20 Most Recent Kenwood KDC-MP628 CD Player Questions & Answers
3answers
Kenwood KDC-MP628 unlock code
press the auto and track up, on the face at the same time. The four digit line should go away, then use your remote and enter yout code
The code is 5227
press the numebers: 5 (two times) then press the track up key
2 (three times) then track up
2 (1 time) and track up
7 (two times) track up key again
6/1/2018 12:46:44 PM • Kenwood... • Answered on Jun 01, 2018
I bought a kenwood car stereo at the flea market and when i got home i found out that it has a lock code,is there any way to reset it without the remote control or shipping it to kenwood? it kdc mp628
you have a problem one is able to set security code without the remote without the security code ..not a chance to over ride it a unit reset wont change the security code check the user manual link Kenwood KDC MP628 Manuals options back to the flea market see if the seller is there.. for a refund or contact that flea markets organizers to track down the stall operators details you can try and contact kenwood car stereo company direct in your part of the world this is USAs other countries have their sites http://locator.kenwood.com/ if you have the gift or sweet talking they may give you an authorized kenwood repairer to take the stereo to ...and get the code number for you 26310612-05xlcb20kmvnuzruvlterhkb-3-1.jpg
10/14/2016 2:32:06 AM • Kenwood... • Answered on Oct 14, 2016
3answers
Auxillary option not available in menu
Try putting the unit in standby via the "SRC" button FIRST..., then press the menu button and cycle through to the "AUX 1" option and activate this....then press menu button again. When the unit is next switched on, you should have an "AUX" option accessible via the "SRC" button which will cycle through all of the availale modes ....standby-tuner-cd-aux etc etc.
3/5/2016 6:09:12 AM • Kenwood... • Answered on Mar 05, 2016
No sound from the cd and extended media but have sound from radio
If you have an amplifier connected to the radio, make sure the amp remote wire is connected to the blue/white wire and not the blue wire of the radio. The blue wire is for power antenna and is energized only when tuner is playing, not when cd or ext media is played, and therefore will shut your amp off when playing those sources.
4/27/2014 2:50:49 AM • Kenwood... • Answered on Apr 27, 2014
CODIGO DE SEGURIDAD
Trata de hacer esto:
Mientras el radio te pide el codigo,manten presionados los botones de AUTO y el boton para adelantar las canciones >>/ Repito presionalos por aprox 3 segundos y vas a notar que las lineas que estan despues de la palabra CODE desaparecen;cuando esto pase, con el control remoto apuntalo asia el radio y tienes que formar la palabra kCAR:
1)presiona en el control el 5 dos veces K
* para avanzar al siguiente digito presiona en el control remoto el boton de adelantar cancion >>/
2)presiona en el control el 2 tres veces C
sigue el paso *
3)preesiona el 2 una vez A
sigue el paso *
4)presiona el 7 dos veces R
y por ultima vez saigue el paso *
El display va a decir APPROVED ,y de esta manera se va a borrar cualquier codigo.
cualquier pregunta me puedes contactar [email protected]
2/17/2014 10:52:05 AM • Kenwood... • Answered on Feb 17, 2014
0answers
manual
Am I missing something simple? Read the manual and can't set the time or date on KDC MP628.
Step 1:
Hi there,In standby mode:Enter Menu mode:Press the [MENU] button for at least 1 second."Menu" is displayed.
Step 2:
Select Clock Adjustment mode:Push the Control knob to [FM] or [AM].Select the "Clock Adjust" display.
Step 3:
Enter Clock Adjust mode:Press the Control knob for at least 1 second.The clock display blinks
Step 4:
Adjust the hours:Push the Control knob to [FM] or [AM].Adjust the minutes:Push the Control knob to [Back Search] or [Forward Search].
Step 5:
Exit Clock adjustment modePress the [MENU] button.
Step 6:
Date Adjustment...Select Date Adjust modePush the knob to [FM] or [AM].Select the "Date Adjust" display
Step 7:
Enter Date Adjust modePress the Control knob for at least 1 second.The date display blinks.
Step 8:
Selecting the item (day, month, or year) to adjustPush the Control knob to [Back Search] or [Forward Search].The items that are blinking are items that can be adjusted.
Step 9:
Adjust each itemPush the Control knob to [FM] or [AM].
Step 10:
Repeat step 8 and 9 operation and adjust the date
Step 11:
Exit Date adjustment modePress the [MENU] button.
Step 12:
Setting the date format.Select Date ModePush the Control knob to [FM] or [AM].Select the "Date Mode" display.
Step 13:
Select the date formatPush the Control knob to [Back Search] or [Forward Search].
Step 14:
Exit Menu modePress the [MENU] button.Hope this helps.Cheers,Scott
2/2/2013 8:41:15 AM • Kenwood... • Answered on Feb 02, 2013
Where is the auxiliary port so that I can play music with my iPod?
They're the wires marked "AUX IN" coming out of the back of the unit. See the wiring diagram on page 55 of the manual.
6/24/2012 4:29:57 PM • Kenwood... • Answered on Jun 24, 2012
Where is the auxiliary port so that I can play music using my iPod?
6/24/2012 4:29:45 PM • Kenwood... • Answered on Jun 24, 2012
0answers
HOW TO SET THE TIME
Follow the instructions on page 42 of the manual.
3/23/2012 7:59:26 PM • Kenwood... • Answered on Mar 23, 2012
I need a faceplate for a kdc-mp628.are there any
try pacparts.com.
9/15/2011 5:29:29 PM • Kenwood... • Answered on Sep 15, 2011
2answers
Error 5
Your CD player thinks the CD is in Upside down. Basically it cannot read the disc. You need to run a CD laser Lens cleaner disc to hopefully get it back reading the Discs good again. Otherwise you will nee to take it apart and clean it all yourself manually.
7/3/2011 5:52:24 PM • Kenwood... • Answered on Jul 03, 2011
Kenwood KDC-MP628 CD Player Logo
Popular Tags
68 questions posted
Top Kenwood Car Audio & Video Experts
 Francisco Mauricio...
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Kenwood Car Audio & Video
Most Popular Question
am missing something simple read manual
  • Car Audio & Video
