20 Most Recent
Suzuki 4'1" Baby-Grand Digital Piano (High Gloss Black) Questions & Answers
How to replace fuses on Suzuki G-3 digital piano
he process for replacing fuses on a Suzuki G-3 digital piano will vary depending on the specific model and age of your piano. However, in general, the following steps should be followed:
- Unplug the piano from the electrical outlet.
- Locate the fuse holder, which is typically located on the back or bottom of the piano.
- Use a screwdriver to remove the screws that hold the fuse holder in place.
- Carefully remove the old fuses from the holder.
- Replace the old fuses with new fuses of the same rating (usually written on the fuse holder).
- Reinstall the fuse holder and secure it with the screws.
- Plug the piano back in and turn it on.
- Test the piano to ensure that it is working properly.
1/12/2023 7:37:14 PM •
Suzuki Music
Answered
on Jan 12, 2023
I have a Suzuki HP-97 electronic piano and the
I called VMI Electronics and they sold me a repair kit called Key Mod, you can reach the company at: (619)244-0006 you can also orderer the repair kti through ebay: http://www.ebay.com/itm/Key-Mod-Piano-Rod-Replacement-Kit-/190822310728?pt=LH_DefaultDomain_0&hash=item2c6de56348
4/9/2013 5:01:03 AM •
Suzuki Music
Answered
on Apr 09, 2013
Several of my minor key
We can't guess what type of Suzuki instrument you might have... they make MANY types of instruments, including pianos.
6/19/2011 2:21:56 PM •
Suzuki Music
Answered
on Jun 19, 2011
Peavey cs1000 x
The most likely case is that one of the main output transistors (if which there are many) is shorted. When the protect circuit senses DC on the final output, it will not allow the output relay to come on to protect the speakers from raw DC. With the power removed, you can check between each outputs Emitter and Collector and you will probably find close to zero ohms. From that point you need to unsolder each of the pins of the bad channel until you find the shorted device(s) and replace them.
2/7/2024 9:32:20 AM •
Music
Answered
on Feb 07, 2024
No or very little sound from Fender passport
Depending on the model, there are four around that date, it could be the insert jacks are tarnished reducing the signal flow between the pre amp stage and digital power amplifier. It could be the power amplifier has failed. It could even be customer error in wiring.
This assumes there is the correct level of signal entering the input sockets of course.
12/31/2023 8:25:12 AM •
Music
Answered
on Dec 31, 2023
