20 Most Recent Kurzweil SP3X 88-Key Stage Piano Questions & Answers
Kurzweil sp3x tips and tricks
The Kurzweil SP3X is a popular stage piano known for its high-quality sound, responsive keyboard, and versatile features. Some of the advantages of the SP3X include its excellent sound quality, which is achieved through Kurzweil's advanced sound engine and a variety of realistic instrument sounds. It also has a highly responsive keyboard that is suitable for playing a wide range of musical styles. Additionally, the SP3X has a variety of features that make it a versatile and useful instrument for live performances, such as its built-in sequencer, arpeggiator, and various effects. Overall, the Kurzweil SP3X is a reliable and powerful stage piano that is well-suited for both professional and amateur musicians.
1/8/2023 5:52:13 AM • Kurzweil SP3X... • Answered on Jan 08, 2023
Cuts out on me while playing
If you';re sure it's the instrument, rather than your amp cutting out or the cord being intermittent, do a factory reset. Beyond doing a reset, it's doubtfull this will be a user servicable problem. You need to contact Kurzweil Support. Here is a link to their page Support Kurzweil
2/8/2015 9:38:08 PM • Kurzweil SP3X... • Answered on Feb 08, 2015
Gets whacky and freezes up every 2-3 minutes
Is this the correct sustain pedal for this unit? It sounds like it should be a momentary button type. I would look into that. Some have a push to work type of switch and some use momentary. If it is, I would open that pedal and clean the switch with contact cleaner, as it appears to be sticking.
3/6/2013 7:54:59 PM • Kurzweil SP3X... • Answered on Mar 06, 2013
Hello, My KURZWEIL start
It could be your internal battery. Do a search on keyboardforums.com for additional support or Kurzwil website. good luck!
10/22/2011 6:06:04 AM • Kurzweil SP3X... • Answered on Oct 22, 2011
I just got this keyboard and want to hear the
Verify the sound in headphones directly from the unit. The cymbal MAY be panned to one side or the other and will require higher frequency response than some of the piano notes.
9/21/2011 1:35:05 AM • Kurzweil SP3X... • Answered on Sep 21, 2011
When i turn the sp3x
That happened to mine. All I did was hard reset it.
8/22/2011 8:11:04 PM • Kurzweil SP3X... • Answered on Aug 22, 2011
I brought my kurzweil sp
It sounds like the new board and firmware has gone to abbreviations instead of fully spelling it out.
I would complain to the store since they should warrant it if it is a problem... but be prepared to accept that the firmware has been changed and displays differently now.
3/23/2011 7:48:05 PM • Kurzweil SP3X... • Answered on Mar 23, 2011
After transport the keyboard,half of
Probably a cable has come loose inside the unit. The keys are scanned by the internal processor as a matrix of two contacts per key. Often the keyboard is divided into two sections.
You will need to have it repaired or if you are electronically adept, open the case and look for obvious problem.
3/18/2011 4:38:51 AM • Kurzweil SP3X... • Answered on Mar 18, 2011
Mainboard kurzweil sp2
1/9/2023 3:48:04 AM • Kurzweil Music • Answered on Jan 09, 2023
2answers
Kurzweil M1 digital piano is resetting (shutting down and turning on) on its own in the middle of playing.
You're correct, that's a power supply problem, but it may also be the power supply connector on the keyboard. If you have access to a voltmeter, check the power supply first.
9/9/2022 6:00:54 PM • Kurzweil Music • Answered on Sep 09, 2022
Hello, I have a piano kurzweil sp88, which when I turn on, the internal effect led flashes, and the leds internal sound and midi bank are half access, how can I fix this?
I would do a factory reset. If this fails then hardware is likely broken and will take forever to be repaired.
2/2/2019 12:15:18 PM • Kurzweil Music • Answered on Feb 02, 2019
How do I restart when Kurzweil Mark 12 1999 piano hangs at waking up scanner message?
Hard reset procedure 1. Turn the Kurzweil off 2. Hold down the KEY START, KEY STOP, and LAYER VOLUME buttons for 5 seconds while powering the unit up, then release 3. Select RUN DIAGS 4. Press the UP arrow until the display reads RAM TEST 5. Press the START/STOP button to run the test 6. When the display reads SUCCESS, turn the unit off and back on. The unit is now reset. If your Kurzweil still does not come up to the normal screen after this procedure, it will require service.
4/29/2016 1:29:56 PM • Kurzweil Music • Answered on Apr 29, 2016
Kurzweil SP3X 88-Key Stage Piano Logo
15 questions posted
Top Kurzweil Music Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Kurzweil Music Expert? Answer questions, earn points and help others
View Most Popular
Kurzweil Music
  • Kurzweil Music
Most Popular Question
cuts out me while playing
  • Music
