean the tracking Laser and the Read Laser. Yours are dusty and the CD can't be read. https://www.walmart.ca/en/ip/Allsop-56500-CD-Laser-Lens-Cleaner/PRD7K19EOE7SKTG ..
3/10/2021 12:33:00 AM • Kenwood Car... • Answered on Mar 10, 2021
Code for Kenwood DPX-044
The code is based on the serial number of the set. There are companies that will sell you the code. If it came with the vehicle as factory standard issue, the dealership will give you the code if you show them the registration document with VIN Number. Also look for a small white sticker in the glove box or the owner's manual. https://www.google.com/search?q=Code+for+Kenwood+DPX-044 ..
2/28/2021 6:35:15 PM • Kenwood Car... • Answered on Feb 28, 2021
How do I unlock my Kenwood KDC 7009 receiver
Press the "Auto" button and "Track up" on the face of Radio at the same time until the four dash lines disappear. Enter the security code using your Kenwood remote. Press and hold the 1 then the 6 preset keys until the display shows the letter 'C'. Enter the Security code using your Remote
2/19/2021 2:24:29 PM • Kenwood Car... • Answered on Feb 19, 2021
Model KDW60x20. Why is it presenting unlisted fault code 1/2 + 3h + 6h?
I’m also getting this. Did you find out what it was?
2/12/2021 9:05:44 AM • Kenwood Car... • Answered on Feb 12, 2021
Kenwood KDC-415S CD Player Logo
2 questions posted
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
 Francisco Mauricio...
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Kenwood Car Audio & Video
Most Popular Question
wire one hook live power
  • Car Audio & Video
